    Config.js file Syntax
    26 Posts 7 Posters 29.8k Views 6 Watching
    • L Offline
      letsirk @amosh83
      @amosh83 Did you post the exact config.js file. If so you’re missing a “/” on the first line.
      A 1 Reply Last reply Reply Quote 1
        amosh83 @letsirk
        @letsirk YES!!!
        I MADE IT!!! turns out that all I was missing was that “/”, are you kidding me??? ahahah
        I’m so thankful to ALL of you, I’ve never touched a Terminal in my life and I managed to do this with manual installation all thanks to you geniuses!!!
        Thank you
        @Mykle1 @bhepler @letsirk
          Mykle1 Project Sponsor Module Developer @amosh83
          @amosh83 said in Config.js file Syntax:
          Ahh, you missed when you copied and pasted. That’s fairly common.
          Now where have I heard this before? Oh yeah, I said it!
          Enjoy your mirror
          • jadeJ Offline
            jade
            I’m having this exact problem, but I’ve used a linter to check for errors and there are none, and my file is in /var/www/html/MagicMirror/config/config.js, I have no idea what I’m doing wrong!
              Mykle1 Project Sponsor Module Developer @jade
              @jade said in Config.js file Syntax:
              Your installation of MM belongs as follows, and so the path to your config.js file
              pi@raspberry ~/MagicMirror/config/config.js
              Then we can work on your config.js if need be
              strawberry 3.141S jadeJ 2 Replies Last reply Reply Quote 0
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Mykle1
                @Mykle1 not necessarily, you can install the mirror in every directory you like
                  Anhalter42 @strawberry 3.141
                  @strawberry-3.141 … except for directories with different read/write permissions. Not a linux expert, but I guess this includes /var/ in its default status!?
                    I was referring to this forums very own “Complete Setup Tutorial.” Specifically, this:
                    https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
                    I guess I shouldn’t assume that everyone follows the installation procedure.
                    • jadeJ Offline
                      jade @Mykle1
                      @Mykle1 said in Config.js file Syntax:
                      When I first started using Linux I was taught the very bad habit of switching to the root user and doing everything as root, so I moved the file into where it needs to be in /home/pi but I still have the same problem
                      var config = {
                          port: 8080,
                          ipWhitelist: [],
                          language: "en",
                          timeFormat: 24,
                          units: "metric",
                                  module: "clock",
                                  position: "top_left"
                                  header: "CWG  Pi",
                                              symbol: "calendar-check-o ",
                                              url: "https://calendar.google.com/calendar/ical/cwgpi2017%40gmail.com/private-b287e4ebe0e8f5d66665e0c83f9e3fa0/basic.ics"
                                  module: "compliments",
                                  position: "lower_third",
                                  updateInterval: 3600000,
                                      compliments: {
                                          morning: [
                                              "Valar Morghulis",
                                              "Valar Dohaeris",
                                              "When You Play The Game Of Thrones You Win Or You Die",
                                              "Where Is The God Of Tits And Wine?"
                                          afternoon: [
                                              "Sometimes, Those With The Most Power Have The Least Grace",
                                              "A Mind Needs Books Like A Sword Needs A Whetstone",
                                              "Chaos Isn't A Pit, Chaos Is A Ladder",
                                              "A Lion Doesn't Concern Himself With The Opinions Of Sheep"
                                          evening: [
                                              "The Night Is Dark And Full Of Terrors",
                                              "Night Gathers And Now My Watch Begins",
                                              "Winter Is Coming",
                                              "Power Resides Where Men Believe It Resides. It's A Trick, A Shadow On The Wall, And A Very Small Man Can Cast A Very Large Shadow"
                                  module: "currentweather",
                                      locationID: "2652381",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      appid: "39ab36a3fa513354fbe406263f175c07"
                      Everything is ok according to jslint but something has got to be not working. Incidentally if I use the sample file and don’t change anything I have the same problem.
                        Again, I hate to refer to the Complete Setup Tutorial but item #7 of Notes at the very beginning of the tutorial states:
                        "DO NOT INSTALL MagicMirror² as the root user! Always do it as the regular, non privileged pi user"
                        With that said, your config is not the problem. I just tested it and it fired right up.
                        Unless, it’s not named correctly (config.js) or MM can’t find it at its proper path
                        jadeJ 1 Reply Last reply Reply Quote 0
                        • jadeJ Offline
                          jade @Mykle1
                          @Mykle1 I’m wondering if the problem was actually that I was using a Pi 0, I’m testing now on a Pi 2 and I’ve run the automatic installer, though it is now just sitting doing absolutely nothing, the last thing it said is:
                          >node-gyp rebuild > build_log.txt 2>&1 || exit 0
                          And now it’s just sitting there. It hasn’t bought the prompt back up yet so maybe I’m being impatient.
                            Anhalter42 @jade
                            @jade several people were struggling with PI0 IIRC. Search the forum (for example start here).
                            • jadeJ Offline
                              jade @Anhalter42
                              @Anhalter42 I’ve got it mostly up and running on Pi 2 now, my only issue now is it’s loading a black screen with no info, the terminal says launching application and then access denied to IP address 0.0.0.0/0 I have no idea what’s going on now!
                              • jadeJ Offline
                                jade @Anhalter42
                                @Anhalter42 Ok, it’s all good, I just took the ipWhitelist section from the sample pasted it in and now I have a working mirror that sporadically gives me game of thrones quotes! My office at work is now much brighter!
                                  bhepler Module Developer @jade
                                  Well, you do until he kills off another Stark child.
