    27" custom framed magic mirror - fun to get done
    41 Posts 13 Posters 76.5k Views 17 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @iwaldrum
      @iwaldrum said in 27" custom framed magic mirror - fun to get done:
      decorative molding all found at my local Home Depot. With a little bit of stain, it came out pretty nice.
      Hell yeah! I used casing from Home Depot and some stain I had on hand. And as you say, it did come out pretty nice. Love your frame! Nice work! And, oh yeah, Go Yankees! Greetings from NYC!
        disakos
        @cohron said in 27" custom framed magic mirror - fun to get done:
        sear
        Hello @iwaldrum , may you please tell us how to add stream from IP Cameras ?
        Thanks.
        I 1 Reply Last reply
        • I
          iwaldrum @disakos
          @disakos
          I’m using a program called Netcam Studio on the same pc that I’m running MM in serveronly mode. Netcam Studio allows you to connect to multiple types of cameras, either local or IP based. I’m using it to connect my q-see surveillance system using RSTP connections, as well as several Foscam and PC connected cams.
          Once the cameras are connected to netcamstudio, you can then generate a secure token based url for each one. I then took each url and placed them into a single html file and put it on a webserver (same pc). Using the iFrame module I pointed to the html file to display it on my MM. You’ll need to play with the positioning and sizing of the iframe, as well as the webpage layout and image sizes in the html.
          I typically get 5-10 fps for each camera. Depending on the # of cameras you will be displaying and the type of system your running MM on will drive the performance of the playback.
          I know the setup is a little complex, but I felt it was the best way to get a flexible, integrated look that performed the best.
          Let me know if you have any questions.
          D I 2 Replies Last reply
            disakos @iwaldrum
            @iwaldrum
            Thanks a lot for answer. I have some hikvision cameras and i’m able to reach RSTP stream of each one. Do you think that i’m able to put RSTP stream into iFrame directly ?
            I S 2 Replies Last reply
            • I
              iwaldrum @disakos
              @disakos
              The challenge is you’ll need some sort of media plugin to view the rstp stream. It will need to run at the end point - MM. Something like vlc or quicktime which I’m not sure can be done. You may be able to use something like https://ipcamlive.com to pull your rstp stream through their service.
                jasondreher
                Excellent, great job! Can you share your css file, I like the days a different color in the forecast.
                • I
                  iwaldrum @jasondreher
                  @jasondreher
                  Here is the section in my custom.css file for the MMM-WunderGround module.
                  /*	MMM-Weatherunderground     */
                  .region.top.right .MMM-WunderGround table th {
                    display: none; /* removes icons above max-temp, min-temp and % chance of rain */
                  .MMM-WunderGround .max-temp {
                    color: #f66;
                  .MMM-WunderGround .min-temp {
                    color: #0ff;
                  .MMM-WunderGround .weather-icon {
                    color: #f93;
                  .MMM-WunderGround .day {
                    color: #6f6;
                  .region.top.center .MMM-WunderGround table.small,   /* selector for ONLY current weather Thanks to Strawberry-3.141 */
                  .region.top.right .MMM-WunderGround table:not(.small),   /* selector for ONLY weather forecast */
                  .region.top.right .MMM-WunderGround table.small td:nth-child(6)  {
                    display: none;    /* this line and line above selector for NO rain amount column */
                  • cowboysdudeC
                    I’d be interested in how you hooked your security cameras to it…
                    • I
                      iwaldrum @iwaldrum
                      @cowboysdude
                      This is how I integrated my security cameras. If you have any questions or want more details let me know.
                      @disakos
                        cohron
                        I cant find the little weather icons. Temp hi and lo and the umbrella.
                        0_1492796477309_upload-210cadc3-e54f-425e-94b6-0466ae88aa00
                        C 1 Reply Last reply
                          cohron @cohron
                          @cohron nevermind im a dummy, copied the custom.css without really reading it:
                          Reply Quote 3
                            cmille34
                            This mirror looks great! It’s been the inspiration to take a stab at making one as well. I like the idea of running MM on an existing windows server I have in the house and just rely on the Pi3 to load the webpage.
                            With your mirror do you turn off the screen when no motion is detected or does it display everything constantly? If you do turn off the screen, how are you triggering it on and off? I see there are PIR modules for MM but since you’ve made the decision to simply view the MM page remotely, I was wondering if you had some way to turn off the screen?
                            Thanks for taking the time to detail this out!
                            • I
                              iwaldrum @cmille34
                              @cmille34
                              Glad I could inspire you. I do like running it centrally. Since I made this one, I’ve setup another one in my son’s room. Different size screen and content. .All I had to do is run another instance on my server - copy and paste folder and change the config file to my liking… done…
                              I do not turn my screen off. It’s on my todo list… To your point, it might be a little trick to do so since MM isn’t running locally. We’ll need to find an external solution to do so that works on fullpageOS or whatever platform you are running at the endpoint. If I find something Ill post…
                              Reply Quote 3
                              • W
                                wbleek @iwaldrum
                                @iwaldrum your project looks great! It is almost the module configuration I am also aiming for. Could you share how you integrated the surveillance cameras (iframe code)? I have trouble integrating mine. They offer rtsp and also jpegs that you can pull via http request. Which seems to be very similar to your setup. I would be interested in how you used the iframes to do it. Did you simply put the token-url in the iFrame-Module? How did you handle the refresh? Maybe you could share some code.
                                Thanks very much
                                Wolf
                                  cmille34 @wbleek
                                  @wbleek I achieved the cameras on my mirror pretty easily with Blue Iris. I simply made a custom .HTM file and placed it in the /modules directory of the MagicMirror then using iFrameReload i just call the /modules/custom.htm URL to load the cameras. Below is my custom.htm file I am calling in the iFrameReload module:
                                  <table>
                                  <tr>
                                  </tr><tr>
                                  <td>
                                  <img src="http://192.168.1.108:81/mjpg/BackyardCam/video.mjpg?q=25&amp;s=25" alt="BackyardCam" />
                                  </td>
                                  <td>
                                  <img src="http://192.168.1.108:81/mjpg/FrontDoor/video.mjpg?q=40&amp;s=40" alt="DrivewayCam" />
                                  </td>
                                  </tr>
                                  <tr>
                                  <td>
                                  <img src="http://192.168.1.108:81/mjpg/DriveWayCam/video.mjpg?q=25&amp;s=25" alt="FrontdoorCam" />
                                  </td>
                                  </tr>
                                  </table>
                                  In lieu of having blue iris you could possibly simply pull the mjpg streams straight from each cameras individually and slap them in the img tag. That may be a better way actually but it seems to be working fine for me through Blue Iris this way.
                                  Below is the code from my config.js showing how I am calling this custom HTM file:
                                  	module: 'MMM-iFrameReload',
                                  	position: 'bottom_bar', // This can be any of the regions.
                                  		url: "http://192.168.1.108:9000/modules/custom.htm",
                                  		width: "100%", // Optional. Default: 400px
                                  		height: "850px", // Optional. Default: 800px
                                  		scrolling:"no",
                                  		refreshInterval: 600, //Optional. Default: 3600 = 1 hour
                                  		animationSpeed: 4000,
                                  My setup is similar to the OP in terms of running the MagicMirror server on a central server and simply running fullpageos on the raspberry pi to call the magicmirror page.
                                  Hope this helps.
                                  W 1 Reply Last reply
                                  Reply Quote 2
                                    pepemujica
                                    Hi! Looks awesome! Congrats!
                                    Do you have any photo from the sides and/or back?
                                    • W
                                      wbleek @cmille34
                                      @cmille34 Hey, thanks for your answer. I appreciate that. My NVR only provides still JPEGs or RTSP for pictures. If I use JPEGs I have to reload them in a 200ms interval to achieve acceptable motion.
                                      At this point, I have tried the following:
                                      1. uses MMM-iFrame
                                      • do the reload via embedded HTML meta-tag
                                      • strong flickers (approx. half of the time blank)
                                      • works, but not visually accaptable
                                      • does not scale due to the flickering
                                      1. use MMM-iFrame
                                      • do the reload via embedded Java-Script function
                                      • almost no flicker, almost fluid motion
                                      • works for 30-60 minutes, then the module stops
                                      • does not scale since it stops earlier with more modules
                                      1. use oxmplayer as an overlay
                                      • needs '–avdict rtsp_transport:tcp ’ switches to work without banding
                                      • rtsp with 640x360 works with 30fps
                                      • tested to concurrent streams
                                      I am happy with the omxplayer solution even though it is not integrated in the MagicMirror. But for the user it looks integrated and it delivery a very good video quality.
                                      Cheers
                                      wolf
                                      Reply Quote 2
                                        Jayh391
                                        I would like to know how you brought your Homeseer info in?
                                        Jay
                                        • zdenekZ
                                          zdenek @iwaldrum
                                          @iwaldrum MMM-SimpleLogo - pulls updated radar image from wundergound - can u plz share details? What´s exactly in the config?
                                          thanks, Zdeněk
                                          • I
                                            iwaldrum @pepemujica
                                            @pepemujica
                                            Here are some additional pics… The back isn’t the prettiest, but it does the job. Used painters tape, L brackets and velcro to keep everything in place.
                                            0_1496222337049_IMG_1961.JPG 0_1496222343783_IMG_2065.JPG 0_1496222351990_IMG_2788.JPG 0_1496222360052_IMG_2866.JPG 0_1496222364276_IMG_2867.JPG
