MMM-Voice-Control using USB Webcam Mic
10 Posts 2 Posters 5.4k Views 2 Watching
    caner
    I tried to use that module with USB webcam’s mic but didnt work. Should i do something to use webcams mic?
    M 1 Reply Last reply May 20, 2017, 12:24 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @caner
      @caner said in MMM-Voice-Control using USB Webcam Mic:
      Is your usb webcam compatible with your Pi?
      http://elinux.org/RPi_USB_Webcams
        caner
        @Mykle1 Its Microsoft Lifecam VX-3000
        M 1 Reply Last reply May 20, 2017, 1:21 PM Reply Quote 0
          It’s been quite a long time since I set up my webcam (Kodak S101) but I was able to use both the cam and the microphone after some fiddling.
          In your terminal, type: alsamixer and that will bring you to this window, where you can manipulate some of your settings by pressing F1 through F6.
          Then from your Pi desktop go to Preferences/Audio Device Settings to reach this window, where you can see more audio info. I don’t recall exactly how I got it to function properly but through process of elimination it finally worked, and is still working to this day
            caner
            @Mykle1 Ok, i bought an USB microphone. Did it default, but still module isn’t working with mic. I can record a sound and listen it.
            M 1 Reply Last reply May 20, 2017, 11:54 PM Reply Quote 0
              @caner
              I don’t use that particular module. Have you tried my suggestions above?
              C 1 Reply Last reply May 21, 2017, 12:01 AM Reply Quote 0
                caner @Mykle1
                @Mykle1
                yeap, i did it. I can record successful. Even i changed USB mic to default.
                M 1 Reply Last reply May 21, 2017, 12:05 AM Reply Quote 0
                  @caner
                  Then, hopefully, someone else that uses that module will step in here and help you out
                  C 1 Reply Last reply May 21, 2017, 12:06 AM Reply Quote 0
                    caner @Mykle1
                    @Mykle1 thanks :/
                    M 1 Reply Last reply May 21, 2017, 12:29 AM Reply Quote 0
                      @caner
                      Your audio preferences should NOT look like this, if they do.
