    602 Posts 67 Posters 2.3m Views 68 Watching
      shbatm Module Developer
      @imdickie If you were on the Master branch it makes sense now why you were getting duplicate views, it was using ffmpeg and looking at only the first port for both cameras. The work-in-progress branch does not use websockets/ports for local playback since OMXPlayer just draws directly on top of the MM’s browser window.
      For the black screen: I forgot the wip branch has an additional node package required. This should take care of your problem:
      cd ~/MagicMirror/modules/MMM-RTSPStream
      git checkout wip
      git pull
      npm install
      You may or may not need to also add a moduleOffset config option: see the posts above for pictures, if the video doesn’t line up with the border, you can add moduleOffset: X to shift the video over (where X is a number of pixels).
      For more information about the wip branch, there is an updated README on the Github page: https://github.com/shbatm/MMM-RTSPStream/tree/wip
      For pm2: it’s definitely not a requirement, but I find it’s nice to have; I included in the note above just in case you were already using it. It will automatically run the MM script for you on startup. See this page if you want more information.
      To all using the module: Thanks for bearing with me, I haven’t had a lot of time this past month to finish out the hardware-accelerated version (wip/development branch) but I hope to get it done in the next month or so. I really do appreciate any feedback / issues you have to help me improve this module.
      I L 2 Replies Last reply Reply Quote 1
      • I Offline
        imdickie
        @shbatm said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        That did it. Thanks a ton.
        Not sure if it is omxplayer or not, but the stream seems to be much clearer. There is definitely less lag.
        Excellent work, thanks again.
        • I Offline
          imdickie @shbatm
          I read through everything I can find and am stuck at the final setting. Can you provide the exact syntax for for the moduleOffset setting?
          I tried several iterations and finally got it to shift, but it shifts an equal amount vertically and horizontally.
          First I tried this:
          moduleOffset:
               top: x
               right: x
               bottom: x
               left: x
          and that put the video smack dab in the center and flipped between the two streams.
          Then I tried this:
          moduleOffset: -20,
          and it shifted the video up and left 20 pixels.
          What I am trying to accomplish is shift the videos up but stay the same left/right.
          Thanks.
            @imdickie The 2nd one was the correct method. I made an adjustment to the code so now you can specify separate vertical & horizontal offsets.
            // Both methods below should work now:
            // Same Offset for Horizontal & Vertical:
            moduleOffset: -20    // any number works
            // Different Offsets for Horizontal & Vertical:
            moduleOffset: { top: -20, left: 0 }
            I didn’t get a chance to double check on my mirror, so please pull the update and let me know if you have any issues:
            # Run the following to update the module
            git pull
            If you want to make any further adjustments yourself without waiting for me, see this post above on where to edit the code directly.
            • I Offline
              imdickie
              I was able to get the overlay to match perfectly without using the moduleOffset variable by setting the module to the bottom bar.
              It offsets when I positioned it other spots. Also, since you are working on this I noticed when the RTSPStream module is placed near another module that can shift in size like newsfeed it will sift the overlay. That was why I thought to place it in the bottom bar so it became the anchor in the bottom justification.
              Thanks again for a great module. It really helped with the wife acceptance factor.
                @imdickie Great! I’m glad it’s working!
                WRT the offset – that part is definitely a work in progress and the moduleOffset setting is a stop-gap.
                For anyone who is proficient in JavaScript – I need a better way to get the position of the camera window’s canvas tag with respect to the corner of the screen and not the browser window. Currently I’m using canvas.getBoundingClientRect() which doesn’t account for all of the borders, margins, or paddings.
                  barnosch
                  Do i understand correctly?
                  Local Player means that it only can playback a source, directly installed at the pi?
                  No source from a wlan attached ip cam?
                  Tried the wip branch for my IP cam, since the ffmeg player uses 100% and has 6 seconds delay in my case.
                  With the omx player i do not get a picture anymore. (At least i do not have a complete black screen anymore ;) )
                    shbatm Module Developer @barnosch
                    @barnosch Here is a picture to explain:
                    • Please make sure you run the following after switching branches:
                        npm install
                    • Do you have any errors in the console log?
                    • Please check omxplayer is installed
                        which omxplayer
                        # Should show '/usr/bin/omxplayer'
                    • Please check omxplayer is running when the video should be playing:
                        pgrep omx
                        # Should show a number (process ID)
                      barnosch
                      Thanks for the explanation.
                      It was already working, but i could not see the stream remotely within a VNC session (the ffmpeg stream was visible).
                      It works perfect now. No delay, and way sharper.
                      But…
                      If i restart the mirror because of changes in the config, i get a blank black screen.
                      The omxplayer does not stop completely. One instance is still running and is not killable.
                      Additionally it seems that something kills the DNS of the pi. (Could be something else, but i guess it starts by adding your module).
                      Now the stupid thing. if i restart the service with “dhclient”, the name resolution works again, but i need to restart the mirror, that the scripts are loading.
                      If i restart the mirror, dns is not working anymore. (etc/resolve.conf is correct)
                      It would really helpful if the omxplayer would shutdown completely if i
                      pm2 stop mirror.sh
                      or
                      pm2 restart mirror.sh
                      to not get a blank screen.
                      Above all this, i love the module and appreciate your work. Thanks a lot.
                      WAF is really huge for this great addon ;)
                        @barnosch Great! I’m glad its working. You bring up an important point that I should emphasize:
                        For anyone using the OMXPlayer Version: OMXPlayer outputs directly to the screen via the GPU. The video window will show up on top of anything else and will not appear in any remote desktop, VLC, or remote browser windows. This is by design. Think of it like picture-in-picture on your TV.
                        About the OMXPlayer not exiting: this is a known issue and is the reason the wip branch hasn’t been made the master yet. I thought I had a fix for it, but it’s inconsistent.
                        A temporary fix is to try adding the following BEFORE the npm start line in your mirror.sh script to make sure everything is dead before restarting:
                        pkill omxplayer
                        pkill electron
                        • L Offline
                          LindaBrestine @shbatm
                          git checkout wip
                          git pull
                          npm install
                          thanks for your support. It really helps
                            barnosch @shbatm
                            added the pkill commands but it does not work. It does not kill the apps.
                            From time to time, the feed disappears. Have not yet found when and why.
                            Sometimes it runs 2 days without problems, the other day it only lasts for some hours.
                            Weird.
                            Only thing what helps is currently a reboot of the whole pi.
                            Since it was to complicated to log in on a device to give the reboot command, i set up a
                            Amazon Dash Button and placed it right next to the mirror.
                            So my wife can reboot the mirror with just a simple order- click. ;)
                            Hopefully the OMX version will become more stable sooner or later.
                            K S 2 Replies Last reply Reply Quote 0
                            • X Offline
                              xblackdemonx
                              I don’t understand, I downloaded the module, i’ve added this to my config.js file and I only see the square box where it’s supposed to show the feeed but it doesn’t show anything. The box is blank. If I put the same URL(rtsp://192.168.1.2:554/unicast/) in VLC on my magic mirror it works fine.
                              My MagicMirror is setup using Debian Jessie and I autostart MagicMirror via PM2. The camera I use is the XiaoMi XiaoFang Smart IP Security Home Camera running fang-hacks Please help.
                              module: ‘MMM-RTSPStream’,
                              position: ‘bottom_center’,
                              autoStart: true,
                              rotateStreams: false,
                              rotateStreamTimeout: 10,
                              showSnapWhenPaused: false,
                              moduleWidth: 704,
                              moduleHeight: 240,
                              stream1: {
                              url: ‘rtsp://192.168.1.2:554/unicast/’,
                              snapshotUrl: ‘’,
                              snapshotRefresh: 10, // Seconds
                              frameRate: “30”,
                              port: 9999,
                              width: “320”,
                              height: “240”,
                              • K Offline
                                kasperb @barnosch
                                @barnosch Having the same issue; only a browser refresh or restart of the MM works. I started to question my camera and thought it was going offline, but looks like it’s related to the current WIP version. :-)
                                • NiggichN Offline
                                  Niggich
                                  @shbatm I try everything to get stream working with omxplayer but I always get a black blank screen. I don’t know what can I try anymore. When I change it back to ffmpeg the stream is working…
                                  X 1 Reply Last reply Reply Quote 0
                                  • X Offline
                                    xblackdemonx @Niggich
                                    @Niggich Then why do you insist on using omxplayer then?
                                    NiggichN 1 Reply Last reply Reply Quote 0
                                    • NiggichN Offline
                                      Niggich @xblackdemonx
                                      @xblackdemonx The ffmpeg have a time difference from live to stream about 10 seconds.
                                      • X Offline
                                        @Niggich Not for me. I see maybe a 1/2 second delay only.
                                        • NiggichN Offline
                                          @xblackdemonx how you did this? I try everything… how is your config?
                                          • X Offline
                                            @Niggich Nothing special. Maybe reboot your cameras?
                                                    module: 'MMM-RTSPStream',
                                                    position: 'bottom_bar',
                                                        autoStart: true,
                                                        moduleWidth: 354,
                                                        moduleHeight: 240,
                                                        stream1: {
                                                            url: 'rtsp://192.168.1.2:554/unicast',
                                                            snapshotUrl: '',
                                                            frameRate: "15",
                                                            port: 9999,
                                            • 30
                                            • 31
                                            • 2 / 31
