    MMM-AlarmClock
    alarm clock
    29 Posts 9 Posters 22.6k Views 10 Watching
    • cowboysdudeC
      AND it IS awesome!!! HUGE Thanks @strawberry-3-141 !!!
      • strawberry 3.141S
        Changelog:
        • alarm sound can now be a http/s stream (thanks to mjtice)
        • fixed german tanslation file
        [card:fewieden/MMM-AlarmClock]
        N 1 Reply Last reply Reply Quote 1
        • O
          omega
          hi. please can you help me .
          How to execute script test.sh wen alarme activet ?
          NM.
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @omega
            @omega this is currently not supported
            • O
              omega
              I lose I need urgent. ok tnks strawberry 3.141
              • G
                gable74
                Hello and thank you for the Module. I am trying to learn to add modules to my MM and could use some help please. I have cloned the folders in to my /modules/default directory as well as modified my config.js file but the alarm object is still not showing on the mirror. Here is my config.js file if someone could see if I have done something wrong. Thanks.
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                		module: "clock",
                		position: "top_left"
                		header: "US Holidays",
                					symbol: "calendar-check-o ",
                		module: "compliments",
                		position: "lower_third"
                		module: "currentweather",
                			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                		module: "weatherforecast",
                		header: "Weather Forecast",
                			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                    		module: 'MMM-AlarmClock',
                    		position: 'top_right',
                        			alarms: [
                            		{time: "18:30", days: [2,4], title: "Soccer", message: "Get ready for soccer training!"},
                		module: "newsfeed",
                		position: "bottom_bar",
                			feeds: [
                					title: "New York Times",
                			showSourceTitle: true,
                			showPublishDate: true
                if (typeof module !== “undefined”) {module.exports = config;}
                • strawberry 3.141S
                  strawberry 3.141 Project Sponsor Module Developer @gable74
                  @gable74 it has to be cloned in modules not modules/default
                  • G
                    gable74
                    Thank you. Sorry for the noob errors, I am trying…lol. To sound even more stupid, I also figured out you need to remove the “-Master” from the folder name as well. At least I figured that out on my own…LOL.
                    “MMM-AlarmClock”…not “MMM-AlarmClock-Master” :)
                    • strawberry 3.141S
                      @gable74 thats because you downloaded it manually
                      • strawberry 3.141S
                        v1.1.0 Changelog
                        • Volume fade in (see config options fade, fadeTimer and fadeStep). (thanks to @mjtice)
                        • French translations (thanks to Plosxh)
                        • Indonesian translations (thanks to @slametps)
                        • N
                          nobita @strawberry 3.141
                          @strawberry-3.141 , Because I adjust so big font display (in css of alert module) but the border around display alarm font not expand (It’s fix), I would like to know how to expand border?
                          Thanks for all help
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @nobita
                            @nobita the .ns-alert class makes use of a fixed with of 40% so you have to change the value of this class in the custom.css
                            • N
                              @strawberry-3.141 OK,IT work Thanks for your hint
                              • axellejamousA
                                axellejamous
                                Thank you so much for this module, it’s amazing and really easy to use!
                                I was wondering however, if I would want to let’s say set the alarm through some buttons attached to my pi, would it be best to try and inject lines into the config file (which seems sloppy to me) or can I set it through the js file directly? Or do I just make a second setnextalarm function?
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @axellejamous
                                  @axellejamous you cannot do that via the config. I suggest you to create a module which is handling your buttons and sending a SET_ALARM notification. Then you need to enhance the alarm module by listening to that notification and set the alarm accordingly.
                                  axellejamousA 1 Reply Last reply Reply Quote 1
                                  • axellejamousA
                                    axellejamous @strawberry 3.141
                                    @strawberry-3.141 I understand, that’s actually really useful thank you! Can I pass parameters with a socketnotification?
                                    • strawberry 3.141S
                                      @axellejamous yes additional data gets passed in the payload, see documentation https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#thissendnotificationnotification-payload
                                      • strawberry 3.141S
                                        I refactored the module and switched to nunjuck templates.
                                        I’m looking for people who are willing to test it:
                                        • combinations of config options
                                        • new config option popup
                                        how to test:
                                        • if not already done, clone the repository to your modules cd ~/MagicMirror/modules/ && git clone https://github.com/fewieden/MMM-AlarmClock.git
                                        • go to the module cd ~/MagicMirror/modules/MMM-AlarmClock
                                        • run git checkout develop
                                        • test various config options
                                        • N
                                          @fewieden
                                          If I would like to add repeat time again like as
                                          1st alarm alert at 8:00 am
                                          2nd alarm alert at 12:00 pm
                                          3rd alarm alart at 5:00 pm
                                          How can i config
                                          • Y
                                            yawns Moderator
                                                    alarms: [
                                                        {time: "08:30", days: [0,1,2,3,4,5,6], title: "1st Alarm", message: "This is your first alarm", sound: "alarm.mp3"},
                                                        {time: "00:00", days: [0,1,2,3,4,5,6], title: "2nd Alarm", message: "This is your second alarm", sound: "alarm.mp3"},
                                                        {time: "17:00", days: [0,1,2,3,4,5,6], title: "3rd Alarm", message: "This is your third alarm", sound: "alarm.mp3"}
                                            Currently these 3 alarms are active for all seven days of the week, where Sunday is 0 !
