Config File stopped working after update
So I installed the update. I use the same config file as before the update. I get a config error. I used Jshint and get zero error.
Try copying and pasting the config.js.sample, renaming it to config.js (after renaming your old config so you don’t lose it) and see if that works. If it does you can copy over the entries from your old config.
@Mykle1
Just did that and get the same error. -
Mykle1 Project Sponsor Module Developerlast edited by Mykle1 Apr 3, 2017, 1:27 AM Apr 3, 2017, 12:48 AM
@bocapie
Assuming your console isn’t showing any errors, then I would go to the repo and grab the config.js.sample from there to be sure it’s the new one from MM 2.1.1 and try again -
Also, read this post. Even a Module Developer is having some troubles with the update. However, he did find a workaround that worked for him.
https://forum.magicmirror.builders/topic/2190/mm-died-after-upgrade/5 -
I got it to load at the bottom line module was with a ’ instead of a "
@bocapie said in Config File stopped working after update:
When I was first setting up my mirror, I had a bunch of typos that ruined it. Glad you figured it out!
