    Two way mirror order for Europe - Orders closed!
    249 Posts 59 Posters 615.3k Views 60 Watching
      Pegasus
      Confirmed! Thx!
        SevenrockMirror
        confirmed!
          bangom
          confirmed! just need to fill the missing info :)
          G 1 Reply Last reply
          • G
            Goldjunge_Chriz @bangom
            @bangom said in Two way mirror order for Europe - Orders closed!:
            You are the only one whose entry is not complete. Please complete the entry as soon as possible. Otherwise I have to take you out unfortunately.
            B 1 Reply Last reply
              bangom @Goldjunge_Chriz
              @Goldjunge_Chriz I have no write permissions in the table, so I cant make any change. Please grant me write permissions again. I have requested permissions change 2 days ago… Thanks.
              yawnsY 1 Reply Last reply
              • yawnsY
                yawns Moderator @bangom
                I just added you manually with your gmail address you use in this forum
                  bangom @yawns
                  @yawns Thanks. I’ve added missing info. Please correct it according to current situation.
                    MyMirror
                    Confirmed! Thx!
                      MyMirror
                      Maybe the mirror of Luttich will be delivered with mine …
                      @Luttich: can you confirm this?
                      • G
                        You can add your second Mirror, no Problem. Please tell me the size ;)
                          @Goldjunge_Chriz
                          Well I can’t add new line. So my order will be:
                          1st mirror: 0,500 x 0,600 m (polished edges)
                          2nd mirror: 0,370 x 1,570 m (WITHOUT polished edges)
                          Will area to pay be sum of areas of 1st and 2nd mirror (0.8809 m2)?
                          Because of size of 2nd mirror I will pick up mirrors by myself.
                            MyMirror
                            @Goldjunge_Chriz Please add the mirror from Luttich to me. We will split the delevery costs.
                            @Luttich : Please confirm !
                            Greets MyMirror
                            • G
                              @bangom
                              1st Mirror: 0,4 m2
                              2nd Mirror: 0,58 m2
                              Sum: 0,98 m2
                              • G
                                Goldjunge_Chriz @MyMirror
                                @MyMirror said in Two way mirror order for Europe - Orders closed!:
                                Greets MyMirror
                                In this case the money must come from one account and I will treat the mirror as if it were for you. So I’ll delete luttich from the list and take the mirror under your name, you will get the bill for two Mirror.
                                Okay?
                                L 1 Reply Last reply
                                  @Goldjunge_Chriz OK. Someone with write access rights to whole table please change the data (add 2nd row).
                                  • nogEN
                                    nogE @Goldjunge_Chriz
                                    Könnte ich noch eventuell Ordern! Danke
                                    0,600
                                    0,900
                                    0,54
                                    0,54
                                    Ried im Innkreis, Austria
                                    polished edges
                                    delivery
                                    G yawnsY 2 Replies Last reply
                                    • G
                                      Goldjunge_Chriz @nogE
                                      @nogE said in Two way mirror order for Europe - Orders closed!:
                                      0,600
                                      0,900
                                      0,54
                                      0,54
                                      polished edges
                                      delivery
                                      Wenn das eine endgültige und sofortige Bestätigung ist dann ja ;)
                                      • yawnsY
                                        I added a second line. I’m at the airport about to onboard the airplane, so I’m a bit in a hurry
                                        • yawnsY
                                          yawns Moderator @nogE
                                          0,600
                                          0,900
                                          0,54
                                          0,54
                                          polished edges
                                          delivery
                                          I will add you this evening when I landed in Munich
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @yawns
                                            @yawns Have a good flight
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
