    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 101.6k Views 15 Watching
      A Former User
      Hi all,
      Just started my adventure with the MagicMirror, running into some problems with streaming 2 ipcams into MM.
      I installed Motioneye in the Rpi and also in the MM module.
      Both ipcams are visable when i log into Motioneye (in my case: 192.168.1.105:8765) but only a small icon appears in the MagicMirror.
      My config is:
      {                       module: 'MMM-MotionEye',
      			position: 'bottom_right',
      			url: "http://192.168.1.105:8765/motioneye/1",
      			debug: true,
      I have tried all above mentioned ideas but to no succes.
      The cams are installed in Motioneye with:
      http://192.168.1.102:88/cgi-bin/CGIStream.cgi?cmd=GetMJStream&usr=XXX&pwd=XXX
      RTSP give me an error.
      Hope someone can help me out…
        Binog
        I have that more often than I can believe. That normally means motioneye crashed,. or something. there is no connection between MM and Motioneye.
        I do the login ins my http://IP:8081 an see if it is running,. normally then MM reloads the full image.
        Give it a try!
        BTW is there a way to let motioneye run through pm2 ?
          Binog
          Change Your port in the config.js from 8765 to 8081
            A Former User @Binog
            @Binog
            Thanks, but still no succes, and would not know why it would work because i have nothing running on 8081?
            MM runs on 8080 and Motioneye runs on 8765
              Binog
              Have a look in motioneye under Videostreaming -> Streaming Port. Use that one,. with me it is 8081. and the snapshot port is 8765.
              Hopefully that helps.
                Cato Module Developer
                Seems many missunderstand the URL-parameter. This is the Streaming URL you have to find in MotionEye. It is not the URL of MagicMirror or the motion detection url you configure in MotionEye.
                As described in the README.md:
                url
                Video Streaming URL. You find it in Motion Eye in the Video Streaming Section under Usefull URLs by by clicking the Streaming URL link. It should look something like this: http://motioneye:8081 (probably an IP instead of hostname).
                Open that URL in a browser and you should get a single animated JPEG. If not, then you have found the wrong URL!
                The URL that looks like this: http://magicmirror:8080/motioneye/1 has nothing to do with what image is visible in the module. This is an triggering URL for showing the image if it’s hidden and a motion that MotionEye detects. It should be configured in MotionEye and not this module. Skip this step unless you know what you are doing…
                • W Offline
                  Woody
                  Hi all,
                  I recently installed the current MM version on the current Jessie image to use on a RPI III. Everyting fine with the standard installation. Then I installed MotionEye on top but can’t get it running. I used the same config parms then in another installation but without success. I can see only a small icon on the screen where the stream should be visible. Surprisingly i can see everything on any other system using http:Ipaddress:8080. I can also switch on/off using wget but I see only a small icon on the MM system. Nothing helpful in the logs. I’m clueless at the moment. Any help will be appreciated.
                    Cato Module Developer @Woody
                    @Woody Can you send a screenshot of Video Streaming URL in MotionEye?
                    • W Offline
                      Woody
                      @Cato Hi Cato, actually I don’t know what you really mean. The URL i use is http://userid:password@myipaddress:8081. This streaming URL works on any browser and on my other MM system. I’ve made also a shot of the icon I see on the screen if you mean that. Remember, when I’m URL to MM from any other system everything works as expected.
                        No, I want to see a screenshot of MotionEye, the section where Video Streaming URL is shown.
                        You say that “Then I installed MotionEye on top but can’t get it running”. What can’t you get running? MotionEye or MagicMirror or this module?
                        • W Offline
                          Woody
                          @cato O.K. Cato, now I understand what you mean, sorry. As mentioned, I installed a complete new MM from scratch. Everything went fine, MM’s standard modules are present, as expected. Then I installed MotionEye as described but on the screen I see only the small image as on the picture. This also disappears when I configure autohide and no motion is present. 0_1493326715516_URL.png
                          I think that’s it
                            Can you paste your config-section of this module?
                            • W Offline
                              Woody
                              @cato
                              	                  position: 'lower_third',
                              		          url: "http://userid:password@192.168.0.13:8081",
                                                        width: '800',
                                                        autoHide: 'false',
                                                        autoHideDelay: '60000',
                                                        debug: 'true'
                              for the sake of completeness, this is my trigger URL http://MMip:8080/motioneye
                              • W Offline
                                Woody
                                @cato
                                made a new installation as describek by @KirAsh4 with the same result as already mentioned but found some maybe related entries in the pm2 mm-out-0.log.
                                > magicmirror@2.1.1 start /home/pi/MagicMirror
                                > sh run-start.sh
                                Starting MagicMirror: v2.1.1
                                Loading config ...
                                Loading module helpers ...
                                Module helper loaded: MMM-MotionEye
                                All module helpers loaded.
                                Starting server op port 8080 ...
                                You're using a full whitelist configuration to allow for all IPs
                                Server started ...
                                Starting module: newsfeed
                                Connecting socket for: MMM-MotionEye
                                Starting module: MMM-MotionEye
                                Launching application.
                                Create new calendar fetcher for url: http://xxx
                                Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/tops/index.rss - Interval: 300000
                                Hiding camera: undefined
                                Motion registered: undefined
                                maybe a helpful hint ???
                                  I’m on vaccation until next week (back 8th of May) and don’t have any chance of doing any testing.
                                  Just wondering about your configuration. The values for width, autoHide, autoHideDelay and debug is not a string and you should not have the hyphen ( ’ ) around them. Not shure if it matters, but could you try to remove them?
                                  • W Offline
                                    Woody
                                    @Cato
                                    Hi, I had a bit more time over the weekend. By trial an error I found out that the problem is related to my motioneye URL string providing userid and password. Apparently the Electron browser can’t handle this. After disabling authorization in Motioneye the problem was solved. In another MM installation on a Pi Zero I use Midori as browser and this works since month without problems. Thanks for MMM-Motioneye and your help in this case.
                                      AWall
                                      • F Offline
                                        fox
                                        which camera du you suggest? I never had one. Should work for and in my garden (to observe the kids)
                                        Issues With MMM-WatchDog known?
                                        https://forum.magicmirror.builders/post/29827
                                        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                          Binog
                                          Just have a look for the noir camera. Have a look for amazon.com. There is an official cam - I think - by the raspberry company. But any other that support the onboard psi cam plug is imho better than usb cam. But that is your decision.
                                            darbos @emos
                                            @emos
                                            I had that same issue. I ended up just creating a few mmm-mogioneye module entries in the config file
                                            • 3 / 4
