    MMM-Todoist - Your todoist tasks on your mirror
    76 Posts 37 Posters 119.8k Views 39 Watching
    • O
      onetwankyfive @shashank
      @shashank click inbox instead of today
        dakipro
        I wanted to try to fix this module, but I have found that using the .ical export from todoist works great with official calendar module, so…
          psm9
          Hi, all,
          Does anybody know how to sort this list? It adds new items at the bottom, so if there is no more room on the mirror, I can’t see them. I can’t figure out how to sort them on Todoist’s site easier, except alphabetically. I am using the “Alexa Shopping List” list in Todoist
            svonbentzel @psm9
            @psm9 said in MMM-Todoist - Your todoist tasks on your mirror:
            Hi, all,
            Hy, please can you post your working config for the Todoist module?
            My Module is starting but the Todos are blank ;-)
            Thank you
              svonbentzel
              i have figured out why the list is blank:
              in MMM-Todoist.js is the default
              Module.register("MMM-Todoist", {
               defaults: {
              	maximumEntries: 10,
              	lists: ["inbox"],
              	interval: 60,
              	fade: true,
              	fadePoint: 0.25
              maybe a result of the fork from Wunderlist.
              you can see that with pm2 logs
              0|mm       | Create new todo fetcher for list: inbox - Interval: 60000
              the added value in the config.js doesn’t accept.
              so I write the correct list in MMM-Todoist.js
               defaults: {
              	maximumEntries: 10,
              	lists: ["198511455"],
              	interval: 60,
              	fade: true,
              	fadePoint: 0.25
              save and restart MM with pm2 restart mm
              then look at pm2 logs
              |mm       | Create new todo fetcher for list: 198511455 - Interval: 60000
              tadaaaa ;-) the correct fetcher ^^
              but why the config.js variable not in use — I don’t know ;-)
              yawnsY 1 Reply Last reply
              • yawnsY
                yawns Moderator @svonbentzel
                @svonbentzel
                how does your config for this module look like?
                  svonbentzel
                  				        module: 'MMM-Todoist',
                  				        position: 'bottom_center',  // This can be any of the regions. Best results in left or right regions.
                  				        header: 'Todoist', // This is optional
                  				        config: { // See 'Configuration options' for more information.
                  				            accessToken: 'c7xxxxxxxxxxxxxxxxxxxxxxxe3b54',
                  							//lists: ["edit in MMM-Todoist.js"],
                  				            maximumEntries: 10,
                  				            interval: 60,
                  				            fade: true,
                  this is my config.js
                  you must edit the /home/pi/MagicMirror/modules/MMM-Todois/MMM-Todoist.js
                  edit the list entry from list: [“inbox”] to [“1234567890”]
                  defaults: {
                  	maximumEntries: 10,
                  	interval: 60,
                  	fade: true,
                  	fadePoint: 0.25
                  • T
                    tkotz8621
                    Hi psm9… I’m fairly new to MagicMirror but I’ve been digging into the Todoist module to sort the list by due date. Did anyone ever answer your question? I didn’t see any responses to your sort question so I started digging into it and added code to the fetcher.js for MMM-Todoist.
                    I’ve got it working on my mirror and when I add something that is due today… it will put it in the proper sequence on the next refresh. My JS skills are limited so the code may be made more efficient but it works. I’ll contact the Todoist author to see if I can add it to the module.
                    P.S. I tried adding the code to this message but it did not take all 50 lines or so.
                      cbrooker
                      Hey guys,
                      Very sorry that I have been MIA. I’ve been really busy with work and haven’t been able to give this any attention. I see a number of bugs and improvements in the thread. If you could submit your improvements and changes as Pull Request to the github repo, I’ll merge them in and everyone can have them. If not, I’ll try to add them in soon.
                      https://github.com/cbrooker/MMM-Todoist
                      Thanks,
                      Chris
                        Chiumanfu
                        Is this module working for people? I’ve tried this one, MMM-Wunderlist and MMM-Wunderlist-Enhanced. They all behave similar. Some times they load the list, sometimes they don’t. When I add an item on my PC, it doesn’t show up in MM until reboot. I see reports of issues like this across all three modules. Since they are based on MMM-Wunderlist, maybe there is a problem in the base code?
                        Here’s the log
                        Create new todo fetcher for list: 2153843199 - Interval: 60000
                        0|mm | Whoops! There was an uncaught exception…
                        0|mm | TypeError: Cannot read property ‘substring’ of null
                        0|mm | at Request._callback (/home/pi/MagicMirror/modules/MMM-Todoist/fetcher.js:69:35)
                        0|mm | at Request.self.callback (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:188:22)
                        0|mm | at emitTwo (events.js:106:13)
                        0|mm | at Request.emit (events.js:191:7)
                        0|mm | at Request. (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:1171:10)
                        0|mm | at emitOne (events.js:96:13)
                        0|mm | at Request.emit (events.js:188:7)
                        0|mm | at IncomingMessage. (/home/pi/MagicMirror/modules/MMM-Todoist/node_modules/request/request.js:1091:12)
                        0|mm | at Object.onceWrapper (events.js:290:19)
                        0|mm | at emitNone (events.js:91:20)
                        0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          Chiumanfu
                          Been testing a lot and figured out if you have entries in your list that have no due date assigned, then it crashes the module. If all entries in the list have dates then it behaves well. Gonna dig into the code to see where the bug is.
                            Sunburned
                            So I have to be one of those… I am having the same problem guys but you guessed it, my list is showing blank.
                            I have confirmed the node_modules is in the MMM-todoist folder and I updated the list number in MMM-Todoist.js. i have confirmed my access token is correct and my lists numbers are correct
                            My MMM-Todoist.js is:
                             defaults: {
                                          maximumEntries: 10,
                                          lists: ["my list number here"],
                                          interval: 60,
                                          fade: false,
                                          fade point: 0.25
                            My config.js is:
                                         position: 'bottom_left',
                                         header: 'Todoist'
                                         accessToken: 'my access token here',
                                                          // lists: ["edit in MMM-Todoist.js"],
                                         maximumEntries: 60,
                                         interval: 60,
                                         fade: false
                            If anyone has any thoughts i would be really appreciative. Been tearing out my 4 remaining hairs.
                            M T joela85J 3 Replies Last reply
                              MasonT3 @Sunburned
                              @Sunburned What worked for me is if when adding TODOs on the app or website if you give them a due date they will then show up on the mirror, in the order that they are due from soonest to latest.
                              S T 2 Replies Last reply
                                dakipro
                                Just a tip, todoist now integrates natively with google calendar, then the “official” calendar plugin works just fine.
                                (even before todoist integrated with google, i used todoist iCal link with official calendar plugin, set manual refresh and it just works great).
                                  Sunburned @MasonT3
                                  @MasonT3
                                  Thanks for the suggestion, saw that earlier in the thread and tried it out. No luck
                                    Sunburned @dakipro
                                    @dakipro
                                    Is that only available to premium users?
                                      dakipro
                                      yeah, looks like it, didn’t think of that to be honest :(
                                        Sunburned
                                        General question then. Do you need a premium todoist account for this module to function? I don’t see why you would but i cant think of another explanation.
                                        T 1 Reply Last reply
                                        • T
                                          tkotz8621 @Sunburned
                                          @Sunburned No you do not need the premium Todoist account for the module to work.
                                          • T
                                            tkotz8621 @MasonT3
                                            @MasonT3 I wrote a fix to the ‘no due date tasks’ so they will sort to the end. I think Chris Booker hasn’t had time to implement but the fix is available at my MMM-Todoist fork at: https://github.com/tkotz8105/MMM-Todoist
                                            • 2 / 4
