    MMM-TTS
    text-to-speech
    19 Posts 4 Posters 14.8k Views 5 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @alexyak
      @alexyak still in development was working most of the time on different modules
      [card:fewieden/MMM-voice]
      A 1 Reply Last reply Reply Quote 1
        alexyak @strawberry 3.141
        @strawberry-3.141 what’s left there, what’s working and what’s not?
          voice recognition and installer are finished, but need to build the module itself
          • cowboysdudeC Offline
            You two are amazing! It’s people like you that bring this type of technology and make it reachable by far more people that just couldn’t afford to pay HUGE amounts of money to just buy a mirror that works…
            Thanks for ALL your hard work and patience with those of us who are neither py or js developers!
              alexyak @cowboysdude
              @cowboysdude thank you.
                @strawberry-3.141 I could start looking at the module for voice rec. if you don’t mind.
                  davericher @strawberry 3.141
                  @strawberry-3.141 Not to be a debbie downer, but does electron not expose Chromes built in multi voice text to speech api?
                  https://developers.google.com/web/updates/2014/01/Web-apps-that-talk-Introduction-to-the-Speech-Synthesis-API
                    strawberry 3.141 Project Sponsor Module Developer @davericher
                    @davericher should be, but that wouldn’t work for people with serveronly mode
                      @strawberry-3.141 True, but it would work for every connected client
                        @davericher if you like you can create a pr to let the user decide via config if he wants to use festival or speech synthesis :)
                          Question…this is what I"m trying to do…
                          else if (/(HIDE)/g.test(data) && /(CLOCK)/g.test(data)) {
                                    this.hide(0, {lockString: 'MMM-voice'});
                                    this.sendNotification('MMM-TTS', 'Hiding Clock');
                                  }  else if (/(SHOW)/g.test(data) && /(CLOCK)/g.test(data)) {
                                    this.show(0, {lockString: 'MMM-voice'});
                                  this.sendNotification('MMM-TTS', 'Showing clock');
                          It works buttttttttttttttt the 1st time you fire it off it doesn’t stop LOL
                          “Showing clock”…“showing clock”…“showing clock”…
                          Same for Hiding clock
                          Apparently I’m not using it correctly hahahhahhahhaha
                          SO which is the correct way?
                            strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                            @cowboysdude where did you put that code piece?
                              cowboysdude Module Developer @strawberry 3.141
                              @strawberry-3.141
                              checkCommands(data) {
                                      if (/(HELP)/g.test(data)) {
                                          if (/(CLOSE)/g.test(data) || (this.help && !/(OPEN)/g.test(data))) {
                                              this.help = false;
                                              this.interval = this.createInterval();
                                          } else if (/(OPEN)/g.test(data) || (!this.help && !/(CLOSE)/g.test(data))) {
                                              this.help = true;
                                              clearInterval(this.interval);
                                      } else if (/(HIDE)/g.test(data) && /(CLOCK)/g.test(data)) {
                                        this.hide(300, {lockString: 'MMM-voice'});
                                       //  if (this.hide){
                                       // this.sendNotification('MMM-TTS', 'Hiding Clock');
                                        this.show(300, {lockString: 'MMM-voice'});
                                      //  this.sendNotification('MMM-TTS', 'Showing clock');
                                @cowboysdude could it be that the output of tts is putting you in a loop because it is triggering the command again :D try to change the output of tts so it will not trigger any output and then see if it still occurs
                                  OK have no idea what that means but I didn’t change anything and now this is all I get…
                                  Error: SIOD ERROR: unbound variable : voice_us1_mbrola
                                  at Socket. (/home/cowboysdude/MagicMirror/modules/MMM-TTS/node_modules/say/index.js:83:14)
                                  at Socket.g (events.js:286:16)
                                  at emitOne (events.js:96:13)
                                  at Socket.emit (events.js:188:7)
                                  at readableAddChunk (_stream_readable.js:176:18)
                                  at Socket.Readable.push (_stream_readable.js:134:10)
                                  at Pipe.onread (net.js:543:20)
                                    @cowboysdude For me it sounds like the output of tts showing clock triggered the voice module to recognize the command again, so tts said showing clock again -> infinite loop
                                    Not sure what this error is
                                      Thanks!!! I got it… can’t understand the jibberish it’s saying but I think TTS didn’t install properly…
                                      FOR the record in simple form DO NOT use the same phrases in TTS that you use for sentences for voice…
                                      if anyone needs examples please let me know I’ll be happy to help.
