    Dynamically Moving Modules
    7 Posts 5 Posters 4.2k Views 4 Watching
      reporter500
      I’m trying to dynamically move the modules on the screen, but I’m don’t know where to start. I’m able to identify all the modules loaded and hide and show them, but I’m not sure how to move them. I tried updating the module.config.position and the module.data.position but it did nothing. Can anyone shed some light on this for me.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @reporter500
        @reporter500 this isn’t a supported feature
          reporter500
          I knew it wasn’t supported, but I wanted to see if anyone was doing any custom development that might have solve this.
            A Former User
            It needs some trick.
            1. Get node of region container.
            2. Draw your dom and insert into region container node in getDom(). Your dom’s root node should have classname ‘module’.
            3. Set region container display style to block.
            Good luck!
            Ps. I use this trick in currently developing module. It works well.
            cowboysdudeC R 2 Replies Last reply
            • cowboysdudeC
              cowboysdude Module Developer @Guest
              @Sean said in Dynamically Moving Modules:
              OH do tell LOL
                reporter500 @Guest
                @Sean Perfect! Thank you.
                  shbatm Module Developer
                  This version of MMM-Carousel will allow you to set different locations for a module for different slides:
                  [card:shbatm/MMM-Carousel]
                  See the very bottom of the README for more information
                  If you’re interested in incorporating this into your own module, the relevant parts of the code are here and here
