    http request
    53 Posts 7 Posters 52.5k Views 6 Watching
    • E Offline
      Eunanibus Module Developer
      Make sure that you’re not just copy and pasting blindly into your config file.
      After each
      etc
      Note the comma , after the module. That comma should only be there if there are more modules.
      Likewise, if you’re pasting it last, you need to make sure the module before it has one, to let the script know there are more modules after the previous one.
      So the pattern is
         module: ‘firstModule’,
         option : ""
      }, <<< COMMA HERE
         module: ‘middleModule’,
         option : ""
      }, <<< COMMA HERE
         module: ‘last module’,
         option : ""
      } <<<<< NO COMMA
      hope that makes sense. hopefully that’s the problem.
        acdacd2
          acdacd2
          • E Offline
            Can you Zip up and upload your config file somewhere I can download it and I’ll take a look? Somewhere like pastebin.
            • K Offline
              KirAsh4 Moderator
              Hey @acdacd2, please use proper Markdown when posting code. It really isn’t that hard to do and it makes it so much easier and pleasant for others to read, and possibly find errors quicker. Specifically you need to use back ticks before and after your code:
                   like so. Note that a back tick is not the same as the normal apostrophe, ` versus ' .
              • E Offline
                @KirAsh4 can you confirm MM startup with my module with this config file?
                The module won’t show any results but MM should boot?
                • K Offline
                  KirAsh4 Moderator
                  The file ‘status.xml’ doesn’t exist on my system, so it gets a 404 returned, however it does load up, and it does work.
                    acdacd2
                    I have the same message with my environment.
                    In a browse it’s ok
                    • K Offline
                      KirAsh4 Moderator
                      Right, I have not tested this on an actual rpi … I’m at the office, so I’m running a serveronly setup. I can do an rpi test later, although I suspect it will still work, as opposed to resulting in a blank screen. It returns the error as expected when it can’t find the file.
                        acdacd2
                        with a browser on the pi, it’s also ok
                        • E Offline
                          @KirAsh4 I’ve isolated the issue as a Cross-Domain Access issue. Do you know of any particular way to make XMLHTTPRequests to external domains?
                          I wasn’t aware this would be an issue but apparently anybody who wants to use this and map to an external domain will have this issue unless they have a running PHP server that can store the XML results locally (or if they can access a server, they can add the line Access-Control-Allow-Origin: * to their HTML headers.
                          Any ideas?
                          • K Offline
                            KirAsh4 Moderator
                            XMLHTTPRequest. Look at how the 'currentweather' module does it in the 'updateWeather()' function.
                            • E Offline
                              Yeah that’s what I based my original request functionality on. The OpenWeather API response is CORS compatible due to the response header - this is why the example response works well. Outside of this domain though (say on http://www.w3schools.com/xml/cd_catalog.xml (or any other external server). This unfortunately makes problems - I’m still looking for a work-around.
                              • K Offline
                                KirAsh4 Moderator
                                Welcome to Javascript security issues.
                                  acdacd2 @KirAsh4
                                    acdacd2
                                      acdacd2
                                        acdacd2
                                        I’m using that code in php
                                        $xml = simplexml_load_file('XML/status1.xml');
                                        echo "<br>--------------<br>XML parsing <br>--------------<br>";
                                        $result = array();
                                        foreach($xml->children() as $child){
                                        $result[$child->getName()] = trim($child);
                                        • strawberry 3.141S Offline
                                          have a look in here https://forum.magicmirror.builders/topic/240/soccer-standings i had also problems with cors so i used the request module in my node_helper to fix it
                                            acdacd2
                                            I copied the xml file on a synology web server, same behaviour status :0
                                            • 2 / 3
