    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 564.2k Views 58 Watching
      bhepler Module Developer @j.e.f.f
      @j.e.f.f - I played around with this module months ago. I wasn’t able to get it working satisfactorily for my purposes, but I think what I learned can help.
      I don’t think the NOIR camera is necessary for your intended setup. Especially if you aren’t going to mount the camera behind the mirror itself. I do not recommend mounting the camera behind the mirror glass. I tried it and without a strong light source, I think you will just be frustrated in your results.
      Given that you’re using a 32" TV, I’m going to assume you’re locked into a portrait orientation. With little kids in the house, I suspect mounting the camera either off to one side or on the top of the frame is your best bet.
      The magic mirror concept works best when you’re fairly close to it. The best effect after all is that the mirror shows you information while you’re looking at your own reflection. This is helpful as it encourages people to come close to the mirror to marvel at it, which aids in the facial recognition. The camera has a decent field of view already. Sufficient to get a good look at a person standing in front of the mirror from arms-length to about two meters away. Beyond that, the facial recognition starts to get spotty because there isn’t enough detail in your face, but most people won’t be looking at the mirror from two meters away, right?
      I would skip the wide-angle attachments. I don’t think it’s going to be necessary.
        j.e.f.f Project Sponsor Module Developer @bhepler
        @bhepler Thanks for your insight! This helps a lot.
        • F
          FuX
          Hey
          When i run npm start in “/home/pi/MagicMirror” i am struck at below message:
          > magicmirror@2.1.1 start /home/pi/MagicMirror
          > sh run-start.sh
          Starting MagicMirror: v2.1.1
          Loading config ...
          Loading module helpers ...
          Module helper loaded: MMM-Facial-Recognition
          All module helpers loaded.
          Starting server op port 8080 ...
          Server started ...
          Connecting socket for: MMM-Facial-Recognition
          Staring module helper: MMM-Facial-Recognition
          Starting module: newsfeed
          Launching application.
          Create new news fetcher for url: http://www.20min.ch/rss/rss.tmpl?type=channel&get=4 - Interval: 300000
          [MMM-Facial-Recognition] Facerecognition started...
          [MMM-Facial-Recognition] Loading training data...
          [MMM-Facial-Recognition] ALGORITHM: LBPH
          [MMM-Facial-Recognition] Training data loaded!
          [MMM-Facial-Recognition] --------------------
          [MMM-Facial-Recognition] PiCam ausgewählt...
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "MMM-Facial-Recognition",
          			classes: "default everyone",
          				recognitionAlgorithm: 1,
          				lbphThreshold: 50,
          				fisherThreshold: 250,
          				eigenThreshold: 3000,
          				useUSBCam: false,
          				trainingFile: "modules/MMM-Facial-Recognition/training.xml",
          				interval: 2,
          				logoutDelay: 15,
          				users: ["Stefan"],
          				defaultClass: "default",
          				everyoneClass: "everyone",
          				welcomeMessage: true
          python facerecongnition.py also not work:
          pi@raspberrypi:~/MagicMirror/modules/MMM-Facial-Recognition-Tools $ python facerecognition.py
          ['Stefan']
          Using FACE_ALGORITM: 1
          Strong:Stefan
          No windowing system, writing face.jpg image
            File "facerecognition.py", line 153, in
              clean_shutdown()
          TypeError: clean_shutdown() takes exactly 2 arguments (0 given)
            So I’ve managed to get this working with a Logitech C170 USB webcam, and I’m pretty stoked!
            I have a few questions:
            • Facial recognition is generally pretty slow… I need to stand in front of the camera for about 10 seconds before I am recognized. Is this normal or a bi-product of the fact that this is a fairly low quality camera… e.g.: if I were to upgrade say to the C920 instead, should I expect better performance? I’ve left the polling setting in config.js at the default 2 seconds – if the recognition were to happen this fast I’d be pretty happy!
            • There is a reference earlier in the thread that the capture resolution can be increased by modifying the module code. Where do I modify this? The c170 can capture natively at 640x480, so I’d like to experiment with capturing both the training images and the real-time facial recognition at this resolution, in an effort to see if I can get better confidence numbers. I’m currently seeing high 40s to mid 50s confidence. At the default threshold of 50, I am often not recognized, but it works more frequently if I increase the threshold to 60. (Training is based on about 50 images all captured from the c170 in representative lighting.) EDIT: one day later and I’m now often seeing confidence in the high 60’s so I needed to increase the threshold to 70.
            • I’d like to experiment with the other recognition algorithms, but I can only get LBPH to work. If I try to use Fisher or Eigen I get an error that the training data has not yet been computed. Training.xml was generated using the appropriate algorithm, and config.js was set to the matching algorithm.
            • With MMM-Facial-Recognition-Tools module, I’m having the same issue as the previous post where I get an error when trying to run tests using facerecognition.py (same error as above). So I need to do my tests with the actual MMM-Facial-Recognition module running on MagicMirror, which as you can imagine is fairly time consuming. Anyone have any insight on getting the test script working?
            For context, I’m opting for a webcam instead of the picam because webcams generally look nicer. I’ve spent HOURS scouring the web for a picam enclosure that didn’t look like a high school engineering project, without finding a single one. The closest I could find is this one by Adafruit but it has two problems:
            • I don’t like that the cover is clear – I don’t want to see the electronics
            • I don’t like how it routes the ribbon cable
            This first point is easily remedied with a can of spray paint, but the second is a little harder to deal with. If anyone has found a nice sleek enclosure for the picam, please share a link!
            Secondly, I like that webcams generally also have a microphone built-in, so that I can also use it for voice control. I REALLY wish I could use this one but I contacted their support and they told me it wouldn’t work at all with the Raspberry Pi. Too bad… was hoping the 4-microphone array would really with not having to yell at my mirror to get it to hear me and I like how sleek it is. Would look quite unassuming sitting on top of my mirror.
            Thanks for the help
            -Jeff
              j.e.f.f Project Sponsor Module Developer @j.e.f.f
              Also one more thought: I’m thinking of turning the camera 90 degrees so that it takes a vertical image – better chance of capturing faces of people of different heights that – thinking myself as a tall adult vs my kids, 9 and 6 years old. I’m thinking a 2:3 image (or 9:16 in the case of an HD cam) would really work well here to turn a wide FoV to a “tall” FoV – perfect for people standing right in front of the mirror… If I just turn the camera 90 degrees, and use it to train and capture in that orientation, will the facial recognition algorithms work as-is (i.e.: Can they recognize a face turned sideways) or would the module need to be changed to rotate the capture first before feeding into the algorithm?
                reaper81
                I have read all posts in this thread. Is there realy no answer why the facerecognation in the testtool is so much better than in the MM-Module?
                  j.e.f.f Project Sponsor Module Developer @paviro
                  @paviro I had a hard time getting this to play nicely with modules that show and hide themselves. I created a pull-request that addresses this:
                  https://github.com/paviro/MMM-Facial-Recognition/pull/48
                  Basically I added a lockString config option to each show and hide command, and when combined with another module that also uses a lockString the particular module is only visible when both have removed their respective lock strings.
                  See here for details about visibility locking:
                  https://github.com/MichMich/MagicMirror/tree/develop/modules
                  cheers!
                    reaper81
                    hello everyone,
                    after update to the new version of the FR-Module i get this error-Massage while starting the MM.
                    Loading config …
                    Loading module helpers …
                    WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘node_helper’
                    App threw an error during load
                    at Module._resolveFilename (module.js:470:15)
                    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                    at Function.Module._load (module.js:418:25)
                    at Module.require (module.js:498:17)
                    at require (internal/module.js:20:19)
                    at Object. (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
                    at Object. (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:89:3)
                    at Module._compile (module.js:571:32)
                    at Object.Module._extensions…js (module.js:580:10)
                    at Module.load (module.js:488:32)
                    Can anybody help me?
                      @paviro I’ve switched to using the Pi cam for facial recognition, and my confidence numbers have improved significantly, but it still takes a good 5 seconds of standing absolutely still looking right at the camera to get it to work. I’ve trained the model with about 40 images of myself standing at various distances from the camera, sometimes looking right at it, other times staring blankly ahead (as if I were looking in the mirror).
                      Is 5 seconds the best I can hope for, or does it work faster for others? I have the frequency configured to interval : 1 although I don’t see much difference between 1 and 2 (or anything smaller than 1).
                      • L
                        lepetitnicolas
                        hello,
                        After a few months of sleep, I wake up my mirror
                        i’ve just update the raspberry and the MagicMirror to the last version
                        also this module (facial recognition) to see if it works better
                        but when i try to make the training.xml with train.py, i’ve this error :
                        Reading training images...
                        Assign label 1 to Gael
                        Assign label 2 to lepetitnicolas
                        OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/imgproc/src/imgwarp.cpp, line 1834
                          File "train.py", line 98, in
                            faces.append(prepare_image(filename))
                          File "train.py", line 56, in prepare_image
                            return face.resize(cv2.imread(filename, cv2.IMREAD_GRAYSCALE))
                          File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/face.py", line 100, in resize
                            interpolation=cv2.INTER_LANCZOS4)
                        cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/imgproc/src/imgwarp.cpp:1834: error: (-215) ssize.area() > 0 in function resize
                        anyone could help me ?
                        • N
                          nuckinfutz @lepetitnicolas
                          @lepetitnicolas Just saw this but here is the fix
                          cd home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools
                          sudo pip install future --upgrade
                          • E
                            EdChamberlain
                            This may not be an appropriate place but is there a good resource / tutorial for setting up / configuring the modules for the mirror? I’m specifically interested in facial recognition and the calendars - so far I only have the basic mirror installed.
                            • L
                              lepetitnicolas @nuckinfutz
                              @nuckinfutz
                              thanks, i do what you saw but i have the same error…
                                chengyuanfei
                                  mc_landin
                                  I can’t seem to get the module to work properly. I made pictures and generated a training.xml file. When I test said file it does identify me.
                                  However, I can’t find a user array in the training file to add to the config.xml. When I add the only user present it still doesn’t work
                                  • X
                                    xchribiza
                                    I have managed to make this module to work finally…BUT …
                                    I have one user (since I have just set it up) and it recognises me well etc…but it recognises other people as ME ???
                                    Why ??
                                    Is there something to be done ?
                                      mc_landin
                                      Anyone able to help me out with this? :)
                                      https://forum.magicmirror.builders/topic/4206/facial-recognition-no-users
                                        reaper81
                                        Hello everyone
                                        the class ‘everyone’, which should activate a module for every person, dont work for me. the clock-module for example stay inactive, no matter wich person is detected. The config looks like this:
                                        module: “clock”,
                                        position: “top_left”,
                                        classes: “everyone”
                                        Work this class for anyboby?
                                          j.e.f.f Project Sponsor Module Developer @reaper81
                                          @reaper81 I think you also need to include the class default as the facial recognition app spends most of its time logged out.
                                            reaper81
                                            @j.e.f.f
                                            the default-class works fine but i whould like to show modules only if a person is in the room. thats why the class “everyone” exist. Do you use it? does it work?
                                            • 10
                                            • 11
                                            • 9 / 11
