    MMM-MotionEye - surveillance video stream on your mirror!
    70 Posts 15 Posters 101.0k Views 15 Watching
    • W Offline
      Woody
      Hi all,
      I recently installed the current MM version on the current Jessie image to use on a RPI III. Everyting fine with the standard installation. Then I installed MotionEye on top but can’t get it running. I used the same config parms then in another installation but without success. I can see only a small icon on the screen where the stream should be visible. Surprisingly i can see everything on any other system using http:Ipaddress:8080. I can also switch on/off using wget but I see only a small icon on the MM system. Nothing helpful in the logs. I’m clueless at the moment. Any help will be appreciated.
        Cato Module Developer @Woody
        @Woody Can you send a screenshot of Video Streaming URL in MotionEye?
        • W Offline
          Woody
          @Cato Hi Cato, actually I don’t know what you really mean. The URL i use is http://userid:password@myipaddress:8081. This streaming URL works on any browser and on my other MM system. I’ve made also a shot of the icon I see on the screen if you mean that. Remember, when I’m URL to MM from any other system everything works as expected.
            No, I want to see a screenshot of MotionEye, the section where Video Streaming URL is shown.
            You say that “Then I installed MotionEye on top but can’t get it running”. What can’t you get running? MotionEye or MagicMirror or this module?
            • W Offline
              Woody
              @cato O.K. Cato, now I understand what you mean, sorry. As mentioned, I installed a complete new MM from scratch. Everything went fine, MM’s standard modules are present, as expected. Then I installed MotionEye as described but on the screen I see only the small image as on the picture. This also disappears when I configure autohide and no motion is present. 0_1493326715516_URL.png
              I think that’s it
                Can you paste your config-section of this module?
                • W Offline
                  Woody
                  @cato
                  	                  module: 'MMM-MotionEye',
                  	                  position: 'lower_third',
                  		          url: "http://userid:password@192.168.0.13:8081",
                                            width: '800',
                                            autoHide: 'false',
                                            autoHideDelay: '60000',
                                            debug: 'true'
                  for the sake of completeness, this is my trigger URL http://MMip:8080/motioneye
                  • W Offline
                    Woody
                    @cato
                    made a new installation as describek by @KirAsh4 with the same result as already mentioned but found some maybe related entries in the pm2 mm-out-0.log.
                    > magicmirror@2.1.1 start /home/pi/MagicMirror
                    > sh run-start.sh
                    Starting MagicMirror: v2.1.1
                    Loading config ...
                    Loading module helpers ...
                    Module helper loaded: MMM-MotionEye
                    All module helpers loaded.
                    Starting server op port 8080 ...
                    You're using a full whitelist configuration to allow for all IPs
                    Server started ...
                    Starting module: newsfeed
                    Connecting socket for: MMM-MotionEye
                    Starting module: MMM-MotionEye
                    Launching application.
                    Create new calendar fetcher for url: http://xxx
                    Create new news fetcher for url: http://www.spiegel.de/schlagzeilen/tops/index.rss - Interval: 300000
                    Hiding camera: undefined
                    Motion registered: undefined
                    maybe a helpful hint ???
                      I’m on vaccation until next week (back 8th of May) and don’t have any chance of doing any testing.
                      Just wondering about your configuration. The values for width, autoHide, autoHideDelay and debug is not a string and you should not have the hyphen ( ’ ) around them. Not shure if it matters, but could you try to remove them?
                      • W Offline
                        Woody
                        @Cato
                        Hi, I had a bit more time over the weekend. By trial an error I found out that the problem is related to my motioneye URL string providing userid and password. Apparently the Electron browser can’t handle this. After disabling authorization in Motioneye the problem was solved. In another MM installation on a Pi Zero I use Midori as browser and this works since month without problems. Thanks for MMM-Motioneye and your help in this case.
                          AWall
                          • F Offline
                            fox
                            which camera du you suggest? I never had one. Should work for and in my garden (to observe the kids)
                            Issues With MMM-WatchDog known?
                            https://forum.magicmirror.builders/post/29827
                            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                              Binog
                              Just have a look for the noir camera. Have a look for amazon.com. There is an official cam - I think - by the raspberry company. But any other that support the onboard psi cam plug is imho better than usb cam. But that is your decision.
                                darbos @emos
                                @emos
                                I had that same issue. I ended up just creating a few mmm-mogioneye module entries in the config file
                                  SdeGeata @Binog
                                  @Binog
                                  Did you ever get an answer back on this one? I am having the same problem. I see everything fine without autohide active, but if I activate autohide, I see it for a bit during page load and never again after. I get detected motion emails and photo uploads so the detection isn’t the problem. It just doesn’t get fed to the mirror module somehow. Maybe my Web-hook config is off?
                                  It would be helpful to know if you fixed your issue and how you did it.
                                    Binog
                                    Hey, SdeGeata
                                    No, actually I didn’t
                                    I circumvented it by setting up a motioneyeos raspberry pi zero. As I needed the larger image on my Magicmirror I used “fast…?” option, which does not provide any of the motion activities,. what was fine to me.
                                    I do think, this is not merely a problem of motioneye, but of the MM its self.
                                    With every update of MM the Gap went bigger, I got more problems.
                                    Now, streaming the motioneyeos to two MMs it is more steady, nonetheless I do habe outages. I don’t see a picture,. although my browser directed to motioneyeos shows an actual one. Restarting MM solves that issue- normally,…
                                    Good look to You !
                                      SdeGeata @Binog
                                      @Binog
                                      Thanks for the info. I’ll keep trying stuff out and see what happens.
                                        SdeGeata @Cato
                                        @Cato
                                        So how do we use that Webhook URL to trigger the hidden module. I have been screwing with it for days trying to get it to work. Can you clarify the config for that?
                                        • O Offline
                                          OberfragGER @SdeGeata
                                          @Cato
                                          I really want to use the AutoHide feature. But the stream is fixed and always displayed. Is there any possibility…?
                                          		module: "MMM-MotionEye",
                                          		position: "bottom_left",
                                          			url: "http://pihole:8081",
                                          			autoHide: true,
                                          			autoHideDelay: "10000",
                                          			forcedRefreshInterval: 60000,
                                          			width: "400px",
                                          			debug: false
                                          • O Offline
                                            OberfragGER @OberfragGER
                                            @oberfragger
                                            ok. solved.
                                            Somehow it was working after an hour or so.
                                            Also- you have to enable access to the mirror via
                                            address: “0.0.0.0” and whitelist
                                            The the commands http://mirror:8080/motioneye and http://mirror:8080/motioneye/hide are working.
                                            • 3 / 4
