    Recommended mirror specs
    11 Posts 2 Posters 8.5k Views 1 Watching
    • brobergB Offline
      broberg Project Sponsor
      I took a picture of the mirror running, light and dark
      Notice the thin text at the top, that’s the standard text-size of the MagicMirror.
      The clock and weather forecast are in a bolder font.
        pauabaer
        @broberg thanks for the pictures. now i have an idea of the possible result.
        how does the thickness influence the effect?
        • brobergB Offline
          broberg Project Sponsor @pauabaer
          @pauabaer the thickness does not change anything (the reflective coating is usually only applied to one side of the glass).
            pauabaer
            Thats obvious. Thought perhaps it has any influence. So the thinner the better because of light weight?
            • brobergB Offline
              @pauabaer yeah basically,
              I would probably go with a thicker mirror if making a large one piece mirror. (mine is 120x60cm and 6mm thick)
                pauabaer
                wow. enormous weight!? :D
                mine should be only 50x30
                • brobergB Offline
                  @pauabaer yeah a couple of kg, but not overwhelmingly heavy :)
