    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 569.6k Views 58 Watching
      chengyuanfei
        mc_landin
        I can’t seem to get the module to work properly. I made pictures and generated a training.xml file. When I test said file it does identify me.
        However, I can’t find a user array in the training file to add to the config.xml. When I add the only user present it still doesn’t work
        • X
          xchribiza
          I have managed to make this module to work finally…BUT …
          I have one user (since I have just set it up) and it recognises me well etc…but it recognises other people as ME ???
          Why ??
          Is there something to be done ?
            mc_landin
            Anyone able to help me out with this? :)
            https://forum.magicmirror.builders/topic/4206/facial-recognition-no-users
              reaper81
              Hello everyone
              the class ‘everyone’, which should activate a module for every person, dont work for me. the clock-module for example stay inactive, no matter wich person is detected. The config looks like this:
              module: “clock”,
              position: “top_left”,
              classes: “everyone”
              Work this class for anyboby?
              J 1 Reply Last reply
                j.e.f.f Project Sponsor Module Developer @reaper81
                @reaper81 I think you also need to include the class default as the facial recognition app spends most of its time logged out.
                  reaper81
                  @j.e.f.f
                  the default-class works fine but i whould like to show modules only if a person is in the room. thats why the class “everyone” exist. Do you use it? does it work?
                    @reaper81 yeah in that case it should work for what you’re trying to do. If it isn’t then I don’t know why.
                    You could also try using a motion sensor to turn the screen on and off. Essentially when someone walks up to the screen it shows modules, and after a specified time out of no motion sensed, if turns itself back off.
                      reaper81
                      So i repeat my question: does anybody use the “everyone”-class and it work?
                        mc_landin
                        I am struggling to get modules using a name class to work. Still waiting for an answer as well
                        T 1 Reply Last reply
                          JavierTSalas
                          Hey guys. I’m having difficulty using my webcam with the capture.py script. I’m able to use fswebcame and motion to capture video but I keep getting errors running the script. I’m using a the playstion eye as a webcam. Any ideas?
                            salamures
                            Hi there, maybe someone is able to help me out.
                            I am trying to run capture.py but getting this Error
                               File "capture.py", line 18, in
                                  import lib.capture as capture
                               File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py", line 21, in
                                 from . import config
                               File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py", line 15, in
                                 (CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.__version__.split(".")
                            ValueError: not enough values to unpack (expected 4, got 3)
                            A 1 Reply Last reply
                            • A
                              avinash @salamures
                              @salamures said in Facial Recognition - customize your mirror for every user!:
                              I am also facing the same issue. Any effort to resolve it will be appreciated.
                                salamures @avinash
                                Are you using OpenCV 3.3? Then i might can help you.
                                  salamures
                                  Got another problem. My picam is not able to open. I am using opencv 3.3.
                                  Remember to set the name list environment variable FACE_USERS
                                  Using default FACE_ALGORITM: 1
                                  File "facerecognition.py", line 30, in
                                  camera = config.get_camera(preview)
                                  File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py", line 101, in get_camera
                                  return webcam.OpenCVCapture(device_id=0)
                                  File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/webcam.py", line 29, in __init__
                                  self._camera.open()
                                  TypeError: Required argument 'device' (pos 1) not found
                                  any suggestions?
                                    PrivatVoidMarmot
                                    Hello!
                                    I have an problem wirth the Facial Regonition Module. I have tried it with the PiCam and an normal webcam. It worked not really good with die webcam and after i’ve tried it with die PiCam it doesn’t work any more. I’ve updatet the config.js.
                                    This is the npm output:
                                    config.js:
                                    On the mirror nothing is shown. {
                                    			module: 'MMM-Facial-Recognition',
                                    				// 1=LBPH | 2=Fisher | 3=Eigen
                                    				recognitionAlgorithm: 1,
                                    				// Threshold for the confidence of a recognized face before it's considered a
                                    				// positive match.  Confidence values below this threshold will be considered
                                    				// a positive match because the lower the confidence value, or distance, the
                                    				// more confident the algorithm is that the face was correctly detected.
                                    				lbphThreshold: 50,
                                    				fisherThreshold: 250,
                                    				eigenThreshold: 3000,
                                    				// force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                                    				useUSBCam: true,
                                    				// Path to your training xml
                                    				trainingFile: 'modules/MMM-Facial-Recognition-Tools/training.xml',
                                    				// recognition intervall in seconds (smaller number = faster but CPU intens!)
                                    				interval: 1,
                                    				// Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                                    				logoutDelay: 15,
                                    				// Array with usernames (copy and paste from training script)
                                    				users: ['Jenny'],
                                    				//Module set used for strangers and if no user is detected
                                    				defaultClass: "default",
                                    				//Set of modules which should be shown for every user
                                    				everyoneClass: "everyone",
                                    				// Boolean to toggle welcomeMessage
                                    				welcomeMessage: true
                                    Any suggestions?
                                    • T
                                      thebeetleuk @mc_landin
                                      @mc_landin I’m at this stage as well! for some reason the classes dont change whats displayed when a new face is seen. So in this example the “default” is seen all the time and then when a generic face is seen then the “everyone” class isnt shown. Has anyone got this working?
                                                          module: "updatenotification",
                                                          position: "top_bar",
                                                          classes: 'default'
                                                          module: "clock",
                                                          classes: 'everyone'
        recognitionAlgorithm: 1, // 1=LBPH | 2=Fisher | 3=Eigen
        lbphThreshold: 50,
        useUSBCam: true, // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
        trainingFile: 'modules/MMM-Facial-Recognition-Tools/training.xml', // Path to your training xml
        interval: 2, // recognition intervall in seconds (smaller number = faster but CPU intens!)
        logoutDelay: 15, // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror f$
        users: [], // Array with usernames (copy and paste from training script)
        defaultClass: "default", //Module set used for strangers and if no user is detected
        everyoneClass: "everyone", //Set of modules which should be shown for every user
        welcomeMessage: true // Boolean to toggle welcomeMessage
                                      • T
                                        thebeetleuk @thebeetleuk
                                        • T
                                          thebeetleuk
                                          Hi All, I have found out that if you want to use your USB webcam for training you can update the file https://github.com/paviro/MMM-Facial-Recognition-Tools/blob/master/lib/config.py in the appropriate directory with the following. for some reason it doesnt seem to want to fall over to the webcam so I just commented out the pi web cam and added the usb one.
                                          def get_camera(preview=True):
                                              try:
                                          #        from . import picam
                                          #        capture = picam.OpenCVCapture(preview)
                                          #        capture.start()
                                          #        return capture
                                                  from . import webcam
                                                  capture.start()
                                                  return capture
                                              except Exception:
                                          • T
                                            thebeetleuk
                                            OK after lots and lots of trial and error I hope this helps people… these are the settings and results I had and as far as I can tell the everyone setting doesnt do what I would expect…
                                            I don’t hink you have a way of identifying a stranger and do something specific for them?
                                            It looks like when everyone is specified on its own then the logic doesnt seem to work. See classes: “everyone” below…
        users: ['martin'], // Array with usernames (copy and paste from training script)
        welcomeMessage: false // Boolean to toggle welcomeMessage
        module: "clock",
        classes: "default" // displays with no face detection (OK) - not displayed when martin detected (OK) - displayed with no specific user detected (OK?)
        module: "clock",
        classes: "default everyone" // displays with no face detection (OK) - displayed with no specific user and martin (OK)
        module: "clock",
        position: "bottom_right",
        classes: "default martin" // displays with no face detection (OK) - displayed with no specific user and martin (OK)
        module: "clock",
        position: "bottom_left",
        classes: "everyone" // never displays (??? I would expect this to display when Martin is detected - or any other user)
        module: "compliments",
        position: "lower_third",
        classes: "martin" // only displayed when martin detected (OK)
                                            • 10
                                            • 11
                                            • 10 / 11
