    MMM-DHT-Sensor - Get temperature & humidity values from a DHT sensor
    22 Posts 9 Posters 17.8k Views 9 Watching
      ryck Module Developer
      Description:
      This week I got a DHT22 because I saw several MMM around here to get the temp/humidity, but none of them worked for me, so… I created my own.
      The module just reads the temperature / humidity values from the sensor and displays them in a MMM module.
      Screenshots:
      MMM-DHT-Sensor
      Download:
      [card:ryck/MMM-DHT-Sensor]
      MMM-DHT-Sensor
      • cowboysdudeC Offline
        Sometimes you just gotta make your own stuff ;)
        Great job!! :)
          Version 1.1.0
          • Use config.units to set the sensor temperature units
          • Implements INDOOR_TEMPERATURE and INDOOR_HUMIDITY notifications so you can use showIndoorTemperature
            indoor temperature
            Dracarys
            i get te notification that there is a new Version available. But if i go to ~/MagicMirror/modules/MMM-DHT-Sensor and do ‘git pull’ it says that the module is already up-to-date. What should i do?
            Cheers
              PaulB
              Cool module,
              i would like to know whether you have an idea to my following problem:
              I did everything as recommended. Unfortunately the module is not shown on the screen.
              I checked everything as well as if the DHT22 works.
              Everything runs fine, unfortunately :D
                ryck Module Developer @Dracarys
                @Dracarys I am not seeing any update notification at all… Do you still have the issue?
                  ryck Module Developer @PaulB
                  @PaulB Did you follow all the steps? Without logs is a little bit difficult to know what’s going on… Did you try to check if the sensor is working (like with a python script or something). It sound like a config.js issue…
                    PaulB
                    @ryck
                    Thanks for your quick reply :
                    I have checked the config file as well as the set up. Checking the sensor via the console works fine.
                    My next steps are deleting the module and downloading it again. Following step by step your manual.
                    I keep you updated :)
                      PaulB
                      @ryck
                      I delete everything and set it up from scratch again.
                      Unfortunately, as I start the MMM application your module is not shown on the screen. Do you have an idea where the problem is located?
                      I used your config.js-example and just changed the Pinnumber from 2 to 4.
                      Kind regards,
                      Paul
                      • O Offline
                        Ogret
                        @ryck
                        Thanks for the great works.
                        It’s possible to change the icons color of the temp and humidity?
                        Thanks for help.
                        BR
                        • O Offline
                          Ogret @Ogret
                          @ryck
                          It’s done.
                            ryck Module Developer @Ogret
                            @Ogret Sorry, I don’t have access to the mirror here, so I was waiting to get home today to reply to you. It’s just adding some code in the custom.css file with the right class, but seems like you already found how to do it!
                            Cheers,
                              PaulB
                              Dear @ryck,
                              I have installed your module and it works up to the point, where it shows me that “no data is returned”.
                              I guess that my wiring is wrong.
                              What do you think?
                                @PaulB Hi Paul
                                That happens sometime, it’s related to the way the raspberry pulls data from the sensor, but it should be OK on the next try. Just in case, put a quick updateInterval (like 1 * 60 *1000) and see what happens…
                                Also, you can try to get a read directly from the sensor, bypassing the MagicMirror. Just clone this (https://github.com/adafruit/Adafruit_Python_DHT) somewhere and edit and execute this (https://github.com/adafruit/Adafruit_Python_DHT/blob/master/examples/simpletest.py), ie, `python simpletest.py
                                Good luck!
                                  PaulB
                                  @ryck
                                  Thank you for your help! :)
                                  Finally it works now.
                                  By the way… the module looks pretty cool ;-)
                                    @PaulB Thank you!
                                    • W Offline
                                      weeee99
                                      ive managed to install the module however the reading show 0 degress and 0% humidity im using a DHT22 btw is this a hardware problem or what? the sensor’s pin 1(Vcc) and pin 4(GND) is connected to a external 3.3v powersouce meaning the pin 2(data) together with a 10k ohms resistor connected in pin 1 and 2 is the only pin connected to the PIs GPIO0_1517635952159_Screenshot (282).png
                                        PaulB
                                        @weee99,
                                        It looks like the module is working, so it has to be a problem with your pins.
                                        I would recommend to try it this way:
                                          ryck Module Developer @weeee99
                                          @weeee99 Seems like the module is working… Have you tried to access the sensor directly? Look my previous post in this thread to know how to do it. Make sure that the pin in the correct one (GPIO and physical pins are not the same, so it can be a little bit confusing). Finally, the one I got (https://www.amazon.co.uk/gp/product/B01N6PB489/ref=oh_aui_search_detailpage?ie=UTF8&psc=1) is plug directly to the Pi, no breadboard / resistance required…
                                            Mo
                                            Hello ryck,
                                            I have a problem with using your module.
                                            When starting MagicMirror the module sometimes stays on “Recieving Sensor Data…” and doesnt actually read the sensor. In rare cases it works, but only once. The module doesnt read the temperature and humidity again and won’t update. I’ve already tried different Update intervals and delaying the initial load time.
                                            I’m having this problem since the last update of module. Any ideas?
                                            1 Reply Last reply Reply Quote -1
