    MMM-Transilien (Paris - France)
    24 Posts 9 Posters 16.9k Views 9 Watching
      bobbob601
      M 1 Reply Last reply Reply Quote 2
      • N Offline
        ninja
        Nice job and thank you bobbob601 !
        IMPORTANT: To use the module, you will need to ask for the API credentials by e-mail here : https://ressources.data.sncf.com/explore/dataset/api-temps-reel-transilien/ -> then click on “demande par mail”
        It’s pretty painfull, but for now, it’s the only method.
          jeremy_fr
          Hi!
          Thank you very much for this great job again :)
          I’ve just asked for Transilien API credentials.
          Just one question: why not use the SNCF API, based on Navitia (https://data.sncf.com/api/fr/documentation)?
          The authentication key can be obtained directly by creating an account, without waiting days or weeks…
          Thank you again!
          Jeremy
          • N Offline
            ninja
            Hi Jeremy !
            We ask for this API, because on the one you mentionned I see:
            "The SNCF API contains theoretical train data for the following commercial modes: TGV, TER, Transilien, Intercités.
            The SNCF API also contains realtime train data for the following commercial modes: TGV, TER, Intercités."
            For realtime, on this particular API there isn’t (I guess) real time Transilien, which was the reason of this module, and the use of the other API.
            (Perhaps I miss understood their indications and give wrong information to bobbob601 ?)
              bobbob601
                jeremy_fr
                Ok, I understand. Thank you!
                Now, I have to wait days or week to use this wonderful module!
                  bobbob601
                    bobbob601
                      jeremy_fr
                      Just got my credentials after 9-10 days!
                      It works like a charm :)
                      Thank you very much!
                        masterbalby @bobbob601
                        @bobbob601
                        Bonjour,
                        J’utilise quotidiennement ce module mais je rencontre un petit problème pour la configuration.
                        Au départ de ma ville (Ville d’avray) il existe deux lignes du transilien. La ligne L (vers St Lazare) et la ligne U (vers La Défense).
                        En fonction de l’état du trafic j’utilise l’une ou l’autre.
                        Pour se faire j’utilise la configuration suivante :
                        			module: 'MMM-Transilien',
                        			position: 'top_left',
                        			header:'VDA vers St Lazare',
                        			config:{
                        				departUIC:"87382341",
                        				arriveeUIC:"87384008",
                        				login:"xxx", // You must add your API login and password
                        				password:"xxx"
                        			header:'VDA vers La Défense',
                        			config:{
                        				arriveeUIC:"87382218",
                        				password:"xxx"
                        Le problème est bien visible sur la capture d’écran ci-dessous
                        Les trains sont mélangés dans les deux modules. Je devrais avoir uniquement les trains PASA dans le premier module et que les trains DEFI dans le deuxième module.
                        La question est de savoir où je me suis trompé.
                        Par avance merci pour l’aide apportée.
                        • Q Offline
                          quisuisje
                          bonjour, j’ai un écran noir quand je lance le modules.
                          voici mon code:
                          module: “MMM-Transilien”,
                          position: “middle_center”,
                          header:“Nemours vers Gare de Lyon”,
                          config:{
                          departUIC:“87684126”,
                          arriveeUIC:“87686006”,
                          login:“4d863c97-…”, // You must add your API login and password
                          password:“…”
                          pensez vous que les codes UIC ne sont pas bonne et qui me cause l’ecran noir ?
                          en attente de vos reponse
                          Q 1 Reply Last reply Reply Quote 0
                          • Q Offline
                            quisuisje @quisuisje
                            @quisuisje bon j’ai trouvé le probleme d’ecran noir dans le dossier modules/MMM-Transilien/ faite un npm install
                            pour le node.js
                            ca marche impeccable!
                              solid
                              Bonjour,
                              J’ai le même problème que @quisuisje, mais par contre j’ai bien recompilé en lançant la commande “npm install”.
                              Y’a t-il d’autres utilisateurs dans le même cas ?
                              N’y a t-il pas eu des changements avec l’API Transilien ?
                              Merci ;)
                                solid
                                Rectif, je n’avais pas lancé la commande “npm install” dans le bon dossier…
                                • G Offline
                                  G271IFCS
                                  Hello les gens
                                  nouveau sur le forum , je suis a la recherche de réponses .
                                  J’ai installé ce module avec quelques difficultés je dois bien l’admettre, et maintenant que mon miroir affiche l’info je suis a moitié soulagé. Pourquoi à moitié ? Parce que j’ai “Loading next train” d’affiché mais point d’horaires…qu’ai je loupé ? Une idée ?
                                  Pour info : api SNCF demandée et reçue c’est un grand chiffre ponctué de tirets et de chiffres et de lettres, rien mis dans password, UIC renseignés, j’ai même reçu un email de Transilien avec login et mdp que je n’ai pas utilisé puisque j’ai privilégié celui envoyé par SNCF…help…
                                    jeremy_fr
                                    Salut @G271IFCS,
                                    En regardant dans mon fichier de configuration (config.js), je vois que mon login est un code alphanumérique à 8 caractères (pas de tirets). J’ai aussi un password. Il doit donc y avoir un problème du côté de ton API login et du password associé.
                                    Pour être honnête, je ne me souviens plus comment je l’ai récupéré mais je pourrais le retrouver si tu ne t’en sors toujours pas.
                                    • G Offline
                                      G271IFCS
                                      Merci jeremy_fr, je teste ça et te tiens au courant…j’ai bien un login et pwd mais je ne l’ai pas utilisé , j’ai préféré employer la clé API envoyée par la SNCF alors que peut etre c’est l’identifiant et mdp du transilien que j’aurai dû mettre. (pour info c’est le RER qui m’interesse)
                                      • G Offline
                                        G271IFCS
                                        Bonsoir,
                                        essayé selon les conseils de jeremy_fr…sans succès, j’ai toujours ce message “loading next train”, je suis a bout d’idées…
                                        • G Offline
                                          G271IFCS
                                          ça maaaaarche ! (je ne sais pas pourquoi)
                                            jeremy_fr
                                            Tant mieux :)
                                            Pour aider la communauté, peux-tu confirmer que c’est bien suite à la correction des paramètres Login et password que le problème s’est corrigé ?
                                            Merci :)
