    multiple module instances overwrites itself values
    Scheduled Pinned Locked Moved Unsolved Development
    13 Posts 7 Posters 10.2k Views 9 Watching
      BenRoe Module Developer
      i am working on a module for FHEM. The module can show data like temperature from FHEM devices. It is working, but if i add two instances of the module to the config.js it overwrites the dom values.
            module: 'MMM-FHEM',
            position: 'bottom_bar',
              host: '192.168.178.28',
              port: '8083',
              deviceNames: [
                            'LaCr.Thermo01',
                            'LaCr.Thermo02',
                            'LaCr.Thermo03',
              deviceReadings: [
                                { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
            module: 'MMM-FHEM',
            position: 'top_right',
            header: 'top_right',
              port: '8083',
              deviceNames: [
                            'LaCr.Thermo03',
                            'LaCr.Thermo04',
                            'LaCr.Thermo05',
              deviceReadings: [
      Right values should different from the bottom one.
      Any idea why? You can find the code here https://github.com/BenRoe/MMM-FHEM
        Ok other question.
        If i setup a module twice in the config, do they share the variables from the code?
          DazDavid
          Any news here?
            BenRoe Module Developer @DazDavid
            @DazDavid nope
              chrisyy
              Would it work if u give them names like MMM-FHEM1 and MMM-FHEM2?
              Cause if u add two instances with the same name in the config i can imagine, that he will read the first value and overwrites them in the second instance. Like
              var variable = 1;
              var variable = 2;
              Output would be 2.
                bobbob601
                B 1 Reply Last reply Reply Quote 3
                  BenRoe Module Developer @bobbob601
                  @bobbob601 thx for the answer. Do you have a example how to write a module with multi-instace support?
                  RedNaxR 1 Reply Last reply Reply Quote 0
                  • RedNaxR Offline
                    RedNax Module Developer @BenRoe
                    @BenRoe
                    Having the same problem with my module… A theoretical solution could be to make node_helper multi instance aware by appending some identifier to the notification unique to the instance: ie GET_WEATHER_001… The helper triggers on GET_WEATHER and builds an array with the different notifications and payloads. It then periodically runs through the array getting the appropriate requests and sending out notifications like WEATHER_001 with the specific payload.
                    Haven’t built it yet though…
                      bobbob601
                      • T Offline
                        trgraglia @bobbob601
                        @bobbob601 I got it working by passing a unique ID to the node helper and passing it back from the node helper.
                        https://github.com/trgraglia/MMM-MVG-LocalTransport
                        Hope this helps.
                        http://www.anthonygraglia.com/
