How to stop Magic Mirror *NOOB*
Press the
Alt
key. This drops down a menu at the top. You won’t see your mouse cursor until you move it into the menu bar. TheFile
menu allows you to Quit the mirror. Check the other menus for other options -
When I try and close it doing that it reopens a couple of seconds after
You’re running PM2? That would relaunch the mirror. Instead of Quitting the mirror, you can
Minimize
it via one of the other menus. Then typepm2 stop mm
in your terminal. That will stop the mirror from relaunching -
ok yeah it was running in pm2 (I just ran magic mirror for the first time after install and I chose yes for that option) Now how would I start it in pm2?
pm2 start mm? -
yes sir
when i do
pm2 start mm
it says: script not found
I should already have a script though as it worked on startup, where would that script be if I have it already? -
If you shut your Pi down and turn it back on, does the mirror launch automatically?
@Mykle1 no it does not launch automatically
Then I believe you may not have saved the
state
of PM2 on installation.https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
