    MMM-KeyBindings: Control your mirror with Amazon Fire Stick Remote and Generic Keyboard Inputs
    keyboardremote controlfire stick remotebluetooth
    34 Posts 13 Posters 21.9k Views 12 Watching
      shbatm Module Developer
      @AgilesChroms By default, the Carousel module will only respond to remote control keys on the “server’s” screen. This was done so you could pull up the MM in a browser on another computer and navigate separately with a keyboard/mouse. It’s in the plan down the road for multiple remotes on different screens running from one server, but I haven’t made it that far yet.
      EDIT: I’m assuming that when you say browser, you’re talking about a browser on a different computer and not just another window on the server/RPi running MM. The suggestions below are based on that assumption.
      For now:
      First 2 corrections in your config:
      • Remove handleKeys: true, from MMM-KeyBindings, this is for adding extra keyboard keys to bind to.
      • Add "MMM-KeyBindings" to the ignoreModules list in MMM-Carousel (probably doesn’t do anything at the moment, but just future proofing).
      Next, 2 options for a fix:
      1. If you want to control the browser’s slides separately (i.e. from a keyboard attached to that computer):
        • In MMM-KeyBindings config section, add: enableMousetrap: true, which will turn on regular keyboard binding in the browser window.
        • Keyboard key presses only work when the browser is active and focused – usually have to click in the window and make sure it’s active before it will respond. I also had issues with some media keys not being sent to to browser at all-which is why I went with the evdev path in the first place.
        • Optional (and untested, but should work): If you want to use additional keyboard keys other than the standard keys, then in MMM-Carousel config section: add a duplicate entry in the keyBindings section:
          keyBindings: {
              NextSlide: "ArrowRight", // Remote Key Name
              NextSlide: "r",          // Keyboard Key Name
              PrevSlide: "ArrowLeft",  // Remote Key Name
              PrevSlide: "l"           // Keyboard Key Name
          You’ll also need to add any new “non-default” keys to MMM-KeyBindings:
          handleKeys: [ 'r', 'l' ],
      2. If you want the remote to control ALL screens: Remove the following from Line 71 in modules/MMM-Carousel/MMM-Carousel.js
         && payload.Sender === this.instance
        • This is a temporary test for now. In the future I will add a config option for the remote to control all instances or just the main screen. At the moment there is no good way to synchronize the screens when just using the Previous/Next navigation (e.g. if your main screen is on Slide 2 and you open a browser to Slide 0 and press next, both will move but one will be on Slide 3 and the other Slide 1).
      Please let me know if this helps / works – still new to MM2 and just starting development of these modules so any feedback or feature requests are more than welcome! I’m glad someone else is able to make use of the modules.
      AgilesChromsA 1 Reply Last reply Reply Quote 0
      • AgilesChromsA Offline
        AgilesChroms @shbatm
        @shbatm said in MMM-KeyBindings: Control your mirror with Amazon Fire Stick Remote and Generic Keyboard Inputs:
        keyBindings: {
        NextSlide: “ArrowRight”, // Remote Key Name
        NextSlide: “r”, // Keyboard Key Name
        PrevSlide: “ArrowLeft”, // Remote Key Name
        PrevSlide: “l” // Keyboard Key Name
        Double definition of keys does not work.
        The remote control is ignored!
        Extra buttons on the remote control are handled
        //                keyBindings: {
                            NextSlide: "k",          // Keyboard Key Name
                            PrevSlide: "j",           // Keyboard Key Name
                            Slide0:    "Return",
                            Slide1:    "Menu",
                            Slide2:    "MediaPreviousTrack",
                            Slide3:    "MediaNextTrack"
          @AgilesChroms - I’m out of town for business, so bear with me since I’m unable to fully test these suggestions.
          To use custom keyboard keys AND the remote, you can also modify the evdevKeymap and handleKeys in the MMM-KeyBindings Config. The module tries to “map” the remote’s key names to more standard keyboard key names and this can be tweaked. For example in the MMM-KeyBindings Config:
           evdevKeymap: {
               Home: "KEY_HOMEPAGE",
               Enter: "KEY_KPENTER",
               j: "KEY_LEFT",          // Change default "ArrowLeft" to "j"
               k: "KEY_RIGHT",         // Change default "ArrowRight" to "k"
               ArrowUp: "KEY_UP",
               ArrowDown: "KEY_DOWN",
               Menu: "KEY_MENU",
               MediaPlayPause: "KEY_PLAYPAUSE",
               MediaNextTrack: "KEY_FASTFORWARD",
               MediaPreviousTrack: "KEY_REWIND",
               Return: "KEY_BACK"
           handleKeys: ['j','k']       //  Add the new keys to the keyboard bindings
          In MMM-Carousel, you can now use:
           keyBindings: { NextSlide: "k", PrevSlide: "j", Slide0: "Return", ... }
          Side note:
          Something you may also find useful: the evdevKeymap tries to standardize keys, but if it receives a key that isn’t in the map, it will still pass it along. I use this to also control my Mirror via my home automation system using GET requests.
          For example: if you add a keybinding to MMM-Carousel like Slide1: "SomeSlideTitle", you can jump to that slide with a GET request to the following URL:
          http://mirror_ip:8080/MMM-KeyBindings/notify?notification=KEYPRESS&payload=%7B%22KeyState%22%3A%20%22KEY_PRESSED%22%2C%20%22Duration%22%3A%200.0%2C%20%22KeyName%22%3A%20%22SomeSlideTitle%22%7D
          // payload parameter is a url-encoded JSON string:
          {"KeyState": "KEY_PRESSED", "Duration": 0.0, "KeyName": "SomeSlideTitle"}
            @shbatm
            I am now satisfied with the behavior. The screen is now syncron with the browser
            thank you for your help
              You are welcome. Glad you made it work and happy to see someone can make use of the module!
                jchenaud
                hey thk for module !
                i try to use it but i have some problem:
                i have put that on my conf file .
                            module :  'MMM-KeyBindings' ,
                            config : {
                				enableNotifyServer : false
                i just want to use a local keyboard for now and i probably change after for remote.
                and on my module of pages organisation
                i have put your config :
                Module.register("Print_text_from_txt",{
                	curentPage: -1,
                	defaults: {
                		updateInterval:  1000,// 30 * 60 * 1000 //reads the file every 30 mins
                    /*** defaults ***
                     *   Add items below to your moduleName.js's `defaults` object
                        /*** MMM-KeyBindings STANDARD MAPPING ***/
                        /* Add the "mode" you would like to respond to */
                        keyBindingsMode: "DEFAULT",
                        keyBindings: {
                            /* Add each key you want to respond to in the form:
                             *      yourKeyName: "KeyName_from_MMM-KeyBindings"
                            Right: "ArrowRight",
                            Left: "ArrowLeft",
                	start: function(){
                		this.setupKeyBindings(); //key binding test
                		this.sendSocketNotification("START", this.config);
                notificationReceived: function(notification, payload){
                		if (this.validateKeyPress(notification, payload)) { return; }
                		if (notification === "PAGE_NUMBER_IS")
                			this.curentPage = payload
                			this.sendNotification("PAGE_CHANGED", this.curentPage);
                i have clone directory on my module folder.
                i have one error on console but she not cause by the module
                TypeError: Failed to execute 'appendChild' on 'Node': parameter 1 is not of type 'Node'.
                    at updateModuleContent (main.js:206)
                    at main.js:139
                    at new Promise (<anonymous>)
                    at updateDomWithContent (main.js:137)
                    at main.js:119
                    at <anonymous>
                i have probably miss something but i dont find :(
                i haven’t notification on console
                sorry for my bad language
                and thanks for your help
                edit:
                i have miss on Line on config file
                but notification is not hear and probably never send :(
                  jchenaud
                  hey i remake all process but nothing new . i am alone in this case ?
                  just my log when all looks ok
                   MagicMirror git:(master) ✗ npm start
                  > magicmirror@2.4.1 start /home/pi/MagicMirror
                  > sh run-start.sh
                  Starting MagicMirror: v2.4.1
                  Loading config ...
                  Loading module helpers ...
                  No helper found for module: MMM-EyeCandy.
                  Module helper loaded: Print_text_from_txt
                  Module helper loaded: MMM-kalliope
                  Module helper loaded: MMM-KeyBindings
                  No helper found for module: MMM-pages.
                  All module helpers loaded.
                  Server started ...
                  Starting module: newsfeed
                  Connecting socket for: Print_text_from_txt
                  Starting module helper: Print_text_from_txt
                  Connecting socket for: MMM-kalliope
                  MMM-kalliope is started
                  Connecting socket for: MMM-KeyBindings
                  MMM-KeyBindings helper has started...
                  Launching application.
                  Create new news fetcher for url: https://www.tdg.ch/rss_ticker.html - Interval: 300000
                  MMM-kalliope received a socket notification: CONNECT - Payload: null
                    rak
                    Hello guys,
                    I cant get the remote connected to the R3B+. I stuck. Searching the web like cracy since yetserday evening with no result.
                    It seems the pairing fails bc of the message “ServicesResolved: no”
                    Any clue whats missing?
                    $ sudo bluetoothctl
                    [NEW] Controller B8:27:EB:DF:FF:D1 raspberrypi [default]
                    [bluetooth]# agent on
                    Agent registered
                    [bluetooth]# scan on
                    Discovery started
                    [CHG] Controller B8:27:EB:DF:FF:D1 Discovering: yes
                    [NEW] Device C4:95:00:6F:19:8A Amazon Fire TV Remote
                    [CHG] Device C4:95:00:6F:19:8A RSSI: -66
                    [CHG] Device C4:95:00:6F:19:8A RSSI: -74
                    [CHG] Device C4:95:00:6F:19:8A RSSI: -62
                    [bluetooth]# scan off
                    Discovery stopped
                    [bluetooth]# pair C4:95:00:6F:19:8A
                    Attempting to pair with C4:95:00:6F:19:8A
                    [CHG] Device C4:95:00:6F:19:8A Connected: yes
                    Request confirmation
                    [agent] Confirm passkey 301420 (yes/no): yes
                    [CHG] Device C4:95:00:6F:19:8A Modalias: usb:v1949p0410d0304
                    [CHG] Device C4:95:00:6F:19:8A UUIDs: 00001101-0000-1000-8000-00805f9b34fb
                    [CHG] Device C4:95:00:6F:19:8A UUIDs: 00001124-0000-1000-8000-00805f9b34fb
                    [CHG] Device C4:95:00:6F:19:8A UUIDs: 00001200-0000-1000-8000-00805f9b34fb
                    [CHG] Device C4:95:00:6F:19:8A ServicesResolved: yes
                    [CHG] Device C4:95:00:6F:19:8A Paired: yes
                    Pairing successful
                    [CHG] Device C4:95:00:6F:19:8A ServicesResolved: no     <<<<< THIS sounds strange to me
                    [CHG] Device C4:95:00:6F:19:8A Connected: no
                    [bluetooth]# trust C4:95:00:6F:19:8A
                    [CHG] Device C4:95:00:6F:19:8A Trusted: yes
                    Changing C4:95:00:6F:19:8A trust succeeded
                    [bluetooth]# devices
                    Device 4F:8A:AE:69:E9:71 4F-8A-AE-69-E9-71
                    Device 6A:79:D3:6A:17:13 6A-79-D3-6A-17-13
                    Device 61:A4:04:D0:5D:66 61-A4-04-D0-5D-66
                    Device 6E:91:C7:B3:7A:C8 6E-91-C7-B3-7A-C8
                    Failed to pair: org.bluez.Error.AlreadyExists
                    [bluetooth]# conntect C4:95:00:6F:19:8A
                    Invalid command
                    [bluetooth]# connect C4:95:00:6F:19:8A
                    Attempting to connect to C4:95:00:6F:19:8A
                    Failed to connect: org.bluez.Error.Failed
                    [bluetooth]#
                      @rak Have you tried pairing the remote using the Bluetooth menu/GUI on the desktop?
                        @jchenaud I am away right now and will take a closer look at your issue when I am back in town.
                        • 1 / 4
