    MMM-Volumio
    14 Posts 7 Posters 11.9k Views 7 Watching
    • T
      trgraglia
      Description:
      Made proof-of-concept for displaying volumio information from the web socket it exposes.
      All feedback welcome.
      Download
      [card:trgraglia/MMM-Volumio]
      http://www.anthonygraglia.com/
        BerndKohl
        Hi @trgraglia,
        just did a test-drive of your module and I was very impressed.
        Looks really cool to me.
        If you need any help let me know.
        Thinking of some improvements…
        • translations
        • configurable fields (hide certain fields returned from Volumio)
        • show cover art
        • improved CSS (possibly using icons from Font Awesome…)
        Cheers,
        T S 2 Replies Last reply
        • T
          trgraglia @BerndKohl
          @BerndKohl
          Hi Bernd,
          I honestly just wanted to see if it was possible. Some ideas:
          • Offer in the config a chance to hide/show each element
          • Offer an ordering of the info in the config
          • Offer class override in the config
          • Offer layouts in the config
          The CSS and showing album art from the provided url, etc is the easy part. The logic to make a nice configurable module is a little trickier. ;) And of course, all input, contribution, etc welcome. Fire away!
          Additionally, would be cool, using pi-gpio to allow button input on predefined pins to play/pause, advance track, adjust volume, etc… Just ideas. Time is the limiting factor.
            Chiumanfu
            I can’t seem to get this to work. It just displays “Connecting to Volumio…” in the mirror.
            Logs show this line popping up every 15 seconds or so.
            — MMM-Volumio: Socket Notification Received: MMM-VOLUMIO-SET-CONFIG
            IP for volumio is set to static 192.168.1.98. This is set correctly in the config.js.
            Thanks for any help you might be able to give.
            T 1 Reply Last reply
            • T
              trgraglia @Chiumanfu
              @Chiumanfu This is just a prrof of concept and I haven’t had any time to expand on it.
              This sounds stupid but are you playing something on Volumio? If nothing is playing, it will not get any data.
              Other than that, perhaps you can inspect the JS in your browser and see if there are any errors there. Sorry I cant offer more support right now.
              Anthony
              C 1 Reply Last reply
                Chiumanfu @trgraglia
                @trgraglia I realized my mistake. I had to add “http://” in front of the IP address in the config.js
                Thanks for your work on this module.
                • T
                  @Chiumanfu The devil is in the details. ;)
                  • L
                    Leobo
                    Hello, This MMM-Volumio modul work great whit Volumio. I have Pi Zero whit RuneAudio. Volumiourl: “http://runeaudio.local” don’t work. Is possible MMM-Volumio modifier for RuneAudio? MMM-MPD don’t work for me.
                      stacywebb @BerndKohl
                      @BerndKohl
                      @trgraglia
                      Displaying the album art is pretty simple.
                      Volumio exposes it through the websocket already, just need to add it.
                      Just add/change the following the MMM-Volumio.js file
                              item.className = 'mmm-volumio-item';
                              item.innerHTML = '<div>' + data['title'] + '<div>'
                                  + '<div>' + data['artist'] + '</div>'
                                  + '<div></br></div>'
                                  //+ '<div>' + data['title'] + '</div>'
                                  + '<div><img style="width:25%;height:25%;" src=' + data['albumart'] + '></div>';
                              wrapper.appendChild(item);
                      edit:
                      it seems the site is removing the formatting from the code
                      Here is a screen shot of the changes.
                      I would say play with the layout as it suits you. I had no need for the album title (the reason the one line is commented out).
                      My version is one the bottom bar.
                      Some screenshots:
                      and
                      You will most likely need to play around with the css to match your layout.
                      One other note if when you first load the module, if you don’t see anything playing (assuming it’s playing on Volumio), stop then start the song again. After that everything will change automatically.
                      • L
                        Leobo
                        Hi, this look very nice. My Problem is I have RuneAudio on Rpi Zero. Can someone rewrite that code for RuneAudio or MPD? I want to have that.
                        Pls.
                        • E
                          EllyJ
                          I can’t make this work. I can display the album, artist and title but not albumart.
                          I have tried the code used by @stacyweb with no luck. I have displayed the albumart url on the screen so I know I have the url. I do get an image icon on the screen. If anyone can help I would really appreciate it.
                          E 1 Reply Last reply
                          • E
                            EllyJ @EllyJ
                            @EllyJ I made it work 🙂
                              sdetweil @EllyJ
                              @EllyJ Awesome! what did u have to change?
                              • E
                                EllyJ
                                It was the url I was trying to use, it was missing the address of my Pi with the Volumio player at the beginning. Interestingly if I had been using the web radio option it would have worked and the radio stations logo would have appeared!
                                I should clean up my code now but as it is working I will leave it as is.
