    Multiple layouts/configs
    Scheduled Pinned Locked Moved Feature Requests
    12 Posts 7 Posters 14.1k Views 6 Watching
    • VendittelliV Offline
      Vendittelli Module Developer
      As the number of cool and interesting modules grows, it’d be good to have a way to have multiple possible modules configurations. Mostly so our nice clean mirrors don’t get too cluttered! So, for instance, one could:
      • Display different modules at different times of day (e.g. travel time to work in the morning only)
      • Have a wired button (or skywriter ;)) to swap between different layouts/modules
      • Display a different layout based on face recognition
      • Be able to swap between languages globally
      • etc.
      I’m not sure how one could implement this sensibly. Maybe give modules the ability to swap between layouts, e.g. for face recognition? Doing it without having to reload modules? Can electron handle multiple tabs and do it that way? Would this increase overheads on the pi? Are these questions rhetorical?
      But anyway, certainly food for thought!
      • paviroP Offline
        paviro
        Different layouts based on facial recognition is already implemented here :slight_smile: It should be trivial to write something similar for the other use cases you just mentioned! Have a look at my code for an example.
        – The Doctor
        • MichMichM Offline
          MichMich
          The core system allows a module to switch modules based on a class. So in theory, we could simply built a module which switches modules on or off based on a time (or something else …)
          VendittelliV 1 Reply Last reply Reply Quote 2
            Vendittelli Module Developer @MichMich
            @MichMich Ah, I hadn’t even thought of that! I will look into it, probably after exams.
            • KirAsh4K Offline
              KirAsh4 Moderator
              Hand gestures anyone? :)
              MichMichM 1 Reply Last reply Reply Quote 2
              • MichMichM Offline
                MichMich @KirAsh4
                @KirAsh4 i prefer voice: “show me the traffic information” - but gestures would be awesome too. :)
                KirAsh4K 1 Reply Last reply Reply Quote 1
                • paviroP Offline
                  paviro
                  Wanted to implement that. I still have a small sensor I bought for it laying around but I am now in favor of voice commands :D
                  – The Doctor
                  • KirAsh4K Offline
                    KirAsh4 Moderator @MichMich
                    @MichMich
                    Yes voice commands would be fine too, I was thinking more in terms of ‘in addition to voice commands …’ Imagine being able to ‘wave’ things away from the screen.
                    I thought of that last night while working on the Calendar module. One thing that came to mind was, what if it displays a notification when an event is about to happen (say at 60, 30, 15 minutes prior to the event), much like the Google Calendar will send you reminders (if set).
                    At present state, there is no easy way for the user to dismiss that notification, it’s all done in the config with a semi-fixed timer. So I can display a popup and hide it after x-time. But what if the user could do that … one way is to integrate a button the user could press to acknowledge the popup … then I thought, what if they can simply ‘wave it away’ … hence hand gestures. :)
                    • zombi27Z Offline
                      zombi27
                      @KirAsh4 i thought about a touchless sensor for that :)
                      • MichMichM Offline
                        MichMich
                        https://www.leapmotion.com
                          DirkS
                          thumbs up on that! I started a new topic but discovered that here afterwards.
                          Would be the perfect solution if we can rotat the visible information on the screen with fixed rotation value, voice control, sensor or external trigger if the mirror is listening to some other devices for example! :D
                          Please keep working on that issue :D
                          • K Offline
                            kclemen
                            What about the raspberry pi skywriter (pimoroni)?
