Recommended mirror specs
11 Posts 2 Posters 7.0k Views 1 Watching
    pauabaer
    Hi guys,
    do you have any recommendations for the best mirror-experience?
    I could get a mirror glas with
    transmission 3% and 4mm thickness. Or better 6mm?
    The mirror should be hanging in the corridor. Most of the time it is artificial lighted. What do you think about the specs?
    pauabaer
    B 1 Reply Last reply May 2, 2017, 6:08 PM Reply Quote 0
      broberg Project Sponsor @pauabaer
      @pauabaer 3% is to little, I know, mine is 3%. I would suggest minimum 10% light transmission.
        pauabaer
        Same place of action?
        B 1 Reply Last reply May 2, 2017, 6:52 PM Reply Quote 0
          @pauabaer one ceiling light, no windows.
          It’s visible, but not really good enough, you have to use a big text size to see it clearly.
          It works good with minimal light (i.e dark room with only monitors to light it up).
            I took a picture of the mirror running, light and dark
            Notice the thin text at the top, that’s the standard text-size of the MagicMirror.
            The clock and weather forecast are in a bolder font.
              pauabaer
              @broberg thanks for the pictures. now i have an idea of the possible result.
              how does the thickness influence the effect?
              B 1 Reply Last reply May 2, 2017, 7:09 PM Reply Quote 0
                @pauabaer the thickness does not change anything (the reflective coating is usually only applied to one side of the glass).
                  pauabaer
                  Thats obvious. Thought perhaps it has any influence. So the thinner the better because of light weight?
                  B 1 Reply Last reply May 2, 2017, 7:28 PM Reply Quote 0
                    @pauabaer yeah basically,
                    I would probably go with a thicker mirror if making a large one piece mirror. (mine is 120x60cm and 6mm thick)
                      pauabaer
                      wow. enormous weight!? :D
                      mine should be only 50x30
                      B 1 Reply Last reply May 2, 2017, 7:53 PM Reply Quote 0
