    MMM-UKNationalRail - Rail departure info for specific UK Railway stations
    uk railtransport
    33 Posts 15 Posters 24.4k Views 16 Watching
    • nwoottonN Offline
      nwootton Module Developer
      Description:
      Retrieves information about rail services running through a specific UK rail station. Built on the Transport API.
      See documentation in the README and on the TransportAPI developer portal.
      Screenshot:
      GitHub Repo: https://github.com/nwootton/MMM-UKNationalRail
        McSorley
        Not given this a go yet but I’ll be sure to give it a try.
        I reckon it will always be marked “Late” though…
        nwoottonN 1 Reply Last reply Reply Quote 0
        • nwoottonN Offline
          nwootton Module Developer @McSorley
          @McSorley I considered making it flash and make noises if the train was on time, but it’s such an edge case that I didn’t think it was worth the effort! :)
          • nwoottonN Offline
            Now includes the platform and a slightly better layout.
              Mar
              @nwootton Thank you so much for this!!! Its my most used module by far and i’ve only had it a week! Wish I could buy you a beer bc you deserve it!
              • nwoottonN Offline
                nwootton Module Developer @Mar
                @Mar Thanks, I’m glad you like it.
                • nwoottonN Offline
                  New version release - better layout, more display options and ability to run multiple station configs.
                  Please provide feedback either here, or by opening an issue on GitHub here.
                  Thanks.
                  • randomnoiseR Offline
                    randomnoise
                    @nwootton This is brilliant, cheers for making this. I was trying to make my own module using this API by attempting to modify existing modules but I never got it running properly & then I moved on to another project. Saw someone on Reddit with a mirror build with UK train data today so I came back to see you’ve completed all the hard work :)
                    • nwoottonN Offline
                      nwootton Module Developer @randomnoise
                      @randomnoise Thanks for that, glad you like it. There’s a bus version as well if you want it!
                      Can you stick a link to the Reddit post up here if you get a chance, would be nice to see one in the wild so to speak!
                      randomnoiseR 1 Reply Last reply Reply Quote 0
                        randomnoise @nwootton
                        @nwootton this is the post in DIY https://www.reddit.com/r/DIY/comments/6fo4fg/i_too_made_a_magic_mirror/
                        I’ll check out the bus one as well once my PI finishes downloading updates (shamefully its been sitting on my desk doing nothing for over 6 months while I fiddled about elsewhere).
                          McSorley
                          Those kind of reddit posts make me wish I took photos when I built mine. Looks great.
                          • N Offline
                            noelandrews
                            apologies, sure i’m doing something obvious but my module isn’t showing up.
                            I’ve done to install it, git clone… then cd to the folder and npm install
                            then add to the config.js file (my addition below).
                            I changed the ’ to " in case that was causing the issue. Still no joy, no errors on the screen it simply doesn’t show up.
                            Any help would be massively appreciated.
                            Noel
                                            module:                 "MMM-UKNationalRail",
                                            position:               "bottom_left",
                                            header:                 "Departures",           //Optional - delete this line to turn OFF the header completely
                                                    stationCode:            "LNB",          // CRS code for station
                                                    app_id:                         "49d8e014",             // TransportAPI App ID
                                                    app_key:                        "1a3d4XXXXXXXXXXXceac3d9f14be",             // TransportAPI App Key
                                                    maxResults:             5,              //Optional - Maximum results to display.
                                                    showOrigin:             false           //Optional - Show the origin of the train in the table
                            • nwoottonN Offline
                              @noelandrews said in MMM-UKNationalRail - Rail departure info for specific UK Railway stations:
                              I have to say - changing the " to ’ made it work for me.
                                      module: 'MMM-UKNationalRail',
                                      position: 'bottom_left',
                                      header: 'Departures', //Optional - delete this line to turn OFF the header completely
                                          stationCode: 'LNB', // CRS code for station
                                          app_id: '49XXX014', // TransportAPI App ID
                                          app_key: '1a3d4XXXXXXXXXXXceac3d9f14be', // TransportAPI App Key
                              Also using the API_ID, API_Key and Station code in the actual TransportAPI also worked. Could it be the rest of JSON config that has issues? Have you tried pasting the whole file into something like jsonlint.com to validate it’s right.
                              I’d STRONGLY advise you remove your API keys from the JSON. Hate for other people to mis-use your account BTW
                              • Y Offline
                                yawns Moderator @nwootton
                                @nwootton said in MMM-UKNationalRail - Rail departure info for specific UK Railway stations:
                                Good advise. That’s why I edited his post and replaced several characters with X :)
                                • N Offline
                                  noelandrews
                                  Thanks for the advice and the edits! Didn’t think about that :)
                                  • nwoottonN Offline
                                    nwootton Module Developer @yawns
                                    @yawns Explains why my email had the key and the post was XXXXXX.
                                    Thought I was losing it!
                                    • F Offline
                                      funk0id
                                      Absolutely love this plugin, just wish it was still being improved :(
                                        dawookie1979
                                        Hello, i have the module working, i just cant get it to display the title.
                                        module: ‘MMM-UKNationalRail’,
                                        position: ‘bottom_left’,
                                        header: ‘Whittlesford Parkway’, //Optional - delete this line to turn OFF the header completely
                                        stationCode: ‘WLF’, // CRS code for station
                                        app_id: ‘xxxxxxxx’, // TransportAPI App ID
                                        app_key: ‘xxxxxxxxxx’, // TransportAPI App Key
                                        any ideas?
                                          sdetweil @dawookie1979
                                          @dawookie1979 u mean the header?
                                            dawookie1979
                                            yes the header is not showing
