    How to stop Magic Mirror *NOOB*
    14 Posts 2 Posters 39.4k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @Adaman134
      @Adaman134
      You’re running PM2? That would relaunch the mirror. Instead of Quitting the mirror, you can Minimize it via one of the other menus. Then type pm2 stop mm in your terminal. That will stop the mirror from relaunching
        Adaman134
        ok yeah it was running in pm2 (I just ran magic mirror for the first time after install and I chose yes for that option) Now how would I start it in pm2?
        pm2 start mm?
          @Adaman134
          yes sir
          A 1 Reply Last reply Reply Quote 1
            Adaman134
            when i do
            pm2 start mm
            it says: script not found
            I should already have a script though as it worked on startup, where would that script be if I have it already?
              Adaman134 @Mykle1
              @Mykle1 ok So I found that my mm.sh was in the installers folder and that works now but when I do pm2 start mm I get an error on run-start.
              MM opens up and everything but is there a reason why I get an error for that?
              Thanks,
              Adam
                @Adaman134
                If you shut your Pi down and turn it back on, does the mirror launch automatically?
                  Adaman134
                  @Mykle1 no it does not launch automatically
                    @Adaman134
                    Then I believe you may not have saved the state of PM2 on installation.
                    https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                      Adaman134 @Mykle1
                      @Mykle1 ok thank you for the help, I finally got it to work like I wanted it to.
                        @Adaman134
                        You’re welcome.
