    Fitbit
    129 Posts 42 Posters 224.4k Views 37 Watching
      bhepler Module Developer @codyli2002hk
      @codyli2002hk You could probably put two instances of the module up on your mirror. Just copy & paste the entire module configuration. Change the position tag, clientID & clientSecret and call it good.
        daniel44992
        Hi, this module works and displays great except for the fact that the only field that is displaying values is steps. Flights, calories, etc. all show 0 values but have the images and progress bars. When I ran setupAccess.py, I made sure all the boxes were checked so that every field was being shared. After doubting whether I actually did this, I went to my Fitbit profile and confirmed that the data is being shared with the app.
        As another form of double checking my Fitbit sync, I have my Fitbit profile also linked to my Alexa and when I asked Alexa, it correctly said each of the fields that are currently zeros on the mirror display.
        Has anyone else had this issue and if so how did you fix it?
        • O
          onetwankyfive @tismepaulo
          @tismepaulo same issue for me as well
            crowbar
            Is anybody able to tell me how I would go about changing my distance from miles to kilometers? My mirror is set to metric however I believe this module has its own settings?
            • O
              Oliver_Tooth
              • O
                Oliver_Tooth
                Hi folks, i’ve installed this module and got it up and running ,but it doesn’t seem to be pulling any data. Could anyone possibly point me in the right direction on how best to fix this? Cheers.
                  bhepler Module Developer @Oliver_Tooth
                  @Oliver_Tooth For starters, I would open up the developer tools to see if there are any obvious errors when the module is attempting to load data from the Fitbit servers.
                  If you’re using an external machine to view the web application (such as Firefox, Chrome, Edge or whatever) press the F12 button. You should see the screen divide and show you what’s going on behind the scenes. Find the console tab and click on it. Look for any error messages in red and see if that helps.
                  If you’re modifying the Pi directly, add the dev switch to the start command: npm start dev. It will likewise open up the developer tools and you can see what’s going on.
                  It’s a start.
                  • O
                    Oliver_Tooth @bhepler
                    @bhepler Cheers for the pointers. I’ve looked through the dev console and I can’t see anything glaringly obvious. Weirdly however, i’ve gone onto my account section on Fitbit’s website and it doesn’t actually say that this module (app) is listed as having access to the data, despite me running through all the setup as written.
                      @Oliver_Tooth Hrm. The next step would probably be to check the NPM logs. I think they’re located at ~/MagicMirror/npm-debug.log, or possibly in the FitBit module’s directory itself.
                      It sure sounds like you’re not extracting data from the website.
                      • O
                        @bhepler Slightly embarrassing to admit i can’t find that debug file anywhere!
                          @Oliver_Tooth Well, the Wife wants her FitBit stats on the mirror so I’m going to end up using this module at some point. I’ll try and catch up to you and we’ll debug this together.
                          • O
                            @bhepler That’d be fantastic if you could! This is a 21st birthday present due in just under a weeks time, so i’m starting to panic somewhat!
                            • O
                              Oliver_Tooth @daniel44992
                              @daniel44992 I too am having this exact issue. Did you ever find a solution?
                                @Oliver_Tooth I was able to successfully install the Fitbit module and get it to pull information from the web API. It took a little tweaking, but I did get it to work.
                                Problems I encountered:
                                • Python was not installed. I had to install it and figure out how to install “pip”.
                                • Fitbit doesn’t make their developer area visible off their main website. I ended up bouncing through their forums first.
                                • Example config file on the module GitHub page contains errors. The character after config: should be {, not [.
                                • The secret key and appID field values need to be surrounded by single quotes, something not explained in the readme file.
                                Here’s the relevant portion of my config.sys file.
                                        module: 'MMM-fitbit',
                                        position: 'bottom_left',
                                                credentials: {
                                                        client_id: '000XX0',
                                                        client_secret: 'abbacadabba1234567890',
                                                resources: [
                                                        'steps',
                                                        'floors',
                                                        'caloriesOut',
                                                        'distance',
                                                        'activeMinutes',
                                                        'sleep',
                                                        'heart'
                                                update_interval: 60
                                When you run npm start the MMM-Fitbit python script will run and kick out a few lines in the console. I’m not entirely sure what it’s doing, but here’s what mine reads:
                                Set credential request recieved.
                                { client_id: '000XX0',
                                  client_secret: 'abbacadabba1234567890' }
                                Initial run request recieved.
                                Running getData.py
                                results: [{"message":"credentials.ini exists","type":"status"},{"message":"Writing credentials to credentials.ini","type":"status"},{"message":"Writing id: 000XX0 and secret: abbacadabba1234567890","type":"status"},{"message":"Credentials write successful","type":"status"}]
                                When I ran the setupAccess.py script, it failed to modify the credentials.ini file. I ended up editing it manually and plugging in my application ID and my secret key. The format is simple. Spaces before & after the = and no quotes around the ID or key.
                                V O V 3 Replies Last reply Reply Quote 1
                                • V
                                  Vendittelli Module Developer @bhepler
                                  @bhepler Please, if you spot any problems with the documentation, create a pull request on GitHub and I’ll happily make those changes.
                                  • O
                                    @bhepler That’s great news! I’ve managed to get mine up and working, but from what I can tell initially, it doesn’t seem to stay authorised for longer than a day, i’m currently browsing the python-fitbit forum for help on that. It’s also only showing data for steps, with all other fields showing 0. Is this something you’ve encountered?
                                      @Oliver_Tooth Somewhat. I see steps, distance and calories. Sleep is zero. There’s definitely something going on here. I haven’t run it long enough to encounter the authorization problem. I’ll investigate further tonight.
                                      @Vendittelli - I’ll do that. I should have a PR for you in a couple days. Thanks for the great module!
                                        s199
                                        Hello, thank you for that nice addon…i finally managed to make it work (exemple code is still incorrect on github…) but there is a problem, im using an alta hr and i only have the “steps” info on display, everything else is set to 0 :/
                                        Any idea how i can fix that ?
                                        • Sandy2503S
                                          Sandy2503
                                          The Modul wont work on my Mirror too.
                                          First:
                                          In the moment i haven`t any Fitbit Hardware. I use the Fitbit -App on my WindowsPhone. I can see in the App all useful things like step etc. and the data will sync with the Fitbit webservce.
                                          I can see all activitys an the Mirror with a Zero …
                                          When i stop the mirror with
                                          pm2 stop mm and try to start the python script setupAccess.py from the local terminal so i can see this:
                                          //your code here
                                          sudo python setupAccess.py
                                          Get credentials from credentials.ini ? (Y/N)
                                          y
                                          {"message": "credentials.ini exists", "type": "status"}
                                          {"message": "Reading from crentials.ini", "type": "status"}
                                          {"message": "Read of credentials.ini successful.", "type": "status"}
                                          [19/Sep/2017:19:30:03] ENGINE Listening for SIGHUP.
                                          [19/Sep/2017:19:30:03] ENGINE Listening for SIGTERM.
                                          [19/Sep/2017:19:30:03] ENGINE Listening for SIGUSR1.
                                          [19/Sep/2017:19:30:03] ENGINE Bus STARTING
                                          CherryPY Checker:
                                          The Application mounted at '' has an empty config.
                                          [19/Sep/2017:19:30:03] ENGINE Started monitor thread 'Autoreloader'.
                                          [19/Sep/2017:19:30:03] ENGINE Started monitor thread '_TimeoutMonitor'.
                                          [19/Sep/2017:19:30:03] ENGINE Serving on http://127.0.0.1:8080
                                          [19/Sep/2017:19:30:03] ENGINE Bus STARTED
                                          and not more - and no prompt …
                                          when i now from a second terminal the mirror restart with pm2 restart mm
                                          i see on the mirror only:
                                          //your code here
                                          ```Traceback (most recent call last):
                                            File "/usr/local/lib/python2.7/dist-packages/cherrypy/_cprequest.py", line 670, in respond
                                              response.body = self.handler()
                                            File "/usr/local/lib/python2.7/dist-packages/cherrypy/lib/encoding.py", line 217, in __call__
                                              self.body = self.oldhandler(*args, **kwargs)
                                            File "/usr/local/lib/python2.7/dist-packages/cherrypy/_cpdispatch.py", line 67, in __call__
                                              raise sys.exc_info()[1]
                                          HTTPError: (404, `Missing parameters: state`)
                                          CherryPy 3.8.2
                                          Can anyone help me to fix the problem ?
                                          Greetz Sandy2503
                                            stephenmelody @s199
                                            @s199 I also have this problem, only Steps is coming through. Did you manage to get it fixed?
                                            • 4 / 7
