    Facial Recognition - customize your mirror for every user!
    216 Posts 56 Posters 570.3k Views 58 Watching
    • L
      lepetitnicolas @nuckinfutz
      @nuckinfutz
      thanks, i do what you saw but i have the same error…
        chengyuanfei
          mc_landin
          I can’t seem to get the module to work properly. I made pictures and generated a training.xml file. When I test said file it does identify me.
          However, I can’t find a user array in the training file to add to the config.xml. When I add the only user present it still doesn’t work
          • X
            xchribiza
            I have managed to make this module to work finally…BUT …
            I have one user (since I have just set it up) and it recognises me well etc…but it recognises other people as ME ???
            Why ??
            Is there something to be done ?
              mc_landin
              Anyone able to help me out with this? :)
              https://forum.magicmirror.builders/topic/4206/facial-recognition-no-users
                reaper81
                Hello everyone
                the class ‘everyone’, which should activate a module for every person, dont work for me. the clock-module for example stay inactive, no matter wich person is detected. The config looks like this:
                module: “clock”,
                position: “top_left”,
                classes: “everyone”
                Work this class for anyboby?
                J 1 Reply Last reply
                  j.e.f.f Project Sponsor Module Developer @reaper81
                  @reaper81 I think you also need to include the class default as the facial recognition app spends most of its time logged out.
                    reaper81
                    @j.e.f.f
                    the default-class works fine but i whould like to show modules only if a person is in the room. thats why the class “everyone” exist. Do you use it? does it work?
                      @reaper81 yeah in that case it should work for what you’re trying to do. If it isn’t then I don’t know why.
                      You could also try using a motion sensor to turn the screen on and off. Essentially when someone walks up to the screen it shows modules, and after a specified time out of no motion sensed, if turns itself back off.
                        reaper81
                        So i repeat my question: does anybody use the “everyone”-class and it work?
                          mc_landin
                          I am struggling to get modules using a name class to work. Still waiting for an answer as well
                          T 1 Reply Last reply
                            JavierTSalas
                            Hey guys. I’m having difficulty using my webcam with the capture.py script. I’m able to use fswebcame and motion to capture video but I keep getting errors running the script. I’m using a the playstion eye as a webcam. Any ideas?
                              salamures
                              Hi there, maybe someone is able to help me out.
                              I am trying to run capture.py but getting this Error
                                 File "capture.py", line 18, in
                                    import lib.capture as capture
                                 File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py", line 21, in
                                   from . import config
                                 File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py", line 15, in
                                   (CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.__version__.split(".")
                              ValueError: not enough values to unpack (expected 4, got 3)
                              A 1 Reply Last reply
                              • A
                                avinash @salamures
                                @salamures said in Facial Recognition - customize your mirror for every user!:
                                I am also facing the same issue. Any effort to resolve it will be appreciated.
                                  salamures @avinash
                                  Are you using OpenCV 3.3? Then i might can help you.
                                    salamures
                                    Got another problem. My picam is not able to open. I am using opencv 3.3.
                                    Remember to set the name list environment variable FACE_USERS
                                    Using default FACE_ALGORITM: 1
                                    File "facerecognition.py", line 30, in
                                    camera = config.get_camera(preview)
                                    File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py", line 101, in get_camera
                                    return webcam.OpenCVCapture(device_id=0)
                                    File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/webcam.py", line 29, in __init__
                                    self._camera.open()
                                    TypeError: Required argument 'device' (pos 1) not found
                                    any suggestions?
                                      PrivatVoidMarmot
                                      Hello!
                                      I have an problem wirth the Facial Regonition Module. I have tried it with the PiCam and an normal webcam. It worked not really good with die webcam and after i’ve tried it with die PiCam it doesn’t work any more. I’ve updatet the config.js.
                                      This is the npm output:
                                      config.js:
                                      On the mirror nothing is shown. {
                                      			module: 'MMM-Facial-Recognition',
                                      				// 1=LBPH | 2=Fisher | 3=Eigen
                                      				recognitionAlgorithm: 1,
                                      				// Threshold for the confidence of a recognized face before it's considered a
                                      				// positive match.  Confidence values below this threshold will be considered
                                      				// a positive match because the lower the confidence value, or distance, the
                                      				// more confident the algorithm is that the face was correctly detected.
                                      				lbphThreshold: 50,
                                      				fisherThreshold: 250,
                                      				eigenThreshold: 3000,
                                      				// force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
                                      				useUSBCam: true,
                                      				// Path to your training xml
                                      				trainingFile: 'modules/MMM-Facial-Recognition-Tools/training.xml',
                                      				// recognition intervall in seconds (smaller number = faster but CPU intens!)
                                      				interval: 1,
                                      				// Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror for a few seconds
                                      				logoutDelay: 15,
                                      				// Array with usernames (copy and paste from training script)
                                      				users: ['Jenny'],
                                      				//Module set used for strangers and if no user is detected
                                      				defaultClass: "default",
                                      				//Set of modules which should be shown for every user
                                      				everyoneClass: "everyone",
                                      				// Boolean to toggle welcomeMessage
                                      				welcomeMessage: true
                                      Any suggestions?
                                      • T
                                        thebeetleuk @mc_landin
                                        @mc_landin I’m at this stage as well! for some reason the classes dont change whats displayed when a new face is seen. So in this example the “default” is seen all the time and then when a generic face is seen then the “everyone” class isnt shown. Has anyone got this working?
                                                            module: "updatenotification",
                                                            position: "top_bar",
                                                            classes: 'default'
                                                            module: "clock",
                                                            classes: 'everyone'
        recognitionAlgorithm: 1, // 1=LBPH | 2=Fisher | 3=Eigen
        lbphThreshold: 50,
        useUSBCam: true, // force the use of a usb webcam on raspberry pi (on other platforms this is always true automatically)
        trainingFile: 'modules/MMM-Facial-Recognition-Tools/training.xml', // Path to your training xml
        interval: 2, // recognition intervall in seconds (smaller number = faster but CPU intens!)
        logoutDelay: 15, // Logout delay after last recognition so that a user does not get instantly logged out if he turns away from the mirror f$
        users: [], // Array with usernames (copy and paste from training script)
        defaultClass: "default", //Module set used for strangers and if no user is detected
        everyoneClass: "everyone", //Set of modules which should be shown for every user
        welcomeMessage: true // Boolean to toggle welcomeMessage
                                        • T
                                          thebeetleuk @thebeetleuk
                                          • T
                                            thebeetleuk
                                            Hi All, I have found out that if you want to use your USB webcam for training you can update the file https://github.com/paviro/MMM-Facial-Recognition-Tools/blob/master/lib/config.py in the appropriate directory with the following. for some reason it doesnt seem to want to fall over to the webcam so I just commented out the pi web cam and added the usb one.
                                            def get_camera(preview=True):
                                                try:
                                            #        from . import picam
                                            #        capture = picam.OpenCVCapture(preview)
                                            #        capture.start()
                                            #        return capture
                                                    from . import webcam
                                                    capture.start()
                                                    return capture
                                                except Exception:
                                            • 10
                                            • 11
                                            • 10 / 11
