    MagicMirror Weather
    10 Posts 4 Posters 7.3k Views 4 Watching
    • U Offline
      Usrnme2Lng
      Good Evening,
      I looked through a couple of other posts and I am still having trouble getting the weather to display at all in the top right corner. There isn’t any message saying that my APPID isn’t valid or whatever. I followed the Complete Guide, found here: link text. Very nice job by @KirAsh4 !!
      At the end of the guide, there’s a quick note about the weather app, but I can’t seem to get it to work. I created an account at the openweathermap.org site but not sure where to go from there.
      Any advice would be much appreciated. For what it’s worth, I am very new to this type of computer magic, so a detailed instruction would be fantastic.
      Lastly, is there a way to edit the code to remove the compliments that the screen says (i.e., “You look nice!”)? I know it’s lying and I don’t want to see it.
      Thank you!!
      Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @Usrnme2Lng
        @Usrnme2Lng
        Paste the config entry for your weather here using this guide and I’ll take a look at it for you.
        https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
        It should look something like this:
        		module: "currentweather",
        			locationID: "LOCATION ID GOES HERE",     //Location ID from http://openweathermap.org/help/city_list.txt
        			appid: "YOUR API KEY GOES HERE"             //openweathermap.org API key.
        There are more options you can add. See the readme file of the module, but for now lets just get you up and running
        U 1 Reply Last reply Reply Quote 3
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Usrnme2Lng
          @Usrnme2Lng in your config.js file is a section like:
              module: "compliments",
              position: "lower_third"
          just remove that part and it will be gone
          U 1 Reply Last reply Reply Quote 1
          • U Offline
            Usrnme2Lng @Mykle1
            @Mykle1 I think I made a mistake by putting similar code in the wrong file I put it into the other config file by doing ‘sudo nano /boot/config.txt’
            How to I get to the config file you’re talking about?
            • cowboysdudeC Offline
              cowboysdude Module Developer @Usrnme2Lng
              @Usrnme2Lng said in MagicMirror Weather:
              I would in a terminal window go to:
              ~MagicMirror/config
              type: cp config.js.sample config.js
              That will give you your config file.
              Then you can sudo nano config.js and enter the weather info.
                OR
                My suggestion, because it helped me, is, don’t do your editing in the terminal. Do it in the graphical user interface (GUI). Navigate your desktop as you would on a PC with Windows or a Mac’s Finder.
                Click on File Manager (the folder at the top left of your desktop, usually)
                Double click the MagicMirror folder
                Double click the config folder
                Right click the config.js.sample file - select Copy
                Right click again somewhere else in that same window - select Paste
                Rename the file you just pasted to config.js and click the Rename button
                The new config.js file that you just pasted is now your working config file for MagicMirror
                Double click it and it should open in a text editor.
                This is one of the places where you will customize your MM. It’s actually good enough to run your MM, although it will only show some of the modules but you’ll be encouraged by the fact that it is at least working. Every module folder has a ReadMe file that instructs you on what to add to your config.js file to get that module up and running.
                • U Offline
                  Usrnme2Lng @strawberry 3.141
                  @strawberry-3.141 Thank you!! That worked!
                  • U Offline
                    Usrnme2Lng @Mykle1
                    @Mykle1 Thanks! This helped a lot. I am trying to get more comfortable with the terminal, but I think that in this case, it was best to use a text editor.
                    Also, I followed the instructions in the guide but for some reason, my screen is still going blank.
                    I edited the autostart file, as below:
                    sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
                    @xset s noblank
                    @xset s off
                    @xset -dpms
                    I also edited the lightdm.conf file, as seen below:
                    sudo nano /etc/lightdm/lightdm.conf
                    I edited the xserver-command bit to look like this:
                    xserver-command=X -s 0 -dpms
                    Any ideas of what I can do next? For what it’s worth, it is a flatscreen TV, so it has a remote and I also tried going through the settings and made sure that sleep mode was off.
                      @Usrnme2Lng Install xscreensaver and save yourself a lot of time and headache…
                      Install it on the pi then disable screensaver… easiest way to do it.
                      https://www.linuxbabe.com/ubuntu/install-autostart-xscreensaver-ubuntu-16-04-16-10
                      • U Offline
                        Usrnme2Lng @cowboysdude
                        @cowboysdude Thank you! That seems to have fixed the issue!
