    MMM-Hive
    39 Posts 7 Posters 28.2k Views 6 Watching
      spwood100
      Hi
      Just tested it on an up to date version of MM and still the same issue. The logs do not show anything out of the ordinary
      /home/pi/.pm2/logs/MagicMirror-out-0.log last 15 lines:
      0|MagicMir | Starting server on port 8080 …
      0|MagicMir | Server started …
      0|MagicMir | Connecting socket for: updatenotification
      0|MagicMir | Connecting socket for: calendar
      0|MagicMir | Starting node helper for: calendar
      0|MagicMir | Connecting socket for: MMM-Hive
      0|MagicMir | Starting node helper for: MMM-Hive
      0|MagicMir | Connecting socket for: newsfeed
      0|MagicMir | Starting module: newsfeed
      0|MagicMir | Sockets connected & modules started …
      0|MagicMir | Launching application.
      0|MagicMir | Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
      0|MagicMir | Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      0|MagicMir | Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
      however in developer mode I can see the the payload for the inside temp is not getting generated where as the outside temp is
      Do I have to enable something on my Hive account to let the API be called on it?
      Cheers
      M 1 Reply Last reply
        mongo116 Module Developer @spwood100
        @spwood100 Can you add deb: true, to your config.js under the MMM-Hive configuration options, and then reload and check the developer tools console. It should show more detailed information.
          spwood100
          Hi Mongo
          Thanks for your continued help on this. This is my config for this module and it doesnt give more detailed information in developer tools than already shown. Is there something worng with how I am calling it?
          module: “MMM-Hive”,
          header: “Hive”,
          position: “top_right”,
          temperatureSuffix: “°C”,
          username: “myusername”,
          password: “mypassword”,
          postcode: ‘whereIlive’,
          showNext: true,
          debug: true,
          animatedLoading: true,
          highestTemp: ‘22’,
          highTemp: ‘20’,
          lowTemp: ‘16’,
          lowestTemp: ‘14’,
          nothing in the pm2 error logs either it just does not look to be calling the payload for the INTERNAL temp.
          Cheers
            spwood100 @spwood100
            @mongo116 , If I click into the output in developer tools I get the following (not sure if thats any help?)
            var dt = new Date();
            var utcDate = dt.toUTCString();
            if (notification === “INSIDE”) {
            if (this.config.debug == true) {
            Log.log(utcDate + " " + this.name + " received notification: " + notification);
            this.processData(“INSIDE”, JSON.parse(payload));
            this.updateDom(this.config.animationSpeed);
            this.loaded = true;
            this.error = false;
            this.error401 = false;
              @spwood100 It looks like it should be working. I’ve just updated the module though and added the payload when debug is true. This should now output a load of text when in the console. Which is the JSON response from the Hive server relating to your receiver. You should see something like the following:
              “name”:“Your Receiver”,“nodeType”:“http://alertme.com/schema/json/node.class.thermostat.json#”
              I am using the “name”:“Your Receiver” to find the correct node (as this is the one that holds the temperature info). Could be that your’s is called something else. I’d say attach the complete JSON here, but I cannot be sure there isn’t anything in there that you wouldn’t want to put on a public website! So best bet is to copy / paste the text (starting with {“meta”:{},“links”:{},“linked”:{},“nodes”:[ and ending with }}}]}) into notepad++, and use the JS Tool plugin, which has a very good JSON viewer. If you run the JSON viewer, you will then see meta, links, linked, nodes etc on the left pane. If you can expand Nodes and then go into each one (0, 1, 2, etc) and let me know the ‘name:’ for each node (with the corresponding node number).
                spwood100
                Hey
                Yes I saw that suddenly pop up on my screen and I know have a bunch more information. My receiver and thermostat are named “downstairs” but I can rename those as thats not critical seeing as there is only one Hive thermostat in the house. So I have renamed this and cannot see the old name in the payload but I do see the first node which has a name of Your Receiver and if I drill down into that it does have a bunch of attributes one of which is Thermostat and has a Reported value in there.
                In terms of the information you want though:
                Node
                Array > Object 1: Hall Light
                  spwood100
                  Node > Array > Object 2 - Your Reciever
                  Node > Array > Object 3 - Landing Light
                  Node > Array > Object 4 - Receiver 3 ( I think this is the hot water reciever)
                  Node > Array > Object 5 - Hub
                  Node > Array > Object 6 - This seems to be an API call
                  Node > Array > Object 7
                  Node > Array > Object 8 - Your Receiver
                  Node > Array > Object 9 - Receiver 2
                  Hope this helps
                  M 2 Replies Last reply
                    @spwood100 Thanks for the info. I’ve updated the module and added a new config setting (‘nodeName’). Can you copy the debug text from the INSIDE debug info into notepad++ again, and using the JSON viewer drill down into each of the nodes. Only one should have stateHeatingRelay under attributes. Assuming only one does, make a note of the ‘name’ of this node and then add the following to the config section of the MMM-Hive section in your config.js:
                    nodeName: "value from above here",
                    Hopefully this should then pick up the inside temperature from your thermostat. If more than one have a stateHeatingRelay, then it’s back to the drawing board! As that’s not mentioned in any of the api details on the web :)
                      @spwood100 If I look at the payload from my Hive, I’m only seeing 5 nodes:
                      0: Your Receiver
                      1: Heating (thermostat)
                      2: Signal Booster
                      3: Your Hub
                      4: Heating (receiver)
                      My system is only heating, so maybe that’s the issue. It may be that both the hot water and heating receiver have stateHeatingRelay in the JSON response. Let me know how you get on with the updated version though. Thanks
                        spwood100
                        BINGO!!
                        It works, thanks so mych for your help on this (and obviously developing the module in the first place), its very much appreciated. Nice solution as well!
                        Cheers
                          @spwood100 Fantastic news :)
                          So what was the nodeName you have used to get this working?
                            spwood100
                            Its Receiver 2 which I guess is a standard if its a multi node set-up as you cannot rename it.
                            Thanks again
                              rick @mongo116
                              @mongo116 Hi - Looks like Hive have changed the login details and so the inside temp has stopped working. This can be fixed by changing the following line (#62) in node_helper.js from
                              url: lUrl + '/global/login',
                              to
                              url: lUrl + '/cognito/login',
                                DarrenG
                                Ah thank you, came here to research this issue and have just implemented your fix and all working again.
                                  mongo116 Module Developer @rick
                                  @rick Cheers for the details. I’ve updated and added some config options in case this changes again, so you only then need to update the config.
                                    rick
                                    Looks like Hive have been changing login details yet again!. This time you need to change line(#67) in node_helper.js from
                                    headers: { 'Content-Type': 'application/json'},
                                    to
                                    headers: { 'Content-Type': 'application/json', 'User-Agent': 'HiveRNApp/10.16.2' },
                                      @rick Thanks for that. Github has been updated :thumbs_up_light_skin_tone:
                                        Not sure whether many are using this module but figured I’d provide an update on the changes I made today. I’ve now updated the module so that it works again! I have updated to include the new login process and from testing it all appears to work - would welcome any feedback though :)
                                        • N
                                          np27np27
                                          My Hive module is giving a login error all of a sudden. Has Hive changed its user authentication method?
                                          Can the module author update this?
                                          N 1 Reply Last reply
                                          • N
                                            np27np27 @np27np27
                                            @mongo116 ?
