    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 116.4k Views 39 Watching
      svonbentzel
      				        module: 'MMM-Todoist',
      				        position: 'bottom_center',  // This can be any of the regions. Best results in left or right regions.
      				        header: 'Todoist', // This is optional
      				        config: { // See 'Configuration options' for more information.
      				            accessToken: 'c7xxxxxxxxxxxxxxxxxxxxxxxe3b54',
      							//lists: ["edit in MMM-Todoist.js"],
      				            maximumEntries: 10,
      				            interval: 60,
      				            fade: true,
      this is my config.js
      you must edit the /home/pi/MagicMirror/modules/MMM-Todois/MMM-Todoist.js
      edit the list entry from list: [“inbox”] to [“1234567890”]
      defaults: {
      	maximumEntries: 10,
      	lists: ["198511455"],
      	interval: 60,
      	fade: true,
      	fadePoint: 0.25
      • T Offline
        tkotz8621
        Hi psm9… I’m fairly new to MagicMirror but I’ve been digging into the Todoist module to sort the list by due date. Did anyone ever answer your question? I didn’t see any responses to your sort question so I started digging into it and added code to the fetcher.js for MMM-Todoist.
        I’ve got it working on my mirror and when I add something that is due today… it will put it in the proper sequence on the next refresh. My JS skills are limited so the code may be made more efficient but it works. I’ll contact the Todoist author to see if I can add it to the module.
        P.S. I tried adding the code to this message but it did not take all 50 lines or so.
          cbrooker
          Hey guys,
          Very sorry that I have been MIA. I’ve been really busy with work and haven’t been able to give this any attention. I see a number of bugs and improvements in the thread. If you could submit your improvements and changes as Pull Request to the github repo, I’ll merge them in and everyone can have them. If not, I’ll try to add them in soon.
          https://github.com/cbrooker/MMM-Todoist
          Thanks,
          Chris
            Chiumanfu
            Is this module working for people? I’ve tried this one, MMM-Wunderlist and MMM-Wunderlist-Enhanced. They all behave similar. Some times they load the list, sometimes they don’t. When I add an item on my PC, it doesn’t show up in MM until reboot. I see reports of issues like this across all three modules. Since they are based on MMM-Wunderlist, maybe there is a problem in the base code?
            Here’s the log
            Create new todo fetcher for list: 2153843199 - Interval: 60000
            0|mm | Whoops! There was an uncaught exception…
            0|mm | TypeError: Cannot read property ‘substring’ of null
            0|mm | at Request._callback (/home/pi/MagicMirror/modules/MMM-Todoist/fetcher.js:69:35)
            0|mm | at Request.self.callback (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:188:22)
            0|mm | at emitTwo (events.js:106:13)
            0|mm | at Request.emit (events.js:191:7)
            0|mm | at Request. (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:1171:10)
            0|mm | at emitOne (events.js:96:13)
            0|mm | at Request.emit (events.js:188:7)
            0|mm | at IncomingMessage. (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:1091:12)
            0|mm | at Object.onceWrapper (events.js:290:19)
            0|mm | at emitNone (events.js:91:20)
            0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              Chiumanfu
              Been testing a lot and figured out if you have entries in your list that have no due date assigned, then it crashes the module. If all entries in the list have dates then it behaves well. Gonna dig into the code to see where the bug is.
                Sunburned
                So I have to be one of those… I am having the same problem guys but you guessed it, my list is showing blank.
                I have confirmed the node_modules is in the MMM-todoist folder and I updated the list number in MMM-Todoist.js. i have confirmed my access token is correct and my lists numbers are correct
                My MMM-Todoist.js is:
                Module.register("MMM-Todoist", {
                 defaults: {
                              maximumEntries: 10,
                              lists: ["my list number here"],
                              interval: 60,
                              fade: false,
                              fade point: 0.25
                My config.js is:
                             position: 'bottom_left',
                             header: 'Todoist'
                             accessToken: 'my access token here',
                                              // lists: ["edit in MMM-Todoist.js"],
                             maximumEntries: 60,
                             interval: 60,
                             fade: false
                If anyone has any thoughts i would be really appreciative. Been tearing out my 4 remaining hairs.
                M T joela85J 3 Replies Last reply Reply Quote 0
                  MasonT3 @Sunburned
                  @Sunburned What worked for me is if when adding TODOs on the app or website if you give them a due date they will then show up on the mirror, in the order that they are due from soonest to latest.
                  S T 2 Replies Last reply Reply Quote 0
                    dakipro
                    Just a tip, todoist now integrates natively with google calendar, then the “official” calendar plugin works just fine.
                    (even before todoist integrated with google, i used todoist iCal link with official calendar plugin, set manual refresh and it just works great).
                      Sunburned @MasonT3
                      @MasonT3
                      Thanks for the suggestion, saw that earlier in the thread and tried it out. No luck
                        Sunburned @dakipro
                        @dakipro
                        Is that only available to premium users?
                          dakipro
                          yeah, looks like it, didn’t think of that to be honest :(
                            Sunburned
                            General question then. Do you need a premium todoist account for this module to function? I don’t see why you would but i cant think of another explanation.
                            • T Offline
                              tkotz8621 @Sunburned
                              @Sunburned No you do not need the premium Todoist account for the module to work.
                              • T Offline
                                tkotz8621 @MasonT3
                                @MasonT3 I wrote a fix to the ‘no due date tasks’ so they will sort to the end. I think Chris Booker hasn’t had time to implement but the fix is available at my MMM-Todoist fork at: https://github.com/tkotz8105/MMM-Todoist
                                • T Offline
                                  @Sunburned I wrote a fix to the ‘no due date tasks’ so they will sort to the end. I think Chris Booker hasn’t had time to implement but the fix is available at my MMM-Todoist fork at: https://github.com/tkotz8105/MMM-Todoist
                                    Sunburned
                                    So i have tried:
                                    1. Updating the fetcher from https://github.com/tkotz8105/MMM-Todoist
                                    2. Putting my list number in the MMM-Todoist.js file rather than the config file (my list number is 10 digits btw, not an issue but i thought it was odd as all the samples had 9.)
                                    3. Changing the Access token
                                    4. Deleting and recreating the module
                                    5. Deleting my todoist account and recreating it
                                    I am currently at a loss.
                                      Sunburned
                                      So the plot thickens. I have a cron job that restarts my mirror at 2am every day. I get home from work today and my mirror shows the 2 test entries I made when setting up my new todoist account, but they will not update. So those entries will not be removed and new entries will not be added, even when restarting the mirror.
                                        Chiumanfu
                                        Do those two entries have due dates associated? Mine did some weird things until I assigned due dates to each entry… and subsequently added tkotz8105’s fetcher fix.
                                        • T Offline
                                          tkotz8621
                                          @Sunburned I find that sometimes happens as well… some changes I make (deletions, additions, mods) don’t make it to the mirror. I do not know why that is happening and have not looked in any detail on it. When you say that you restart the Mirror at 2 am… is it a system reboot? I do the same and when it all starts back up… the tasks are there and properly sorted.
                                            Sunburned
                                            Thanks for the responses everyone.
                                            Chiumanfu
                                            Yep the entries all had due dates, and I also did the fetcher fix.
                                            tkotz8621
                                            2am is a full system reboot of the raspberry pie that then restarts the mirror.
                                            • 2 / 4
