    MMM-HTTPRequestDisplay
    10 Posts 5 Posters 8.3k Views 6 Watching
    • E Offline
      Eunanibus Module Developer
      Thank you :wink: - I hope it’s useful to someone. It needs some work so I’ll probably revisit it soon.
      But right now I’m working on a new module to give to everyone. And it’s even cooler :stuck_out_tongue: - I actually think a lot of people will use it.
      • cowboysdudeC Offline
        VERY nice with this I think you have solved a few issues for me! :) I wrote a module for my joomla site and was looking for a way to use it here [NFL Scoreboard] but since this will do the httprequest I can pick apart my module and use the parts with this and it should work!! Bravo!!
        HUGE Thank you!
          OH and where can I download it from? Thank you!
          • E Offline
            Download available here
            https://github.com/Eunanibus/MMM-HTTPRequestDisplay
            I need to make some fixes to the module so for right now consider it in Beta :)
            • K Offline
              Kristianson
              Great! Should solve my problems, however I seem to have issues retrieving any data :
              this is from my config:
              module: ‘MMM-HTTPRequestDisplay’,
              position: ‘top_center’,
              header: ‘Room Temp’,
              httpRequestURL: “http://192.168.1.38/guestRoomTemp.php”,
              updateInterval: 2500
              The guestRoomTemp.php output an XML file format such as this
              “< root>< roomTemp>20.00< /roomTemp>< /root>” (had to add the space in the XML output example here as the editor seemed to remove the tags)…
              are there issues calling .php files? The error I get is: HTTP Request Failed. Status 0.
              Please check the request URL in the module config.
              I can call the page and get the result from a web browser so there should be no access rights issues?
              • E Offline
                Hello guys,
                Thanks for reminding me to do this. This script has needed some work for a while now and I keep delaying it.
                There’s an issue with cross-site scripting I need to resolve (so resolving external URL’s may fail) - I also want to establish the issue with node inspections. I’m going to begin fixing these issues as soon as my exams are up (So beginning of June) - So you can expect an update then. Apologies for the inconvenience in the mean time.
                As an added bonus, I’ll be releasing a new module also :) It’s pretty cool looking and I’m looking forward to giving it to all of you.
                Thanks!
                • K Offline
                  Kristianson
                  Cool! Quick response! I might move it to the localhost then for now until new version is out :)…
                  • idoodlerI Offline
                    idoodler Module Developer @zombi27
                    @zombi27 You may wanna checkout my module MMM-Loxone:)
                    [card:idoodler/MMM-Loxone]
