    MMM-UKNationalRail - Rail departure info for specific UK Railway stations
    uk railtransport
    33 Posts 15 Posters 24.4k Views 16 Watching
    • randomnoiseR Offline
      randomnoise @nwootton
      @nwootton this is the post in DIY https://www.reddit.com/r/DIY/comments/6fo4fg/i_too_made_a_magic_mirror/
      I’ll check out the bus one as well once my PI finishes downloading updates (shamefully its been sitting on my desk doing nothing for over 6 months while I fiddled about elsewhere).
        McSorley
        Those kind of reddit posts make me wish I took photos when I built mine. Looks great.
        • N Offline
          noelandrews
          apologies, sure i’m doing something obvious but my module isn’t showing up.
          I’ve done to install it, git clone… then cd to the folder and npm install
          then add to the config.js file (my addition below).
          I changed the ’ to " in case that was causing the issue. Still no joy, no errors on the screen it simply doesn’t show up.
          Any help would be massively appreciated.
          Noel
                          module:                 "MMM-UKNationalRail",
                          position:               "bottom_left",
                          header:                 "Departures",           //Optional - delete this line to turn OFF the header completely
                                  stationCode:            "LNB",          // CRS code for station
                                  app_id:                         "49d8e014",             // TransportAPI App ID
                                  app_key:                        "1a3d4XXXXXXXXXXXceac3d9f14be",             // TransportAPI App Key
                                  maxResults:             5,              //Optional - Maximum results to display.
                                  showOrigin:             false           //Optional - Show the origin of the train in the table
          • nwoottonN Offline
            nwootton Module Developer
            @noelandrews said in MMM-UKNationalRail - Rail departure info for specific UK Railway stations:
            I have to say - changing the " to ’ made it work for me.
                    module: 'MMM-UKNationalRail',
                    position: 'bottom_left',
                    header: 'Departures', //Optional - delete this line to turn OFF the header completely
                        stationCode: 'LNB', // CRS code for station
                        app_id: '49XXX014', // TransportAPI App ID
                        app_key: '1a3d4XXXXXXXXXXXceac3d9f14be', // TransportAPI App Key
            Also using the API_ID, API_Key and Station code in the actual TransportAPI also worked. Could it be the rest of JSON config that has issues? Have you tried pasting the whole file into something like jsonlint.com to validate it’s right.
            I’d STRONGLY advise you remove your API keys from the JSON. Hate for other people to mis-use your account BTW
            • Y Offline
              yawns Moderator @nwootton
              @nwootton said in MMM-UKNationalRail - Rail departure info for specific UK Railway stations:
              Good advise. That’s why I edited his post and replaced several characters with X :)
              nwoottonN 1 Reply Last reply Reply Quote 0
              • N Offline
                noelandrews
                Thanks for the advice and the edits! Didn’t think about that :)
                • nwoottonN Offline
                  nwootton Module Developer @yawns
                  @yawns Explains why my email had the key and the post was XXXXXX.
                  Thought I was losing it!
                  • F Offline
                    funk0id
                    Absolutely love this plugin, just wish it was still being improved :(
                      dawookie1979
                      Hello, i have the module working, i just cant get it to display the title.
                      module: ‘MMM-UKNationalRail’,
                      position: ‘bottom_left’,
                      header: ‘Whittlesford Parkway’, //Optional - delete this line to turn OFF the header completely
                      stationCode: ‘WLF’, // CRS code for station
                      app_id: ‘xxxxxxxx’, // TransportAPI App ID
                      app_key: ‘xxxxxxxxxx’, // TransportAPI App Key
                      any ideas?
                        sdetweil @dawookie1979
                        @dawookie1979 u mean the header?
                          dawookie1979
                          yes the header is not showing
                          • T Offline
                            tenpinmark
                            Does anyone have a multi-station configuration working? I also do not get any headers showing - anyone managed to solve that one?
                            Thanks in advance
                              Bob
                              Headers have been broken for a while now. Happened after MM version update. Not sure if @nwootton is still working on this or not though.
                              Also not been able to get multi-station working. The fix I used was just to have 2 modules listed one after each other (ie, duplicate the code in the config file, including API etc). That seems to work fine.
                              • T Offline
                                tenpinmark
                                Hi Bob,
                                Thanks for the information. I’ve been playing and have fixed up the header not being shown and in addition have added column headings such as "Platform, To, From, Planned, Actual and Status to the displayed table.
                                I have seen in the forums elsewhere you do have to have multiple modules in order to get multiple stations which I suppose is OK, but a bit awkward. I may have a look to see if this can be all rolled into one config section.
                                One other feature I would like to work on is this: My partner travels home eveyday and says what train she is on, but never knows what time it will arrive at our home station - I want to see if it is possible to have a a listing of the possible trains with the departue and arrival times. As I’m very new to all this, it’s going to hurt my head coding it I suspect.
                                • G Offline
                                  Glass92 @tenpinmark
                                  @tenpinmark
                                  Hi Tenpin,
                                  Sounds like me and you want the same thing!
                                  I’m currently having issues with my module updating after a refresh though, don’t know what is going on there! Essentially after I restart the Mirror, the module will work for a couple of hours, then when I get up the next day it will still be showing last nights times, almost like it’s frozen.
                                  How did you get the Header sorted and column headings?
                                  I am also using MMM-ModuleScheduler to display the specific Trains at different times.
                                  I have three modules running see below, where my app id and app key I have replaced with xxx.
                                  One for my partner, Monday to Friday from Home to Work in the morning. Stirling - Dundee (See Station Code is Stirling, calling_at: Dundee)
                                  One for my partner, Monday to Friday from Work to Home in the evening. Dundee - Stirling (See Station Code is Stirling, called_at: Dundee)
                                  One for me, Tuesday to Thursday from Home to Work in the morning. Stirling - Glasgow (See Station Code is Stirling, calling_at: Glasgow)
                                  			header:			'Stirling - Glasgow',		//Optional - delete this line to turn OFF the header completely
                                  			classes: 'scheduler',
                                  				module_schedule: {from: '0 7 * * 2-4', to: '0 9 * * 2-4' },
                                  				stationCode: 		'STG', 		// CRS code for station
                                  				calling_at: 		'GLQ',
                                  				app_id: 			'xxx', 		// TransportAPI App ID
                                  				app_key: 			'xxx', 		// TransportAPI App Key
                                  				maxResults: 		3,  		//Optional - Maximum results to display.
                                  				showOrigin: 		true   	//Optional - Show the origin of the train in the table
                                  			header:			'Stirling - Dundee',		//Optional - delete this line to turn OFF the header completely
                                  				module_schedule: {from: '0 7 * * 1-5', to: '0 9 * * 1-5' },
                                  				calling_at: 		'DEE',
                                  			header:			'Dundee to Stirling',		//Optional - delete this line to turn OFF the header completely
                                  				module_schedule: {from: '0 17 * * 1-5', to: '30 19 * * 1-5' },
                                  				called_at: 			'DEE',
                                  This is my partner’s trians for coming home
                                  https://imgur.com/a/OGflgLi
                                  See it doesn’t list Stirling. It lists end destination and origin station.
                                    Bob
                                    @tenpinmark Any chance you can post the code you used to fix it ? (or submit a fork to switch to instead)
                                    @Glass92 I had similar problems (and only with this module). My solution was to create a cron job to reboot the mirror after midnight, which restarted the code. It’s not ideal, and actually introduces other issues with the HDMI port (will sometimes fail to initialise the display). I’ve since removed the cron job, and now just manually reboot if needed (usually once every couple of days)
                                      alexbell62
                                      Is there a way to make it work?
                                        matt216
                                        Getting emails from transportapi.com saying I’m over my call limit. Anyone else?
                                          matt216
                                          Looks like transportAPI.com has changed their free tier to just 30 calls per day. This module (for me) seems to have used almost 300 per day previously.
                                          Also it doesn’t look like the module is maintained by the developer anymore.
                                          1 Reply Last reply Reply Quote -1
                                            Bungle68
                                            Is anyone able to show how I can get arrivals as well as departures showing?
                                            I tried this, but it’s still only showing Departures.
                                            	header:		'Departure',		//Optional - delete this line to turn OFF the header completely
                                            		stationCode: 		'CUF', 		// CRS code for station
                                            		app_id: 		'8e9c6489', 	// TransportAPI App ID
                                            		app_key: 		'd8*********************7c9c45550', 	// TransportAPI App Key
                                            		showOrigin: 		false,   	//Optional - Show the origin of the train in the table
                                            		type: "arrival,departure"
