    MMM-HTTPRequestDisplay
    10 Posts 5 Posters 8.2k Views 6 Watching
    • cowboysdudeC Offline
      VERY nice with this I think you have solved a few issues for me! :) I wrote a module for my joomla site and was looking for a way to use it here [NFL Scoreboard] but since this will do the httprequest I can pick apart my module and use the parts with this and it should work!! Bravo!!
      HUGE Thank you!
        OH and where can I download it from? Thank you!
        • E Offline
          Eunanibus Module Developer
          Download available here
          https://github.com/Eunanibus/MMM-HTTPRequestDisplay
          I need to make some fixes to the module so for right now consider it in Beta :)
          • K Offline
            Kristianson
            Great! Should solve my problems, however I seem to have issues retrieving any data :
            this is from my config:
            module: ‘MMM-HTTPRequestDisplay’,
            position: ‘top_center’,
            header: ‘Room Temp’,
            httpRequestURL: “http://192.168.1.38/guestRoomTemp.php”,
            updateInterval: 2500
            The guestRoomTemp.php output an XML file format such as this
            “< root>< roomTemp>20.00< /roomTemp>< /root>” (had to add the space in the XML output example here as the editor seemed to remove the tags)…
            are there issues calling .php files? The error I get is: HTTP Request Failed. Status 0.
            Please check the request URL in the module config.
            I can call the page and get the result from a web browser so there should be no access rights issues?
            • E Offline
              Hello guys,
              Thanks for reminding me to do this. This script has needed some work for a while now and I keep delaying it.
              There’s an issue with cross-site scripting I need to resolve (so resolving external URL’s may fail) - I also want to establish the issue with node inspections. I’m going to begin fixing these issues as soon as my exams are up (So beginning of June) - So you can expect an update then. Apologies for the inconvenience in the mean time.
              As an added bonus, I’ll be releasing a new module also :) It’s pretty cool looking and I’m looking forward to giving it to all of you.
              Thanks!
              • K Offline
                Kristianson
                Cool! Quick response! I might move it to the localhost then for now until new version is out :)…
                • idoodlerI Offline
                  idoodler Module Developer @zombi27
                  @zombi27 You may wanna checkout my module MMM-Loxone:)
                  [card:idoodler/MMM-Loxone]
