    MMM-Hive
    39 Posts 7 Posters 28.1k Views 6 Watching
      spwood100
      Hi Mongo
      Thanks for your continued help on this. This is my config for this module and it doesnt give more detailed information in developer tools than already shown. Is there something worng with how I am calling it?
      module: “MMM-Hive”,
      header: “Hive”,
      position: “top_right”,
      temperatureSuffix: “°C”,
      username: “myusername”,
      password: “mypassword”,
      postcode: ‘whereIlive’,
      showNext: true,
      debug: true,
      animatedLoading: true,
      highestTemp: ‘22’,
      highTemp: ‘20’,
      lowTemp: ‘16’,
      lowestTemp: ‘14’,
      nothing in the pm2 error logs either it just does not look to be calling the payload for the INTERNAL temp.
      Cheers
        spwood100 @spwood100
        @mongo116 , If I click into the output in developer tools I get the following (not sure if thats any help?)
        var dt = new Date();
        var utcDate = dt.toUTCString();
        if (notification === “INSIDE”) {
        if (this.config.debug == true) {
        Log.log(utcDate + " " + this.name + " received notification: " + notification);
        this.processData(“INSIDE”, JSON.parse(payload));
        this.updateDom(this.config.animationSpeed);
        this.loaded = true;
        this.error = false;
        this.error401 = false;
        M 1 Reply Last reply
          mongo116 Module Developer @spwood100
          @spwood100 It looks like it should be working. I’ve just updated the module though and added the payload when debug is true. This should now output a load of text when in the console. Which is the JSON response from the Hive server relating to your receiver. You should see something like the following:
          “name”:“Your Receiver”,“nodeType”:“http://alertme.com/schema/json/node.class.thermostat.json#”
          I am using the “name”:“Your Receiver” to find the correct node (as this is the one that holds the temperature info). Could be that your’s is called something else. I’d say attach the complete JSON here, but I cannot be sure there isn’t anything in there that you wouldn’t want to put on a public website! So best bet is to copy / paste the text (starting with {“meta”:{},“links”:{},“linked”:{},“nodes”:[ and ending with }}}]}) into notepad++, and use the JS Tool plugin, which has a very good JSON viewer. If you run the JSON viewer, you will then see meta, links, linked, nodes etc on the left pane. If you can expand Nodes and then go into each one (0, 1, 2, etc) and let me know the ‘name:’ for each node (with the corresponding node number).
            spwood100
            Hey
            Yes I saw that suddenly pop up on my screen and I know have a bunch more information. My receiver and thermostat are named “downstairs” but I can rename those as thats not critical seeing as there is only one Hive thermostat in the house. So I have renamed this and cannot see the old name in the payload but I do see the first node which has a name of Your Receiver and if I drill down into that it does have a bunch of attributes one of which is Thermostat and has a Reported value in there.
            In terms of the information you want though:
            Node
            Array > Object 1: Hall Light
              spwood100
              Node > Array > Object 2 - Your Reciever
              Node > Array > Object 3 - Landing Light
              Node > Array > Object 4 - Receiver 3 ( I think this is the hot water reciever)
              Node > Array > Object 5 - Hub
              Node > Array > Object 6 - This seems to be an API call
              Node > Array > Object 7
              Node > Array > Object 8 - Your Receiver
              Node > Array > Object 9 - Receiver 2
              Hope this helps
              M 2 Replies Last reply
                @spwood100 Thanks for the info. I’ve updated the module and added a new config setting (‘nodeName’). Can you copy the debug text from the INSIDE debug info into notepad++ again, and using the JSON viewer drill down into each of the nodes. Only one should have stateHeatingRelay under attributes. Assuming only one does, make a note of the ‘name’ of this node and then add the following to the config section of the MMM-Hive section in your config.js:
                nodeName: "value from above here",
                Hopefully this should then pick up the inside temperature from your thermostat. If more than one have a stateHeatingRelay, then it’s back to the drawing board! As that’s not mentioned in any of the api details on the web :)
                  @spwood100 If I look at the payload from my Hive, I’m only seeing 5 nodes:
                  0: Your Receiver
                  1: Heating (thermostat)
                  2: Signal Booster
                  3: Your Hub
                  4: Heating (receiver)
                  My system is only heating, so maybe that’s the issue. It may be that both the hot water and heating receiver have stateHeatingRelay in the JSON response. Let me know how you get on with the updated version though. Thanks
                    spwood100
                    BINGO!!
                    It works, thanks so mych for your help on this (and obviously developing the module in the first place), its very much appreciated. Nice solution as well!
                    Cheers
                      @spwood100 Fantastic news :)
                      So what was the nodeName you have used to get this working?
                        spwood100
                        Its Receiver 2 which I guess is a standard if its a multi node set-up as you cannot rename it.
                        Thanks again
                          rick @mongo116
                          @mongo116 Hi - Looks like Hive have changed the login details and so the inside temp has stopped working. This can be fixed by changing the following line (#62) in node_helper.js from
                          url: lUrl + '/global/login',
                          to
                          url: lUrl + '/cognito/login',
                            DarrenG
                            Ah thank you, came here to research this issue and have just implemented your fix and all working again.
                              mongo116 Module Developer @rick
                              @rick Cheers for the details. I’ve updated and added some config options in case this changes again, so you only then need to update the config.
                                rick
                                Looks like Hive have been changing login details yet again!. This time you need to change line(#67) in node_helper.js from
                                headers: { 'Content-Type': 'application/json'},
                                to
                                headers: { 'Content-Type': 'application/json', 'User-Agent': 'HiveRNApp/10.16.2' },
                                  @rick Thanks for that. Github has been updated :thumbs_up_light_skin_tone:
                                    Not sure whether many are using this module but figured I’d provide an update on the changes I made today. I’ve now updated the module so that it works again! I have updated to include the new login process and from testing it all appears to work - would welcome any feedback though :)
                                    • N
                                      np27np27
                                      My Hive module is giving a login error all of a sudden. Has Hive changed its user authentication method?
                                      Can the module author update this?
                                      N 1 Reply Last reply
                                      • N
                                        np27np27 @np27np27
                                        @mongo116 ?
                                        • N
                                          np27np27 @np27np27
                                          I think its to do with Hive’s 2-factor authentication
                                          Does anyone have a workaround for it?
