    Missing the weather after new installation
    8 Posts 5 Posters 4.8k Views 4 Watching
    • corsalessC Offline
      corsaless
      Hello out there!
      I have a question about the weather modul:
      I have setup following the manuals now two times the MM2 and always the weather on the right hand side is missing? I created an account @Openweathermap and looked up my city.
      Both entered in the config.js… but still no weather displayed?
      Thank you in advance for your support!
      0_1493216766152_upload-9b54a877-0495-4e31-ab6f-b8ef8d0c60fd
      Newbie… but the willingness to learn :-)
        corsaless
        Here is the full c&p from my config.js if that helps:
        (just removed the link to my private calender…)
        /* Magic Mirror Config Sample
        • MIT Licensed.
        var config = {
        port: 8080,
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses.
            language: "de",
            timeFormat: 24,
            units: "metric",
                            module: "alert",
                            module: "updatenotification",
                            position: "top_bar"
                            module: "clock",
                            position: "top_left"
                            header: "Termin Diana und Ingo",
                                                    symbol: "calendar-check-o ",
                                                    url: ""
                           module: "compliments",
                            position: "lower_third"
                            module: "currentweather",
                                    locationID: "2820465",  //ID from http://www.openweathermap.org/help/city_list.txt
                                    appid: "2d293dbaa988b5f49577db048ee2153c"
                            module: "weatherforecast",
                            header: "Weather Forecast",
                            module: "newsfeed",
                            position: "bottom_bar",
                                    feeds: [
                                                    title: "RP Online",
                                                    url: "http://www.rp-online.de/feed.rss"
                                    showSourceTitle: true,
                                    showPublishDate: true
        if (typeof module !== “undefined”) {module.exports = config;}
        D Mykle1M 2 Replies Last reply Reply Quote 0
          davidrq7 @corsaless
          @corsaless this config looks fine. Check more in modules mby somewhere there you have mistake?
          • hartattackH Offline
            hartattack
            Not sure if this will answer it, but I had to create a new API Key after I installed the first time. The first one wouldnt work, but the second one worked great!
              Mykle1 Project Sponsor Module Developer @hartattack
              @hartattack said in Missing the weather after new installation:
              His API key and his locationID are fine.
              The proof:
                Mykle1 Project Sponsor Module Developer @corsaless
                @corsaless
                However, jshint.com basically reported that your config was a mess. Rather than tell you the things that were wrong, I went ahead and fixed it for you. The only thing missing from this config now is a url for your calendar module and your API key for weather that you already have. You simply have to insert them.
                Peace!
                var config = {
                	port: 8080,
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                	language: "de",
                	timeFormat: 24,
                	units: "metric",
                                    module: "alert",
                                    position: "top_bar"
                                    module: "clock",
                                                            url: ""
                                            appid: "YOUR API KEY"
                                    module: "newsfeed",
                                            feeds: [
                                                            title: "RP Online",
                • brobergB Offline
                  broberg Project Sponsor @Mykle1
                  @Mykle1 Wrong quotations again, I’m guessing the built in word-editor in pixel is to blame here. (that automaticly change " to “ )
                    Mykle1 Project Sponsor Module Developer @broberg
                    @broberg
                    Yup, it was just easier to fix it than explain
