    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.7k Views 58 Watching
      j.e.f.f Project Sponsor Module Developer @paviro
      @paviro I had a hard time getting this to play nicely with modules that show and hide themselves. I created a pull-request that addresses this:
      https://github.com/paviro/MMM-Facial-Recognition/pull/48
      Basically I added a lockString config option to each show and hide command, and when combined with another module that also uses a lockString the particular module is only visible when both have removed their respective lock strings.
      See here for details about visibility locking:
      https://github.com/MichMich/MagicMirror/tree/develop/modules
      cheers!
        reaper81
        hello everyone,
        after update to the new version of the FR-Module i get this error-Massage while starting the MM.
        Starting MagicMirror: v2.1.1
        Loading config …
        Loading module helpers …
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘node_helper’
        App threw an error during load
        at Module._resolveFilename (module.js:470:15)
        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
        at Function.Module._load (module.js:418:25)
        at Module.require (module.js:498:17)
        at require (internal/module.js:20:19)
        at Object. (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:6:18)
        at Object. (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:89:3)
        at Module._compile (module.js:571:32)
        at Object.Module._extensions…js (module.js:580:10)
        at Module.load (module.js:488:32)
        Can anybody help me?
          @paviro I’ve switched to using the Pi cam for facial recognition, and my confidence numbers have improved significantly, but it still takes a good 5 seconds of standing absolutely still looking right at the camera to get it to work. I’ve trained the model with about 40 images of myself standing at various distances from the camera, sometimes looking right at it, other times staring blankly ahead (as if I were looking in the mirror).
          Is 5 seconds the best I can hope for, or does it work faster for others? I have the frequency configured to interval : 1 although I don’t see much difference between 1 and 2 (or anything smaller than 1).
          • L
            lepetitnicolas
            hello,
            After a few months of sleep, I wake up my mirror
            i’ve just update the raspberry and the MagicMirror to the last version
            also this module (facial recognition) to see if it works better
            but when i try to make the training.xml with train.py, i’ve this error :
            Reading training images...
            Assign label 1 to Gael
            Assign label 2 to lepetitnicolas
            OpenCV Error: Assertion failed (ssize.area() > 0) in resize, file /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/imgproc/src/imgwarp.cpp, line 1834
              File "train.py", line 98, in
                faces.append(prepare_image(filename))
              File "train.py", line 56, in prepare_image
                return face.resize(cv2.imread(filename, cv2.IMREAD_GRAYSCALE))
              File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/face.py", line 100, in resize
                interpolation=cv2.INTER_LANCZOS4)
            cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/imgproc/src/imgwarp.cpp:1834: error: (-215) ssize.area() > 0 in function resize
            anyone could help me ?
            N 1 Reply Last reply
            • N
              nuckinfutz @lepetitnicolas
              @lepetitnicolas Just saw this but here is the fix
              cd home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools
              sudo pip install future --upgrade
              L 1 Reply Last reply
              • E
                EdChamberlain
                This may not be an appropriate place but is there a good resource / tutorial for setting up / configuring the modules for the mirror? I’m specifically interested in facial recognition and the calendars - so far I only have the basic mirror installed.
                • L
                  lepetitnicolas @nuckinfutz
                  @nuckinfutz
                  thanks, i do what you saw but i have the same error…
                    chengyuanfei
                      mc_landin
                      I can’t seem to get the module to work properly. I made pictures and generated a training.xml file. When I test said file it does identify me.
                      However, I can’t find a user array in the training file to add to the config.xml. When I add the only user present it still doesn’t work
                      • X
                        xchribiza
                        I have managed to make this module to work finally…BUT …
                        I have one user (since I have just set it up) and it recognises me well etc…but it recognises other people as ME ???
                        Why ??
                        Is there something to be done ?
                          mc_landin
                          Anyone able to help me out with this? :)
                          https://forum.magicmirror.builders/topic/4206/facial-recognition-no-users
                            reaper81
                            Hello everyone
                            the class ‘everyone’, which should activate a module for every person, dont work for me. the clock-module for example stay inactive, no matter wich person is detected. The config looks like this:
                            module: “clock”,
                            position: “top_left”,
                            classes: “everyone”
                            Work this class for anyboby?
                            J 1 Reply Last reply
                              j.e.f.f Project Sponsor Module Developer @reaper81
                              @reaper81 I think you also need to include the class default as the facial recognition app spends most of its time logged out.
                                reaper81
                                @j.e.f.f
                                the default-class works fine but i whould like to show modules only if a person is in the room. thats why the class “everyone” exist. Do you use it? does it work?
                                  @reaper81 yeah in that case it should work for what you’re trying to do. If it isn’t then I don’t know why.
                                  You could also try using a motion sensor to turn the screen on and off. Essentially when someone walks up to the screen it shows modules, and after a specified time out of no motion sensed, if turns itself back off.
                                    reaper81
                                    So i repeat my question: does anybody use the “everyone”-class and it work?
                                      mc_landin
                                      I am struggling to get modules using a name class to work. Still waiting for an answer as well
                                      T 1 Reply Last reply
                                        JavierTSalas
                                        Hey guys. I’m having difficulty using my webcam with the capture.py script. I’m able to use fswebcame and motion to capture video but I keep getting errors running the script. I’m using a the playstion eye as a webcam. Any ideas?
                                          salamures
                                          Hi there, maybe someone is able to help me out.
                                          I am trying to run capture.py but getting this Error
                                             File "capture.py", line 18, in
                                                import lib.capture as capture
                                             File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py", line 21, in
                                               from . import config
                                             File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py", line 15, in
                                               (CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.__version__.split(".")
                                          ValueError: not enough values to unpack (expected 4, got 3)
                                          A 1 Reply Last reply
                                          • A
                                            avinash @salamures
                                            @salamures said in Facial Recognition - customize your mirror for every user!:
                                            I am also facing the same issue. Any effort to resolve it will be appreciated.
                                            • 10
                                            • 11
                                            • 10 / 11
