    MMM-Hive
    39 Posts 7 Posters 28.2k Views 6 Watching
      spwood100
      Hey
      Yes I saw that suddenly pop up on my screen and I know have a bunch more information. My receiver and thermostat are named “downstairs” but I can rename those as thats not critical seeing as there is only one Hive thermostat in the house. So I have renamed this and cannot see the old name in the payload but I do see the first node which has a name of Your Receiver and if I drill down into that it does have a bunch of attributes one of which is Thermostat and has a Reported value in there.
      In terms of the information you want though:
      Node
      Array > Object 1: Hall Light
        spwood100
        Node > Array > Object 2 - Your Reciever
        Node > Array > Object 3 - Landing Light
        Node > Array > Object 4 - Receiver 3 ( I think this is the hot water reciever)
        Node > Array > Object 5 - Hub
        Node > Array > Object 6 - This seems to be an API call
        Node > Array > Object 7
        Node > Array > Object 8 - Your Receiver
        Node > Array > Object 9 - Receiver 2
        Hope this helps
        M 2 Replies Last reply
          mongo116 Module Developer @spwood100
          @spwood100 Thanks for the info. I’ve updated the module and added a new config setting (‘nodeName’). Can you copy the debug text from the INSIDE debug info into notepad++ again, and using the JSON viewer drill down into each of the nodes. Only one should have stateHeatingRelay under attributes. Assuming only one does, make a note of the ‘name’ of this node and then add the following to the config section of the MMM-Hive section in your config.js:
          nodeName: "value from above here",
          Hopefully this should then pick up the inside temperature from your thermostat. If more than one have a stateHeatingRelay, then it’s back to the drawing board! As that’s not mentioned in any of the api details on the web :)
            @spwood100 If I look at the payload from my Hive, I’m only seeing 5 nodes:
            0: Your Receiver
            1: Heating (thermostat)
            2: Signal Booster
            3: Your Hub
            4: Heating (receiver)
            My system is only heating, so maybe that’s the issue. It may be that both the hot water and heating receiver have stateHeatingRelay in the JSON response. Let me know how you get on with the updated version though. Thanks
              spwood100
              BINGO!!
              It works, thanks so mych for your help on this (and obviously developing the module in the first place), its very much appreciated. Nice solution as well!
              Cheers
              M 1 Reply Last reply
                @spwood100 Fantastic news :)
                So what was the nodeName you have used to get this working?
                  spwood100
                  Its Receiver 2 which I guess is a standard if its a multi node set-up as you cannot rename it.
                  Thanks again
                    rick @mongo116
                    @mongo116 Hi - Looks like Hive have changed the login details and so the inside temp has stopped working. This can be fixed by changing the following line (#62) in node_helper.js from
                    url: lUrl + '/global/login',
                    to
                    url: lUrl + '/cognito/login',
                      DarrenG
                      Ah thank you, came here to research this issue and have just implemented your fix and all working again.
                        mongo116 Module Developer @rick
                        @rick Cheers for the details. I’ve updated and added some config options in case this changes again, so you only then need to update the config.
                          rick
                          Looks like Hive have been changing login details yet again!. This time you need to change line(#67) in node_helper.js from
                          headers: { 'Content-Type': 'application/json'},
                          to
                          headers: { 'Content-Type': 'application/json', 'User-Agent': 'HiveRNApp/10.16.2' },
                            @rick Thanks for that. Github has been updated :thumbs_up_light_skin_tone:
                              Not sure whether many are using this module but figured I’d provide an update on the changes I made today. I’ve now updated the module so that it works again! I have updated to include the new login process and from testing it all appears to work - would welcome any feedback though :)
                              • N
                                np27np27
                                My Hive module is giving a login error all of a sudden. Has Hive changed its user authentication method?
                                Can the module author update this?
                                N 1 Reply Last reply
                                • N
                                  np27np27 @np27np27
                                  @mongo116 ?
                                  • N
                                    np27np27 @np27np27
                                    I think its to do with Hive’s 2-factor authentication
                                    Does anyone have a workaround for it?
