    MMM-MyNest
    6 Posts 4 Posters 3.6k Views 4 Watching
      This is a fork of MMM-Nest by Luke Moch, modified to look much closer to the display you see in the Nest app.
      NOTE I have not tested this with multiple thermostats, as I only have one in my house, nor have I tested the display of list mode as it defeats the purpose of why I modified this module.
      [card:jclarke0000/MMM-MyNest]
      • tidus5T Offline
        tidus5
        Hello @j-e-f-f
        Thanks for your update (looks amazing)
        is there a way to see also the ambient temperature ?
        and i just built my IR frame :D so im looking to add the touch option - is it something possible ?
        thanks
          j.e.f.f Project Sponsor Module Developer @tidus5
          @tidus5 Yeah I’ve been thinking about how I can create the same display as the Nest itself, with the ticks on the outside of the circle, the ambient temperature, the target heating .cooling temperature, etc. I plan to release an update once I figure that out.
          • mochmanM Offline
            mochman Module Developer
            @j-e-f-f Your CSS changes look great! I added them back into my module with a few tweaks to get the heat&cool mode working again. If you just want to send me pull requests instead of making a new module with cosmetic changes, I’d me more than happy to merge them.
              j.e.f.f Project Sponsor Module Developer @mochman
              @mochman hey! Great to hear you like the changes! I’ve been thinking about modifying this to have the ticks in a citcle around th outside of the widget, just like the Nest itself. But I think it will require some pretty heavy changes to the markup and subsequently to the dom generator.
              Why don’t I play around on my version of the module then when I have something working I’ll message you to figure out how easy it would be to merge the two.
              • pugslyP Offline
                pugsly
                Anyone working on integrating the nest protect smoke detectors?
