Black Screen after Launching application.
When i run the application it starts and a Black Screen comes and nothing is displayed… i tried various ways but still does not show anything
every command is working fine, logs start stop but it does not display anything
Please help
magicmirror@2.1.1 start /home/pi/MagicMirror
sh run-start.shStarting MagicMirror: v2.1.1
Loading config …
Loading module helpers …
No helper found for module: aiclient.
No helper found for module: aiclientdebugger.
All module helpers loaded.
Starting server on port 8080 …
Starting server op port 8080 …
Server started …
Sockets connected & modules started …
Launching application. -
Far as I can tell, there is a black screen when you made a mistake in the config.js file or if you made a mistake in the code of module.
Did you wrote the module you want to use yourself ? -
Try starting with dev tools and click
consoleonce it has started. Are you getting any errors reported there?pi@raspberrypi:~/MagicMirror $ npm start dev -
application runs fine on pi@raspberrypi:~/MagicMirror $ npm start dev but again black screen nothing can be seen, i checked the logs they also shows no error, i have only used the default modules
@romain - i just did the git clone of the repository and no new addition done to any modules
@undergroundauth said in Black Screen after Launching application.:
a
git cloneof the repo would only try to download the repo again. Agit pullwould try to update. Make sure your node is up to date and try again if it updates. I assume you did annpm installin the MagicMirror directory, as per the installation instructions.Did you do the automatic installation?
The manual installation?
Update from 2.1.0? -
@Mykle1 - I did the same as you said, here is the log of the dev environment it appers to be the problem with aiclient//aiclient.js
Please help
main.js:406 Initializing MagicMirror.
translator.js:182 Loading core translation file: translations/en.json
translator.js:204 Loading core translation fallback file: translations/en.json
loader.js:182 Load script: modules/aiclient//aiclient.js
aiclient.js Failed to load resource: the server responded with a status of 404 (Not Found)
loader.js:190 Error on loading script: modules/aiclient//aiclient.js
script.onerror @ loader.js:190
loader.js:182 Load script: modules/aiclientdebugger//aiclientdebugger.js
aiclientdebugger.js Failed to load resource: the server responded with a status of 404 (Not Found)
loader.js:190 Error on loading script: modules/aiclientdebugger//aiclientdebugger.js
loader.js:197 Load stylesheet: css/custom.css
main.js:424 All modules started! -
@undergroundauth This is weird, you said you did not add module and yet, your log talk about “modules/aiclient” wich isn’t a default module . In a fresh cloned repository, your modules folder should only have a “default” folder, a “node_modules” folder and a “Readme.md” file in it.
your error talk about a “modules/aiclient” so it’s clear that you have another folder named “aiclient” in it. And If there is an error on it, it’s also mean the magic mirror try to call it which mean you add a section on the “config/config.js” file in the magic mirror repository.
So this module must have an error in it that messed up the display.
do something like renaming the current config file and reset the default value on a new one.
the following command should do the trickmv ~/MagicMirror/config/config.js ~/MagicMirror/config/old_config.js.save cp ~/MagicMirror/config.js.sample ~/MagicMirror/config.jsIf you didn’t mess with the config.js.sample it should reset your config.js to the default configuration.
Try to run the magic mirror next and tell us if something appear on the mirror. -
Even I have the same black screen problem. I have not added any other modules. Just have renamed the config.js.sample to config.js
The application launches with a black screen. -
@dhirajv12
In the terminal it says
No helper found for module: clock
no helper found for module: complements -
When i start the console
With npm start dev following errors are found
Uncaught reference error: moment is not defined
At Class.getDom (clock.js:77)
At updateDom (main.js:99)
at Object.updateDom (main.js:470)
at Class.updateDom (module.js:291)
at clock.js:45Need help I am stuck
Thanks -
@dhirajv12
For the black screen proble, I even did the git pull to update
git pull https://github.com/MichMich/MagicMirror
From https://github.com/MichMich/MagicMirror- branch HEAD -> FETCH_HEAD
Already up-to-date.
Now where is the issue??? Stuck please help
@dhirajv12 Let’s double-check some things. Please enter the following.
cd ~/MagicMirror rm -rf modules/aiclient git pull npm install cp config/config.js.sample config/config.js npm startWith luck, that should at the very least get you a basic interface with the calendar, clock, compliments and newsfeed.
@dhirajv12 said in Black Screen after Launching application.:
no helper found for module: complementsThis is normal. The system is checking for a
node_helper.jsfile for every module. Those modules do not have one, so it is reported as such during the startup process.
