    I cannot get the calendar and events to show New Zealand
    12 Posts 3 Posters 7.2k Views 3 Watching
      RYANO
      Hi
      Please can someone help me I am trying to get my magic mirror to show a New Zealand calendar and events please help.
        ranger33
        Hey man! https://www.calendarlabs.com/ical-calendar/holidays/new-zealand-holidays-61/# try coping and basting this link into the space that likely reads as ‘http://www.calendarlabs.com/templates/ical/US-Holidays.ics’ currently. if that fails, check out this link https://www.calendarlabs.com/ical-calendar/holidays/new-zealand-holidays-61/ as it is a copy of the calendar and I’m sure the correct link is somewhere on there! If none of this works message me and i will be sure to get it running on my pi and send you what i did!
          RYANO @ranger33
          @ranger33 hi Thanks for the help see the below. It does not work, Again thank you for the help I am new at this.
          urgency: 7,
          timeFormat: “relative”,
          dateFormat: “MMM Do”,
          fullDayEventDateFormat: “MMM Do”,
          getRelative: 6,
          fadePoint: 0.25, // Start on 1/4th of the list.
          hidePrivate: false,
          colored: false,
          symbol: “calendar”,
          url: ‘https://www.calendarlabs.com/templates/ical/new-zealand-holidays.ics’,
            RYANO
            I all tried the link you sent this does not work as well.
            urgency: 7,
            getRelative: 6,
            hidePrivate: false,
            colored: false,
            symbol: “calendar”,
            url: “https://www.calendarlabs.com/ical-calendar/holidays/new-zealand-holidays-61/”,
              Mykle1 Project Sponsor Module Developer @RYANO
              @RYANO said in I cannot get the calendar and events to show New Zealand:
              The links above are not valid but I can provide you with a workaround for your problem.
              • Go here.
              • Click the green Download button to download the New_Zealand_Holidays.ics file.
              • Create an ics folder within your modules folder.
              • Move the New_Zealand_Holidays.ics file that you downloaded into the ics folder that you just created.
              • Open your config.js file. Change your calendar url to this:
              url: "webcal://localhost:8080/modules/ics/New_Zealand_Holidays.ics"
              • Save your config.js file.
              • Run your mirror.
              • That works!
                What events are you referring to?
                  RYANO
                  thank you so much for the the help I WOW thanks again. I will give it a try and ley you know, again thank you.
                    RYANO
                    thank you everyone for your help I my NZ calendar working you are all great again thank you soooo much, you all rock!!
                      RYANO @Mykle1
                      @Mykle1
                      thansk you works perfect, you rock!!1, thank you again and everyone for the help you all are great, many thanks.
                        You’re welcome. Enjoy your mirror. :^)
