    MM Nightly Reboot Needed, PM2 ?
    7 Posts 2 Posters 4.3k Views 2 Watching
      cohron
      I have a finicky wireless here and need MM to reboot nightly to stay connected, otherwise MM loses the connection and never reconnects.
      Can anyone help me set up a scheduled reboot script for my RPI? I have PM2 installed and running for auto-start but I dont see where it can reboot my RPI.
      Many thanks.
        Mykle1 Project Sponsor Module Developer @cohron
        @cohron
        Have you done this?
        Disable WiFi Power Save
        Edit /etc/modprobe.d/8192cu.conf
        sudo nano /etc/modprobe.d/8192cu.conf
        Add the following lines
        Disable power saving
        options 8192cu rtw_power_mgnt=0 rtw_enusbss=1 rtw_ips_mode=1
        For Raspberry Pi 3
        Edit /etc/network/interfaces
        sudo nano /etc/network/interfaces
        Add the following line under the wlan0 section
        wireless-power off
        Reboot your PI
        sudo reboot
        That comes straight from here:
        https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#disable-wifi-power-save
          cohron @Mykle1
          @Mykle1 I did but since i didnt have the Edit /etc/modprobe.d/8192cu.conf file, I’m running an rPI3b so I did the wireless-power off step bu it didnt seem to help or the problem is outside the raspberry.
          I just found how to do a nightly reboot using crontab.
          https://www.raspberrypi.org/forums/viewtopic.php?f=91&t=126106
            @cohron said in MM Nightly Reboot Needed, PM2 ?:
            That worked for me and I have Pi3 b as well. Glad you found the script you were looking for. Good luck!
              cohron @Mykle1
              @Mykle1 curious, did you have the /etc/modprobe.d/8192cu.conf file already or did you create it? i just created it, just in case that does the trick too.
              thanks again.
                thanks again.
                As it turns out, I do NOT have the 8192cu.conf file are all.
                pi@Pi3:/etc/modprobe.d $ ls
                fbdev-blacklist.conf ipv6.conf libpisock9.conf raspi-blacklist.conf
                However, looking at the instructions again, it says:
                For Raspberry Pi 3
                wireless-power off
                Reboot your PI
                sudo reboot
                It’s been some time since I set up my Pi but it’s obvious that I only did this portion of the instruction
                  @cohron
                  I was curious so I checked my /etc/network/interfaces file. It would appear I don’t have the edit we’re talking about, yet my wifi never drops. Here is the file:
                  interfaces(5) file used by ifup(8) and ifdown(8)
                  Please note that this file is written to be used with dhcpcd
                  For static IP, consult /etc/dhcpcd.conf and ‘man dhcpcd.conf’
                  Include files from /etc/network/interfaces.d:
                  source-directory /etc/network/interfaces.d
                  auto lo
                  iface lo inet loopback
                  iface eth0 inet dhcp
                  auto wlan0
                  allow-hotplug wlan0
                  iface wlan0 inet dhcp
                  wireless-essid XE1S3
                  wireless-key 5BBXXXXXX
