    How to stop Magic Mirror *NOOB*
    14 Posts 2 Posters 38.7k Views 3 Watching
      Adaman134
      Sorry about this dumb question but, how would I stop the magic mirror app? I have tried pressing ctrl + w and that only does some sort of refreshing thing to the app.
      Would anyone be able to help me with this?
      If you need more information let me know.
      Thanks,
      Adam
        Mykle1 Project Sponsor Module Developer @Adaman134
        @Adaman134
        Press the Alt key. This drops down a menu at the top. You won’t see your mouse cursor until you move it into the menu bar. The File menu allows you to Quit the mirror. Check the other menus for other options
          Adaman134
          When I try and close it doing that it reopens a couple of seconds after
            @Adaman134
            You’re running PM2? That would relaunch the mirror. Instead of Quitting the mirror, you can Minimize it via one of the other menus. Then type pm2 stop mm in your terminal. That will stop the mirror from relaunching
              Adaman134
              ok yeah it was running in pm2 (I just ran magic mirror for the first time after install and I chose yes for that option) Now how would I start it in pm2?
              pm2 start mm?
                @Adaman134
                yes sir
                A 1 Reply Last reply Reply Quote 1
                  Adaman134
                  when i do
                  pm2 start mm
                  it says: script not found
                  I should already have a script though as it worked on startup, where would that script be if I have it already?
                    Adaman134 @Mykle1
                    @Mykle1 ok So I found that my mm.sh was in the installers folder and that works now but when I do pm2 start mm I get an error on run-start.
                    MM opens up and everything but is there a reason why I get an error for that?
                    Thanks,
                    Adam
                      @Adaman134
                      If you shut your Pi down and turn it back on, does the mirror launch automatically?
                        Adaman134
                        @Mykle1 no it does not launch automatically
