    MMM-UKNationalRail - Rail departure info for specific UK Railway stations
    uk railtransport
    33 Posts 15 Posters 22.0k Views 16 Watching
      Mar
      @nwootton Thank you so much for this!!! Its my most used module by far and i’ve only had it a week! Wish I could buy you a beer bc you deserve it!
      nwoottonN 1 Reply Last reply Reply Quote 0
      • nwoottonN Offline
        nwootton Module Developer @Mar
        @Mar Thanks, I’m glad you like it.
        • nwoottonN Offline
          New version release - better layout, more display options and ability to run multiple station configs.
          Please provide feedback either here, or by opening an issue on GitHub here.
          Thanks.
          • randomnoiseR Offline
            randomnoise
            @nwootton This is brilliant, cheers for making this. I was trying to make my own module using this API by attempting to modify existing modules but I never got it running properly & then I moved on to another project. Saw someone on Reddit with a mirror build with UK train data today so I came back to see you’ve completed all the hard work :)
            • nwoottonN Offline
              nwootton Module Developer @randomnoise
              @randomnoise Thanks for that, glad you like it. There’s a bus version as well if you want it!
              Can you stick a link to the Reddit post up here if you get a chance, would be nice to see one in the wild so to speak!
              randomnoiseR 1 Reply Last reply Reply Quote 0
                randomnoise @nwootton
                @nwootton this is the post in DIY https://www.reddit.com/r/DIY/comments/6fo4fg/i_too_made_a_magic_mirror/
                I’ll check out the bus one as well once my PI finishes downloading updates (shamefully its been sitting on my desk doing nothing for over 6 months while I fiddled about elsewhere).
                  McSorley
                  Those kind of reddit posts make me wish I took photos when I built mine. Looks great.
                  • N Offline
                    noelandrews
                    apologies, sure i’m doing something obvious but my module isn’t showing up.
                    I’ve done to install it, git clone… then cd to the folder and npm install
                    then add to the config.js file (my addition below).
                    I changed the ’ to " in case that was causing the issue. Still no joy, no errors on the screen it simply doesn’t show up.
                    Any help would be massively appreciated.
                    Noel
                                    module:                 "MMM-UKNationalRail",
                                    position:               "bottom_left",
                                    header:                 "Departures",           //Optional - delete this line to turn OFF the header completely
                                            stationCode:            "LNB",          // CRS code for station
                                            app_id:                         "49d8e014",             // TransportAPI App ID
                                            app_key:                        "1a3d4XXXXXXXXXXXceac3d9f14be",             // TransportAPI App Key
                                            maxResults:             5,              //Optional - Maximum results to display.
                                            showOrigin:             false           //Optional - Show the origin of the train in the table
                    • nwoottonN Offline
                      @noelandrews said in MMM-UKNationalRail - Rail departure info for specific UK Railway stations:
                      I have to say - changing the " to ’ made it work for me.
                              module: 'MMM-UKNationalRail',
                              position: 'bottom_left',
                              header: 'Departures', //Optional - delete this line to turn OFF the header completely
                                  stationCode: 'LNB', // CRS code for station
                                  app_id: '49XXX014', // TransportAPI App ID
                                  app_key: '1a3d4XXXXXXXXXXXceac3d9f14be', // TransportAPI App Key
                      Also using the API_ID, API_Key and Station code in the actual TransportAPI also worked. Could it be the rest of JSON config that has issues? Have you tried pasting the whole file into something like jsonlint.com to validate it’s right.
                      I’d STRONGLY advise you remove your API keys from the JSON. Hate for other people to mis-use your account BTW
                      • yawnsY Offline
                        yawns Moderator @nwootton
                        @nwootton said in MMM-UKNationalRail - Rail departure info for specific UK Railway stations:
                        Good advise. That’s why I edited his post and replaced several characters with X :)
                        • 1 / 4
