How to stop Magic Mirror *NOOB*
14 Posts 2 Posters 37.1k Views 3 Watching
    Adaman134
    Sorry about this dumb question but, how would I stop the magic mirror app? I have tried pressing ctrl + w and that only does some sort of refreshing thing to the app.
    Would anyone be able to help me with this?
    If you need more information let me know.
    Thanks,
    Adam
    M 1 Reply Last reply Jul 24, 2017, 1:07 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @Adaman134
      @Adaman134
      Press the Alt key. This drops down a menu at the top. You won’t see your mouse cursor until you move it into the menu bar. The File menu allows you to Quit the mirror. Check the other menus for other options
        Adaman134
        When I try and close it doing that it reopens a couple of seconds after
        M 1 Reply Last reply Jul 24, 2017, 1:47 AM Reply Quote 0
          @Adaman134
          You’re running PM2? That would relaunch the mirror. Instead of Quitting the mirror, you can Minimize it via one of the other menus. Then type pm2 stop mm in your terminal. That will stop the mirror from relaunching
            Adaman134
            ok yeah it was running in pm2 (I just ran magic mirror for the first time after install and I chose yes for that option) Now how would I start it in pm2?
            pm2 start mm?
            M 1 Reply Last reply Jul 24, 2017, 2:56 AM Reply Quote 1
              @Adaman134
              yes sir
              A 1 Reply Last reply Jul 24, 2017, 3:26 AM Reply Quote 1
                Adaman134
                when i do
                pm2 start mm
                it says: script not found
                I should already have a script though as it worked on startup, where would that script be if I have it already?
                  Adaman134 @Mykle1
                  @Mykle1 ok So I found that my mm.sh was in the installers folder and that works now but when I do pm2 start mm I get an error on run-start.
                  MM opens up and everything but is there a reason why I get an error for that?
                  Thanks,
                  Adam
                  M 1 Reply Last reply Jul 24, 2017, 1:24 PM Reply Quote 0
                    @Adaman134
                    If you shut your Pi down and turn it back on, does the mirror launch automatically?
                      Adaman134
                      @Mykle1 no it does not launch automatically
                      M 1 Reply Last reply Jul 24, 2017, 3:54 PM Reply Quote 0
