    multiple module instances overwrites itself values
    Scheduled Pinned Locked Moved Unsolved Development
    13 Posts 7 Posters 12.7k Views 9 Watching
      BenRoe Module Developer
      Ok other question.
      If i setup a module twice in the config, do they share the variables from the code?
        DazDavid
        Any news here?
        B 1 Reply Last reply
          BenRoe Module Developer @DazDavid
          @DazDavid nope
            chrisyy
            Would it work if u give them names like MMM-FHEM1 and MMM-FHEM2?
            Cause if u add two instances with the same name in the config i can imagine, that he will read the first value and overwrites them in the second instance. Like
            var variable = 1;
            var variable = 2;
            Output would be 2.
              bobbob601
              Reply Quote 3
                BenRoe Module Developer @bobbob601
                @bobbob601 thx for the answer. Do you have a example how to write a module with multi-instace support?
                R 1 Reply Last reply
                  RedNax Module Developer @BenRoe
                  @BenRoe
                  Having the same problem with my module… A theoretical solution could be to make node_helper multi instance aware by appending some identifier to the notification unique to the instance: ie GET_WEATHER_001… The helper triggers on GET_WEATHER and builds an array with the different notifications and payloads. It then periodically runs through the array getting the appropriate requests and sending out notifications like WEATHER_001 with the specific payload.
                  Haven’t built it yet though…
                    bobbob601
                    T 1 Reply Last reply
                    • T
                      trgraglia @bobbob601
                      @bobbob601 I got it working by passing a unique ID to the node helper and passing it back from the node helper.
                      https://github.com/trgraglia/MMM-MVG-LocalTransport
                      Hope this helps.
                      http://www.anthonygraglia.com/
                        bobbob601
                        • T
                          @bobbob601 Yup. In my case, the user provides a station ID per instance because it has to do with local transport here in Munich. So in theory, the user is already providing unique IDs and I have no need to generate them. ;)
                          • strawberry 3.141S
                            every instance has already a unique identifier see here https://github.com/MichMich/MagicMirror/tree/master/modules#available-module-instance-properties
                            also the discussion in here is related to the issue https://forum.magicmirror.builders/topic/960/london-bus-status/14
