    MMM-Instagram - Pull and animate photos from Instagram feed
    87 Posts 26 Posters 120.7k Views 27 Watching
    • L Offline
      lucallmon
        BonkingElephant
        • Y Offline
          Yurick
          Hi, this is really nice module, the only problem is it doesn’t update photos from instagram. I managed to make it work properly using setInterval for grabPhotos function AND storing url in a new variable which I used in sendSocketNotification (this.url somehow works only at the first iteraction, then it overwrited by something). Since I could not find the real problem, my code looks ugly but still works. Now it takes couple minutes to display a just taken picture on a mirror.
            schnibel
            Hi all,
            Just a message to share what I did.
            I tried to find out why I wasn’t able to display my images using different MMM-Instagram modules (I tried with @kapsolas ’ initial module and yo-less’ and jeffjoe’s forks).
            It took me a lot of time to understand it wasn’t compatible with MMM-ProfileSwitcher module (https://github.com/tosti007/MMM-ProfileSwitcher)
            If ever you have the same problem, here is a workaround (done from the last JeffJoe’s fork - https://github.com/jeffjoe/MMM-Instagram, but also works with @kapsolas’ one)
            So, in MMM-Instagram.js, you just have to comment the line :
            this.info.classes = 'bright medium';
            //this.info.classes = 'bright medium';
            Indeed, it is overwriting a variable that is also used in MMM-ProfileSwitcher. (See in GitHub ProfileSwitcher description, just before the section “Current Supported Languages”. I know it’s not exactly the same thing, but the idea is the same)
            I’m not going to create a new fork for this, so guys, I let you manage this.
            BTW, yo-less’ fork is still bugged… there is a tempimpage variable instead of temp image
            Thanks for the module
            • zeularZ Offline
              zeular
              Hi, I would like to get pictures from two APIs in same module. Is it possible?
              • K Offline
                kapsolas Module Developer
                The current setup of the module does not allow for pulling from multiple locations (API)
                • zeularZ Offline
                  zeular
                  Okay, but is it possible? Anything you could implement? I would like to be able to get in family photos in chronological order. :)
                  • K Offline
                    kapsolas Module Developer @zeular
                    @zeular I suppose that this could be implemented. The module could be updated to make multiple requests to various sources.
                    Given my current availability, this would not be something I can do in the near future.
                    zeularZ 1 Reply Last reply Reply Quote 0
                    • zeularZ Offline
                      zeular @kapsolas
                      @kapsolas I understand, but if you had time over, I would be grateful.
                      Thank’s anyway, for taking your time and reply.
                      • K Offline
                        @zeular You are welcome!
                        And to be clear, when you say pull from different API, you mean different services? Like Flickr, Instagram, etc?
                        • zeularZ Offline
                          zeular @kapsolas
                          @kapsolas No, I meant two different instagram accounts …
                          • G Offline
                            Garrett
                            @kapsolas Forgive me if i’m wrong, (New Here) when you mean pulling images from your own feed, that means the images are loading from your own account correct? Anyway to pull from others users accounts? I know it states that in your Readme yet i’ve found no instructions on how that works. Basically I want it it load the “home feed” where other users posts you follow show up in. Any light in this area would be much appreciated! Thanks.
                            K 1 Reply Last reply Reply Quote 1
                            • K Offline
                              kapsolas Module Developer @Garrett
                              @Garrett Not sure if this is actually possible, but may be.
                              I would need to review the instragram API.
                              Currently, i was just interested in viewing my own photos when I wrote the module. it was more to meet my needs and then I shared it.
                              When I have some time, i’ll try to implement some of the requests folks have had.
                              zeularZ rudibaraniR 2 Replies Last reply Reply Quote 1
                              • zeularZ Offline
                                zeular @kapsolas
                                @kapsolas In my case, I have two APIs from me and my wife’s account that I want to appear, I’ve tried to “just” to add two APIs, but it wasen’t that easy…
                                I first thought Instagram “sandbox” could import other accounts flow but it does not seem so. I have added my wifes account to my “sandbox” but there is no difference.
                                • rudibaraniR Offline
                                  rudibarani Project Sponsor @kapsolas
                                  Hi @kapsolas,
                                  I think I need some help with the settings for
                                  min_timestamp: 0,
                                  Is there a way to set show only images from today and show nothing if there is no image uploaded today?
                                  Thanks for your help
                                  • K Offline
                                    kapsolas Module Developer @rudibarani
                                    @rudibarani Hi - There currently is no intelligence on the images selected. It just processes the list that is returned by the API and starts to randomly display them.
                                    What you are asking for would need to be coded.
                                    rudibaraniR 1 Reply Last reply Reply Quote 0
                                      @kapsolas Thanks for the quick reply. Another question on the side: It seems that only images are are loaded that where on Instagram before I restarted my MM. Is that intended behaviour or am I doing something wrong?
                                      			module: 'MMM-Instagram',
                                      			position: 'middle_center',
                                      			disabled: false,
                                      				access_token: '####.####',
                                      				count: 200,
                                      				min_timestamp: 0,
                                      				animationSpeed: 2500,
                                      				updateInterval: 30000
                                      I waited an hour but non of my new images showed up. Only old ones. Even create a new account with only three images before booting my MM - and it keeps cycling those three and ignores later uploads…
                                      Any idea?
                                      • Y Offline
                                        Yurick
                                        Read my post 4 months ago. I changed the code and it works fine for me. As I am a copy-paste coder, I can’t post it here for not to be damned. :) But if we ask a author to fix it using my clues it would be nice to have a working module.
                                          rudibarani Project Sponsor @Yurick
                                          Thanks @Yurick for finding the solution to the problem. Would be great to see this implemented so everyone could benefit from @kapsolas module.
                                          • K Offline
                                            The module was not loading new images. I was thinking to fix that and I have a solution i am testing.
                                            Sounds like @Yurick has a solution for this too. If he pm’s it i can test it and incorporate into the code
                                            • 4 / 5
