    digital photo frame
    34 Posts 15 Posters 43.1k Views 18 Watching
      schlachtkreuzer6 @Mr.Sponti
      @Mr.Sponti sounds great :) I´ll see if I can use the code (still need to get better at coding at all…) :smiley:
        roramirez Core Contributors
        I just publish another module for show images from a directory. The idea was checking process of module development.
        If anybody have ideas or new features to add please add issue into the Github.
        https://github.com/roramirez/MMM-ImagesPhotos.git
        S L 2 Replies Last reply Reply Quote 1
          schlachtkreuzer6 @roramirez
          @roramirez Super cool! thanks :)
          • L Offline
            Labzz @roramirez
            @roramirez
            Wow well done ! But if i understand the module correctly it will show pictures from the var urlApHelper = “/MMM-ImagesPhotos/photos” directory?
            Is it possible to add a feature that grab the images from dropbox or simulair?
            ~Edit: maybe a local website, or mobile application to upload pictures is earier to setup? ~
            Hope to hear you soon!
            C R 2 Replies Last reply Reply Quote 0
              chrisfoerg @Labzz
              @Labzz you can set a ln -s between your dropbox and the modules folder
                roramirez Core Contributors @Labzz
                @Labzz the /MMM-ImagesPhotos/photos is a backend endpoint for get content from upload directory used by module. You can synchronize the your DropBox folder in upload directory.
                • garblefluxG Offline
                  garbleflux Project Sponsor @Mr.Sponti
                  @Mr.Sponti
                  I’m also looking for a solution to make the mirror to a photo frame. Is it maybe
                  possible to use with your module a picture viewer like “feh”? Up to now I’m useing
                  feh to show my HD-Photos on a large TV. The best would be to have a hardwareswitch (or a voice command) to chanced between photoshow and the
                  infos an the mirror. Has anyone an idea?
                  Unfortunatelly I have no experience in programming.
                  • N Offline
                    nobita @roramirez
                    @roramirez you can change or modify your module pull photo from dropbox (replace from folder) . I mean more detail in programming for apply in mirror project v2.1
                    Thanks for your kind
                      roramirez Core Contributors @nobita
                      @nobita said in digital photo frame:
                      What? Why you dont synchronize your Dropbox folder into the upload directory of the module ?
                      If you can help this feature to pull directly from DropBox the Pull request are welcome ;)
                        soqueen
                        I am extremely interested in this as well. In fact, I just posted about this very thing elsewhere in this forum. Question- OpenFrame and Canviz (openframe is on github, canviz software you can download for free) do what I want. Is there a way to incorporate them into the same pi, or somehow use them as modules on the mm? I want to run the mm with all the info for certain parts of the day and then use it the rest of the day as a digital art display for my artist daughter’s artwork.
                          schlachtkreuzer6 @soqueen
                          @soqueen to change the modules per time, you can use this: https://github.com/ianperrin/MMM-ModuleScheduler
                            I also had the idea with the MMM-Scheduler to show for example own photos 15 Minutes und infos on the mirror for one minute. But I’m not sure if I can start for example the program “feh” from MM - as I understand the scheduler has only limited commands (MonitorOff/MonitorOn/Restart etc.). Please correct me if this wrong. I also decided to use crontab to start the photoshow-programm. I’m an absolute beginner in programming, so I didn’t see an option to run a specific programm for a specific time: Start MM at 8 am, after 5 minutes stop MM, start the photoshow for 30 minutes, stop this and start MM again for 5 Minutes … in a loop .
                            Thanks for any hints
                            • F Offline
                              fox
                              Any news here?
                              Was anyone able to use MM as photo frame? The flickr module is a simple start, but it only uses public albums and you need a flickr account.
                              Issues With MMM-WatchDog known?
                              https://forum.magicmirror.builders/post/29827
                              Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                              • F Offline
                                fabbr
                                I wanted to see something similar to this: https://dakboard.com/blog/diy-wall-display/
                                Such an amazing idea!
                                  Mykle1 Project Sponsor Module Developer @fabbr
                                  @fabbr
                                  Looks doable to me. Install a background picture or a module that does that for you and run your mirror with the other modules you want.
                                  I grabbed a picture of the lower East side of Manhattan, similar to the picture in your example, used it as a background and enabled 3 modules. Is this what you had in mind?
                                  F N 2 Replies Last reply Reply Quote -1
                                  • F Offline
                                    fabbr @Mykle1
                                    @Mykle1 YES! that looks great. Do we have module that would periodically change the background picture by grabbing it from an online service? like google photos or some place like that?
                                    K Mykle1M 2 Replies Last reply Reply Quote 0
                                    • K Offline
                                      kolbyjack @fabbr
                                      @fabbr I just made a module that can pull from Bing’s image of the day, /r/wallpapers, or /r/Verticalwallpapers: https://github.com/kolbyjack/MMM-Wallpaper/
                                        @fabbr said in digital photo frame:
                                        I don’t know. Maybe. Have a look through the 3rd party modules list.
                                        https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                                        Or better yet, fork an existing module, or create your own, and make it do what you want it to do. :-)
                                        • N Offline
                                          nobita @Mykle1
                                          What is your font-family?at Upper and Lower font,Thank so much
                                          F Mykle1M 2 Replies Last reply Reply Quote 0
                                          • F Offline
                                            fabbr @nobita
                                            @nobita This isn’t mine but @Mykle1 !
