    MMM-MyCommute
    286 Posts 80 Posters 720.4k Views 77 Watching
      j.e.f.f Project Sponsor Module Developer @Fonfon
      @Fonfon Do you see any errors in the pm2 logs? Can you send me your config? I’ll give it a try. (Hide your API key)
      • F Offline
        Fonfon @j.e.f.f
        @j.e.f.f thanks jeff
        when mm starting there is no error
        sorry but i d’ont knows how get logs
        this my config:
        module: ‘MMM-Mycommute’,
        position: ‘top_left’,
        showHeader: true,
        headerText: ‘Traffic’,
        api_key: ‘API’,
        origin: ‘my home’,
        startTime: ‘00:00’,
        endTime: ‘23:59’,
        hideDays: [0,6],
        destinations: [
        destination: ‘myworkplace’,
        label: ‘Bureau’,
        mode: ‘driving’,
        color: ‘#82E5AA’
          @Fonfon OK there are two problems with your config:
          module: 'MMM-Mycommute' needs a capital C, like follows:
          module: 'MMM-MyCommute'
          Next, the property name for the API key is apikey not api_key
          Give those a try and see if it fixes your issue.
          Also, the showHeader config isn’t needed any more. If you want a header, add it to your config in the normal way, like so:
                module: 'MMM-MyCommute',
                position: 'top_left',
                header: "Commute",  // ---- here ----
                  headerText: 'Traffic',
                  apikey: '...',
                  origin: '...',
                  startTime: '00:00',
                  endTime: '23:59',
                  hideDays: [0,6],
                  destinations: [
                      destination: '...',
                      label: 'Bureau',
                      mode: 'driving',
                      color: '#82E5AA'
          If you don’t want one, don’t specify that property.
          F 1 Reply Last reply Reply Quote 1
          • F Offline
            Fonfon @j.e.f.f
            its ok now Thanks very much for your help
            this module is absolutely fantastic !!!
            thanks again !!
              @Fonfon Glad it’s working for you now!
              • L Offline
                leshark
                I love this module, it works really well! Is there any way that the journey time could be displayed in HH:MM format rather than just minutes? I’ve looked through the config and I can’t see a way to change this.
                Many thanks!
                  j.e.f.f Project Sponsor Module Developer @leshark
                  @leshark I made it explicitly just in minute to save space. Even a long commute of 1hr 30min can be expressed shorter as 90 min. If I enabled the change in format as you ask then I’ll need to dedicate more space to the time, which takes away from the label. I felt the label was more important.
                  • L Offline
                    leshark @j.e.f.f
                    @j.e.f.f Hi, thanks for the reply, I can see that makes sense now and can live with it in minutes! Some of my journeys are 400+ minutes and at 0600 in the morning it takes a moment to do the math :-).
                    Cheers
                    Craig
                    • F Offline
                      Fonfon
                        @leshark I decided to throw in this feature. I didn’t change the CSS, so if you use a long formatting template, you run the risk of the label overlapping the travel time. I’ll leave that up to you to manage shortening your label. That said, there should be ample space for a format like 3h 45m.
                        To get the update, navigate to your MMM-MyCommute and execute the following:
                        git pull
                        then:
                        npm install
                        After that you’ll be able to specify a travelTimeFormat configuration option. By default it will be m [min] (e.g. 87 min), but you can specify any format you wish. I’m using the moment-duration-format plugin for this (https://github.com/jsmreese/moment-duration-format).
                        Note that this I’m using this plugin’s trim feature, which will omit unnecessary tokens. For example, if you specify a format of h[h] m[m] (e.g.: 1h 27m), but your travel time is less than an hour, only the minute portion will be displayed (e.g.: 36m instead of 0h 36m).
                        Have fun!
                        -Jeff
                        • L Offline
                          leshark @j.e.f.f
                          @j.e.f.f Works like a charm! Thanks for the update :-)
                            RYANO
                            Hi
                            How do get this work in New zealand, Sorry I am new to this and you module look great and I want to use it.
                              j.e.f.f Project Sponsor Module Developer @RYANO
                              @RYANO Hey glad you like the module! There should be nothing special you need to do in order to get this to work in New Zealand. If regular Google maps works for you in your browser or on your phone, then this module should work just fine. Follow the installation instructions as per the Readme, and make sure you get a Google API key. Put your API key in the apikey field in the config. Put your home address as it would normally appear in Google maps as the origin in the config, and the destination address, again as it would normally appear in Google maps as the destination for each entry in your destinations array. Configure everything else to your preference.
                              • K Offline
                                kasperb
                                @j-e-f-f Thanks for your module - it works great! I have one question: one of my trips involves using the light rail, however, the module list this as “(undefined)” opposed to the actual method of transportation. Do you have any suggestions how I could fix this?
                                • K Offline
                                  kasperb @kasperb
                                  @j-e-f-f The issue was resolved after a git pull - thanks for the quick fix!
                                  • L Offline
                                    lucallmon
                                    @j-e-f-f I haven’t come to this site for a while and wanted to know if you’ve worked out a way to have multiple stops and transportation modes in a single module. For instance, I’d like to see the total time it takes: Home to Metro station, Metro Station to Metro Station, Metro station to Work = total commute time. Is there a way to do this in a single module?
                                      j.e.f.f Project Sponsor Module Developer @lucallmon
                                      @lucallmon The Google directions API doesn’t directly work that way. One API call requires an origin, a destination, and a single mode of transportation. It’s possible to specify explicit waypoints, but those are assumed to be part of the same mode of transportation. In theory it should be possible to do what you are asking by making multiple calls, with the destination of the first call being the origin of the next call (and so forth). I worry, though, that such an approach would make it more likely to exceed the daily request limit. Let me think about it and see if there is an effective way to manage that.
                                      • L Offline
                                        lucallmon @j.e.f.f
                                        @j.e.f.f Thanks Brother! Looking forward to hearing how it turns out.
                                          Binog
                                          Hey j.e.f.f.
                                          Thanks for this amazing module !
                                          I do have the problem that I use two modules of your commute. once in a while it worked fine, but then it stopped working. Thought something withe the googleAPIkeys was wrong,. now trying, if I cutout one commute, the other shows itself.
                                          Do I have to name MMM-MyCommute to MMM-MyCommute2 for the second one? And then, do I have to rename the js-file as well?
                                          Thx for helping !
                                            j.e.f.f Project Sponsor Module Developer @Binog
                                            @Binog This module is supposed to support multiple instances. Send me a message with your config and I’ll help you troubleshoot.
                                            • 14
                                            • 15
                                            • 6 / 15
