    MMM-Hive
    39 Posts 7 Posters 27.3k Views 6 Watching
      mongo116 Module Developer @spwood100
      @spwood100 If I look at the payload from my Hive, I’m only seeing 5 nodes:
      0: Your Receiver
      1: Heating (thermostat)
      2: Signal Booster
      3: Your Hub
      4: Heating (receiver)
      My system is only heating, so maybe that’s the issue. It may be that both the hot water and heating receiver have stateHeatingRelay in the JSON response. Let me know how you get on with the updated version though. Thanks
        spwood100
        BINGO!!
        It works, thanks so mych for your help on this (and obviously developing the module in the first place), its very much appreciated. Nice solution as well!
        Cheers
          @spwood100 Fantastic news :)
          So what was the nodeName you have used to get this working?
            spwood100
            Its Receiver 2 which I guess is a standard if its a multi node set-up as you cannot rename it.
            Thanks again
              rick @mongo116
              @mongo116 Hi - Looks like Hive have changed the login details and so the inside temp has stopped working. This can be fixed by changing the following line (#62) in node_helper.js from
              url: lUrl + '/global/login',
              to
              url: lUrl + '/cognito/login',
                DarrenG
                Ah thank you, came here to research this issue and have just implemented your fix and all working again.
                  mongo116 Module Developer @rick
                  @rick Cheers for the details. I’ve updated and added some config options in case this changes again, so you only then need to update the config.
                    rick
                    Looks like Hive have been changing login details yet again!. This time you need to change line(#67) in node_helper.js from
                    headers: { 'Content-Type': 'application/json'},
                    to
                    headers: { 'Content-Type': 'application/json', 'User-Agent': 'HiveRNApp/10.16.2' },
                      @rick Thanks for that. Github has been updated :thumbs_up_light_skin_tone:
                        Not sure whether many are using this module but figured I’d provide an update on the changes I made today. I’ve now updated the module so that it works again! I have updated to include the new login process and from testing it all appears to work - would welcome any feedback though :)
                        • N Offline
                          np27np27
                          My Hive module is giving a login error all of a sudden. Has Hive changed its user authentication method?
                          Can the module author update this?
                          • N Offline
                            np27np27 @np27np27
                            @mongo116 ?
                            • N Offline
                              np27np27 @np27np27
                              I think its to do with Hive’s 2-factor authentication
                              Does anyone have a workaround for it?
